Type 3 Contingent Melbourne
Page: Previous  1, 2, 3 ... 45, 46, 47 ... 126, 127, 128  Next
vlad01
vlad01 is offline
PostPosted: Thu Mar 01, 2012 3:39 am    Post subject: Reply with quote
Willo357 wrote:
internet police wrote:
i havent done much recently. i wanna get the notch finished soon i just need someone to do the body work and sort out what i need for roadworthy then itll be on the road. the fastback has been having some troubles atfirst the exhaust fell off but that all fixed now except some days it wont start or it starts and just randomly stops running at about 45 kmh. also i fitted new points & plugs and checked the timing but it still had a fuckload of over-run sometimes it keeps going for 2 minutes. and the sets of points i put in are completely kangarooted in about a week. i dunno whats goin on with it. ive been contemplating getting a different daily driver. and just sorting out the fastback and selling it to mum to pay for the notch.
1. Running on = either your carb solenoids (the small tin cans with a elect lead on them) are not working or they are not in tight enough. to check turn the ignition on and then plug the elect lead in and out and listen for a click. if they click you need to tighten them in the carb body to stop leaks.
2. points burning can be for a number of reasons.
a. incorrect points gap
b. condensor not working or dogey
c. make sure when you check your points cap that the feeler gauge does not have oil on it.
d. vacuum advance diaphragm has a hole in it and is letting fuel vapor into the distributor
e. primary coil shorted internally(ie bad coil) check the resistance of the coil terminal LT to terminal, terminal to case, HT terminal to case, to LT terminals etc..
i drive my square every day.... it loves it .
Get it sorted and keeps smiling.
id come give you a hand but i have a big weekend of engine tuning myself, let me know next week if u still have probs, i might be able to help
oh p.s. to check the vacuum advance diaphragm pull the hose from the carb, push the distributor plate in then whilst holding it in put your thumb over the hose, release the plate and note how it returns. Then let go of the hose..... the plate should return some more.... if it doesnt then the diaphragm is broken .... but do it a few times to make sure.
I added one for ya, that can also explain not starting sometimes.
I don't know about 2.d. ? you really think so that would burn points?
dragsters for life
dragsters for life is offline
PostPosted: Thu Mar 01, 2012 7:48 am    Post subject: Reply with quote
big willy laying it down like a boss
new t3c merch coming soon
Slow 1200
Slow 1200 is offline
PostPosted: Thu Mar 01, 2012 7:53 am    Post subject: Reply with quote
I've had 2.d happen once, took me a while to figure that one out!
Willo357
Willo357 is offline
PostPosted: Thu Mar 01, 2012 11:57 pm    Post subject: Reply with quote
gotta help out the police!!!
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...highlight=
Willo357
Willo357 is offline
PostPosted: Fri Mar 02, 2012 12:01 am    Post subject: Reply with quote
so who has totally programable ignition controll ......? As of 5 min ago me!
pics comming tomorrow ... hell maybe a vid
vlad01
vlad01 is offline
PostPosted: Fri Mar 02, 2012 2:54 am    Post subject: Reply with quote
well concrete is on its way, next sat is the day. had to delay it so the ground around the apron can dry out from all this shit rain.
Got a wicked ass price on the whole shebang!
nearly got 220m2 of 18mm new chip board for around 600 buks to line the whole workshop.
A guy was selling the whole factory worth of chip board and MDF for 6k and also individually sell them too. I got this estimate price and the next day I got him the correct measured amount I needed and he said the whole lot was sold.
FFFUUUUUUUUUU!!!!!!!!!!!!!
who ever bought those at a few bucks a pop, is going to make shit loads of money. There was a few thousand sheets of brand new chip board.
man the stuff you find and miss out on ebay Laughing
I have noted all the correct building materials I need are on ebay in bucket loads for dirt cheap and new, yet the building suppliers and timber yards can not get anything I need as its apparently "obsolete sizes"
well there you go. Smile
dragsters for life
PostPosted: Fri Mar 02, 2012 1:24 pm    Post subject: Reply with quote
you should talk to the fella about board, his factory was full of it when he moved in
coffee at north point this morn, see you lads there
Phat bug
Phat bug is offline
PostPosted: Sun Mar 04, 2012 6:52 pm    Post subject: Reply with quote
Hey Lads,
On behalf of Volksclub Bendigo, I'd like to invite the "Contingent" to.....
Come and enjoy all the Bendigo Easter festivity's and catch a VW show while your here Cool
Cheers,
Rhett
President
Volksclub Bendigo
Click to view image
Willo357
Willo357 is offline
PostPosted: Sun Mar 04, 2012 9:40 pm    Post subject: Reply with quote
looks cool Rhett Dancing
dragsters for life
PostPosted: Sun Mar 04, 2012 11:45 pm    Post subject: Reply with quote
sure does look good
thanks for the invite rhett, whats everyone doing easter time?
could be a great day run
Willo357
Willo357 is offline
PostPosted: Mon Mar 05, 2012 12:34 am    Post subject: Reply with quote
Every day is a great day for a run....
what about this weekend .... isnt it a long w/end?
T3 Contingent
T3 Contingent is offline
PostPosted: Mon Mar 05, 2012 1:29 am    Post subject: Reply with quote
Yep, long weekend coming up, hopefully finish up all the required welding on the square and knock over a working bee at Eccles at the same time - you down for a visit Will?
Help - Part needed
Also, we have little issue here with a dual arm steering column for a late square i just got for Pia's car. The wiper arm got snapped off in transit from Sydney ( via Aus Post with brainless packing from the seller Mad ), and after removing 3 screws, should have been 4 btw Rolling Eyes , have removed the whole indicator/wiper mechanism. Yet another wtf moment as to why the seller didn't just do that to ship Exclamation
While the majority of the steering column can still be used for the car, we need to find out if this mechansim would be compatible with what the Beetles were running of the same era perhaps, or if anyone may have one of these in a complete state to get hold of? Pics of part in need of below.
damo99
damo99 is offline
PostPosted: Mon Mar 05, 2012 3:09 am    Post subject: Reply with quote
you can find that at " pinch a part" on centre rd (imlachs)
theres a type 3 down the back of the yard .
had an excellent set of thunderbird extractors on it ($20)
vlad01
vlad01 is offline
PostPosted: Mon Mar 05, 2012 4:34 am    Post subject: Reply with quote
sure does look good
if your going to that, you all should drop by and do a photo shoot workshop christening. 16 cars please! be an awesome shot.
damo99
damo99 is offline
PostPosted: Mon Mar 05, 2012 4:45 am    Post subject: Reply with quote
forgot to mention make sure the indicator assembly has the same plug as there are a few diffrent ones(some have less or more wires going to them) in the late aussie type 3's as i have been caught out before
dragsters for life
PostPosted: Mon Mar 05, 2012 5:35 am    Post subject: Reply with quote
cheers for the heads up damo
its also jases (slammed dc) b day on the weekend
dragsters for life
PostPosted: Mon Mar 05, 2012 5:47 am    Post subject: Reply with quote
come give my car a tune up will please
T3 Contingent
PostPosted: Mon Mar 05, 2012 5:58 am    Post subject: Reply with quote
Cheers Damo, know the place, will check it out.
empitype3
empitype3 is offline
PostPosted: Mon Mar 05, 2012 11:50 pm    Post subject: Reply with quote
Check Mk 1 golf or 1303 L Bugs, think that late type 3 and golf are the same (check plug)
Bobnotch
Bobnotch is offline
PostPosted: Tue Mar 06, 2012 7:10 am    Post subject: Reply with quote
And IF the golf has intermittant wipers, that's a nice bonus. Wink
Bob 65 Notch S with Sunroof
Tram wrote:
Page 46 of 128
