Where the heck can I get these bearings in a hurry!
targetinspect
targetinspect is offline
PostPosted: Mon Mar 05, 2012 7:24 pm    Post subject: Where the heck can I get these bearings in a hurry! Reply with quote
What I need is .020" (.50mm) oversized line bore main bearings w/ oversized thrust (2.579" od, .826" thrust) - I need .010" undersize crankshaft main bearings (2.155" journal, 0.25mm undersized)
I also need a full set of .010" undersize rod journal bearings (2.155" journal, 0.25mm undersized).
CB performance doesn't have em' listed as such, I needed these 3 weeks ago! HELP!
DarthWeber
DarthWeber is offline
PostPosted: Mon Mar 05, 2012 7:32 pm    Post subject: Reply with quote
Did you check with Brother's VW Machine Shop? Rimco? AirCooled.Net?
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
targetinspect
PostPosted: Mon Mar 05, 2012 8:01 pm    Post subject: Reply with quote
eff it, I printed out a tax id # and am faxing it out to the vendors directly, Wholesale Beatches, Kustom1, CB and everyone else can pound sand, Im going direct, Thanks...
modok
modok is offline
PostPosted: Mon Mar 05, 2012 8:05 pm    Post subject: Reply with quote
odd size
pn 111-198-473OS
http://www.appletreeauto.com/VW-ENGINE/MAIN-BEARINGS/
targetinspect
PostPosted: Mon Mar 05, 2012 8:10 pm    Post subject: Reply with quote
I need 1mm on the thrust, Go figure, I wouldn't order crap from any builder that does a lign bore and crank grind but with no thrust, what were they thinking? Does no body thrust align their cases? horizontal is great but the slop can't be fixed by adding shims at the end play folks, do the math...
modok
modok is offline
PostPosted: Mon Mar 05, 2012 8:17 pm    Post subject: Reply with quote
what? do what math?
google the part number
targetinspect
PostPosted: Mon Mar 05, 2012 8:19 pm    Post subject: Reply with quote
Close size @ .040 but still wrong, who makes the .10 Thrust? I'm sure its right in front of my face somewhere, it just seems so easy, I need 20 on the case 10 on the crank and 10 on the thrust!
modok
modok is offline
PostPosted: Mon Mar 05, 2012 8:23 pm    Post subject: Reply with quote
normal thrust width is 22mm
you say you need .826, well you 'do the math" bro, that's 040, not 010
mark tucker
mark tucker is offline
PostPosted: Mon Mar 05, 2012 8:24 pm    Post subject: Reply with quote
you use a .040" thrust and cut it to fit your case, not cut the case to .040. when you cut thrust only do what it needs to clean it up.
Dale M.
Dale M. is offline
PostPosted: Mon Mar 05, 2012 8:30 pm    Post subject: Reply with quote
Why are you asking here? You took a route very few of have available to us...
Dale
targetinspect
PostPosted: Mon Mar 05, 2012 8:38 pm    Post subject: Reply with quote
Bam, Found em... My appologies... Thanks Ya'll........
targetinspect
PostPosted: Mon Mar 05, 2012 8:41 pm    Post subject: Reply with quote
@ Mark, No the case thrust is cut down on the case via the mill, I've never heard of cutting a bearing down though? Awesome...
DarthWeber
PostPosted: Mon Mar 05, 2012 8:42 pm    Post subject: Reply with quote
Who was that guy?? Shocked
targetinspect
PostPosted: Mon Mar 05, 2012 8:54 pm    Post subject: Reply with quote
Just I needed this crap to make the Phoenix Bug O Rama in 2.5 weeks... Not gonna happen this spring...
yamaducci
yamaducci is offline
PostPosted: Tue Mar 06, 2012 11:09 am    Post subject: Reply with quote
You just had about 4 or 5 of the most knowledgeable regular people here trying to help you....
Thanks for sharing.
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested.
AlteWagen
Troll
AlteWagen is offline
PostPosted: Tue Mar 06, 2012 2:06 pm    Post subject: Reply with quote
In the shop I used to work at the old man would rather cut the bearing than grind the thrust if it didnt need it. He used a small jewelers lathe and would cut oversize bearings to fit. With case prices where they are these days I would rather keep as much material on the case as bearings are disposable.
blue77bay
blue77bay is offline
PostPosted: Tue Mar 06, 2012 8:03 pm    Post subject: Reply with quote
and he is rebuilding an engine ,me thinks he needs to go to vw engines 101
I like hammers. Lots of hammers. Hammers and me go way back.
A large hammer collection is like an instant problem solver
Mark tucker wrote:,wack off as needed
mark tucker
PostPosted: Tue Mar 06, 2012 8:17 pm    Post subject: Reply with quote
@ mark hopes you have it inline or it will kill the thrust, how did you hold the caseto get it all in line? you can make a thrust cutting tool to be sure it is straight .but if your off juat a little you will have a clearance that wont stay there the bearing will move due to it not seating on the case fully& when the pressure plate pressureis applied it will deform the bearing and probably grab the crank& spin it the case .
caranage will soon insue.befor assy you might just want to take it to somebody that knows how to properly cut the thrust. just centering up in the bearing hole dont always get it, but if your good and trianglated it all to get the case inline with your collum it might work.
