Rear corner replacment need ideas?? updated pic heavy FAQ
bugger101
bugger101 is offline
PostPosted: Sat Feb 18, 2012 8:32 am    Post subject: Rear corner replacment need ideas?? updated pic heavy FAQ Reply with quote
hey guy's I need some idea's on how to replace the corners, I have looked(searched) but I am coming up with threads that have broken links on the pictures Confused . I have heard of cutting out and around the frame but I don't think i can do it to this one. I am also replacing the battery trays while I am there. Any help is appreciated Very Happy
here are some pics of the corners for reference
75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus
ned
ned is offline
PostPosted: Sat Feb 18, 2012 9:39 am    Post subject: Reply with quote
If that were mine I would start by sanding that paint to see just how bad it`s gonna be. I would remove the engine first to create better access. But thats me. You may be surprised at just how bad it isn`t, but then again you may open up a whole can of worms you never anticipated. Good luck and just don`t be in a rush. I would open one side at a time. That way I can always change my mind if I don`t like what I see and just drive it as is. They are not all show cars. Good luck and try to have some fun. Smile Oh... I see now that it looks like the engine is out. And it don`t look too bad. But then again I am a Californian.
bugger101
PostPosted: Sat Feb 18, 2012 9:59 am    Post subject: Reply with quote
I have the engine out and have spot blasted the area it's not that much worse. I am just confused with where i would cut and weld where it meets with the rear valance Sad Im just kinda of stumped at this moment. never have done a rear corner on a bus before. I think my plan of attack it to cut right below the mounting bolt for the taillight and up along the side. something like this
but the other side is going to have to wait untill I get the rear wheel arch because of this
Yea my bus is a rust bucket Laughing But it means alot to me, I wouldn't get rid of it for anything.
2010 ford focus
DirtyCossack
DirtyCossack is offline
PostPosted: Sat Feb 18, 2012 12:26 pm    Post subject: Reply with quote
My corners are far worse: wrecked and twisted by previous owner and hack body man. I wanna say I saw replacement corner panels on Bus Boy's site, but they're only 15 inches tall from bottom. The other idea I have is to further explore the rust's extent and contemplate fabrication from raw sheet metal if you have access to a good metal shop; which is looking to be my only option.
bugger101
PostPosted: Sat Feb 18, 2012 12:54 pm    Post subject: Reply with quote
Sweet my panels just showed up Very Happy I am going to give it a try later today or tonight Very Happy . Will update with progress
2010 ford focus
cool karmann collected
cool karmann collected is offline
PostPosted: Sat Feb 18, 2012 1:00 pm    Post subject: Reply with quote
General rule is don't start cutting out big chunks until you have a repair panel in your hand. It's hard to say exactly where to cut as a lot depends on how solid (or not) the metal work is at your intended 'join' until you start cutting. That corner panel is available new still, although i don't know what availability is like where you are.
http://www.justkampers.com/shop/t2-bay-window/orig...10680.html
Price is good for what you're getting, works out more cost-effective in terms of time than the usual lower corner repair panel and some homemade patches Wink
Ant
grandpa pete
grandpa pete is offline
PostPosted: Sat Feb 18, 2012 8:30 pm    Post subject: Reply with quote
If you are in orlando you can save a lot of money on the next pannels you need by getting used peices from randy in Valrico ( near tampa ) he is great to work with...look up " a view from the bay " in the classifieds or pm me and i will look it up when i get home ..................... working in phoenix ..............
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
bugger101
PostPosted: Sat Feb 18, 2012 11:23 pm    Post subject: Reply with quote
here is where I am at Very Happy
Marking the cut
Now making the cut Smile
How I left it tonight
now my plan of attack is to remove the battery tray tomorrow where it is spot welded to the side and put some solid metal there so i can weld my tray in, then weld the corner in and fix the area that is next to the seam.
Here is the replacement panels I am working with.
VW battery trays (had the Klokkerholm sent that garbage back)
2010 ford focus
bugger101
PostPosted: Sun Feb 19, 2012 6:45 am    Post subject: Reply with quote
Hey I know randy he is a great guy, I bought my engine from him.
2010 ford focus
kangaboy
kangaboy is offline
PostPosted: Sun Feb 19, 2012 9:39 am    Post subject: Reply with quote
Where did you get those replacement panels? I thought they didnt make those for late bays....or if they did they were cheap and required a bit of persuading to get to fit.
-74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote:
Shocked
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out Laughing
bugger101
PostPosted: Sun Feb 19, 2012 5:50 pm    Post subject: Reply with quote
the VW battery tray fell right into place didn't need any cutting at all Cool as for the corner I got it from a busdepot It is not a Klokkerholm, but the other corner is a klokkerholm. compared side by side the klokkerholm is shit there are wrinkles all over it Confused
http://busdepot.com/view.jsp?model=57&category=43&group=112&prodgroup=1043
http://busdepot.com/view.jsp?model=57&category=43&group=112&prodgroup=1045
it seems like I got the last of the vw trays for the passenger side
pics as of tonight. ran out of wire Mad
2010 ford focus
highlandmurf
highlandmurf is offline
PostPosted: Sat Mar 24, 2012 10:06 am    Post subject: Reply with quote
Hi,
Thanks for posting your repair. This is a job I will need to be tackling soon. I was wondering how you went about marking out where you need to cut, seeing as the bus is neither level or square.
Also, I see that you stayed away from the seam towards the wheel arch.
Did you cut down the bus depot corner, or is this as far as it goes?
Thanks
1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate
bugger101
PostPosted: Sun Jun 10, 2012 9:20 am    Post subject: Reply with quote
highlandmurf wrote:
Hi,
Thanks
Just to up date this thread and answer your questions
the busdepot corner does go the full length,but does not have the seam Sad so I stayed away from the seam but I need to fix it Mad .
updated pictures
Not bad for the first time though Razz panel did warp a little d'oh!
but hey it's a learning experience Very Happy
2010 ford focus
levi20AE
levi20AE is offline
PostPosted: Sun Jun 10, 2012 2:13 pm    Post subject: Reply with quote
I just did a similar repair on my bus after the PO repaired a bent frame section with bondo.
I was lucky enough to purchase an entire late westy for $100 from a local VW shop to use as a panel donor. Apparently someone cut the bus in half and thought they could sell it as scrap metal without a title.
1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
20th AE VW GTI - 369hp 340tq @ 26 PSI
1982 Rabbit Pickup - German AAZ 1.9TD - daily with lots of MPGs
View user's profile Send private message Instagram Classifieds Feedback
Batan
Batan is offline
PostPosted: Sun Jun 10, 2012 2:51 pm    Post subject: Reply with quote
levi20AE wrote:
Gotta ask, what's up with the blue clutch release shaft? Very Happy
'69 Riviera Bay
'03 20th Anniversary GTI
'74 Super Beetle
Badzak Creative – Still and Motion Pictures
bugger101
PostPosted: Mon Jun 11, 2012 8:42 am    Post subject: Reply with quote
[quote="levi20AE"
I was lucky enough to purchase an entire late westy for $100 from a local VW shop to use as a panel donor. Apparently someone cut the bus in half and thought they could sell it as scrap metal without a title.[/quote]
I would drool if I found that, as I need a lot of weird body panels Laughing
To keep this thread going here is where I am at on the other side(driver's side) still have the other corner which is a piece of shit, might have to get the klassic fab corner Razz
But I have been busy with ford's corporate training center Mad , I will get it done soon Pray
2010 ford focus
1967250s
1967250s is offline
PostPosted: Mon Feb 11, 2013 7:15 pm    Post subject: Reply with quote
Any more done? Good work!
bgoble
bgoble is offline
PostPosted: Tue Feb 12, 2013 12:11 pm    Post subject: Reply with quote
The OP of this thread is a wealth of knowledge and doesn't mind sharing.
http://www.thesamba.com/vw/forum/viewtopic.php?t=543445
elementnz
elementnz is offline
PostPosted: Thu Jan 12, 2017 2:44 pm    Post subject: Re: Rear corner replacment need ideas?? updated pic heavy FAQ Reply with quote
Can I ask you how long it took you to replace? I've just had both corners and d posts replaced and have received a bill of $17,000. $5900 was parts the rest labour I'm thinking this is pretty extreme and wanted to find out how long it would have actually taken
thanks
alman72
alman72 is offline
PostPosted: Thu Jan 12, 2017 2:54 pm    Post subject: Re: Rear corner replacment need ideas?? updated pic heavy FAQ Reply with quote
^good lord!!!
did they paint?
