Jon_slider Samba Member
Posted: Thu Mar 08, 2012 9:48 pm Post subject: Fox Shocks preliminary installation notes and review |
First installation, GoWesty 2" lift springs, with Fox Shocks on a Syncro Westy with 5cyl tdi and spare tire on gary lee rack on Driver rear, using CLK rims with 30.5" tire needs spacer, studs and front bearings also?
remove the shim on PassRear. One shim needed on DRear side only, to level the spare tire and westy closet side of the van.
Rear Trailing arms have lifted perches to help level the heavy motor. GoWesty progressive coils are compressed to touching each other, by the weight of the spare tire, motor, and westy cabinets on my 5000lb van. But the ride is excellent!
lower the front spring perch to 20" ride height if possible to reduce from current front 20.5" ride height and excess upper control arm droop that is causing tire contact
if 30.5" tires still rub front upper control arm, grind upper control arm edge, or wait for shims and run smaller wheels in the meantime.
Axle angles are all near 18 degrees,
Ride height is 20 7/8" on driver rear, lowering ride height to 20.5", or less than 17 degrees, is desireable with stock axles
Im currently loving the Fox shocks ride set to marshmallow number 3 in front, and slightly solid 4 in rear.
I really like the damping options, and the great ride, even over speed bumps. The ability to go super soft over obstacles is fantastic, can be set much softer than OMEs.. My OMEs were similar in damping to Fox at setting 4, but Fox has better dampening and better travel. For me, OME's were bottoming out, and topping out.. I dont think they could handle my wheel weight.. turns out, one each of a front and rear OME were blown, easily compressed by hand, not normal resistance or damping..
Other changes, 2" more ground clearance, huge improvement in approach and departure angles, and now my ground clearance is just 2" below my wheel centers, all great improvements
I will post a sideview of the whole van showing the wheel wells after it gets leveled and dialed tomorrow. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
photogdave Samba Member
Joined: April 05, 2004 Posts: 3173 Location: Vancouver Island, B.C.
Posted: Thu Mar 08, 2012 9:57 pm Post subject: |
Thanks for this post.
| Quote: |
| lower the front spring perch to 20" ride height if possible to reduce from current front 20.5" ride height and excess upper control arm droop that is causing tire contact |
How do you lower the spring perch? I think I need to do this as my front sits higher than the rear and my front OME shocks are topping out too. _________________ 89 Syncro GL Westfalia 2.1 WBX/WBXaustSS
My Westy Movies:
photogdave On Vimeo
photogdave On YouTube
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Thu Mar 08, 2012 9:58 pm Post subject: |
Man, those ball joints are rubbing worse then rosie o'donnell's thigs in blue jeans.
Get some spacers on.
And before/After pics of ride hight. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12422 Location: Santa Cruz, CA
Posted: Thu Mar 08, 2012 9:59 pm Post subject: |
| I wonder if Burley's upper control arms would help your rubbing and/or the ball joint touching the spring issue? I thought about that after I left. |
VWhead Samba Member
Joined: September 27, 2009 Posts: 337 Location: Pacific Grove,CA
Posted: Thu Mar 08, 2012 10:12 pm Post subject: |
Welcome to the club Jon!
| Quote: |
Syncrodoka wrote;
Burley's arms will work a lot better than those spacers
_________________ 81' Single Cab Syncro 1.8T GMW
88' 2wd Westy 1.8T GMW
www.gmwerks.com
Posted: Thu Mar 08, 2012 10:14 pm Post subject: |
Yup, it looks like they definitely fixed the upper ball joint contacting the spring issue.
must....buy....fox....shocks
Posted: Thu Mar 08, 2012 10:16 pm Post subject: |
you cant. I can because its part of the Fox Shocks front design
you need shims in the rear
> I wonder if Burley's upper control arms would help your rubbing issue?
yes, but I would rather fix the excessive width and offset of the CLK rims first. They are moving the tire inwards, closer to the the upper control arms than stock spacing.
A good temporary fix till the wheel spacers arrive would be to run smaller tires, on narrower rims, with lower offset, such as your 225x75x16's on 6" ET30 Mefros.. instead of my 245x75x16's on 7" ET37 CLK's..
did you mean the upper control arm spacers GW provides? or did you mean the wheel spacers loogy provides.
It certainly looks like the Burley arms solved the spring contact problem, thanks for the photo, it shows a lot more spring perch lift than I have, without spring to ball joint contact.., very helpful. Looks like it might not rub my bigger tire either.. not sure.. my rims and tires are different than yours.. I think I can already run your size tires and not rub the tire on the upper control arm without wheel spacers..
what is your front and rear ride height? wheel center to fender lip bottom.. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
Posted: Thu Mar 08, 2012 10:18 pm Post subject: |
| We can try my 3mm spacers and see if that is enough. They go right on without longer studs. Loogs parts, so they are legit. |
Posted: Thu Mar 08, 2012 10:42 pm Post subject: |
3mm spacers would certainly help
I checked my lug nuts, and they have 12 full turns right now.. I dont know how many turns 3mm takes up, maybe 3?, which would leave me 9 turns, and I think 7 is the minimum safe nut turns..
I still need to know how many turns a 10mm spacer will use up.. would be good to try the 3mm and get an idea..
I dont think Burleys arms will solve the offset and wheel width problem of my rims and tires..
looking at this pic,
the distance from spring to tire is tight enough that if burleys arms dont touch the spring, they are going to touch my tire..
Burleys arms are certainly nice, but the photo of the springs not touching VWheads ball joints, is with much more spring perch height. Mine would not touch at that height either..
otoh, burleys arms will probably rub my tires lower than my current stock arms rub..
imo the problem is my rims stick in too far, not my upper arms..
I also want to limit my front ride height to 20", not 21", for sake of my stock front CV's.. so I want the front spring perches as low as possible.. without the springs rubbing..
VWhead, it looks like your front spring perches are much higher than mine, I would be curious to know the dimension of the exposed threads below the perch.. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Posted: Thu Mar 08, 2012 10:55 pm Post subject: |
VWhead is running .org springs it looks like. The 2" GW springs may not let you come down any farther without hitting the front axle.
I thought that these were all made to work together? Does one have to run a big lift with those springs, the adjustable struts cannot be lowered under 21"?
VWhead Samba Member
Posted: Thu Mar 08, 2012 10:59 pm Post subject: |
That picture was when ride height was about 21.5"
I lowered the spring perch to acheive a comfortable ride height at 20.5" _________________ 81' Single Cab Syncro 1.8T GMW
www.gmwerks.com
VWhead Samba Member
Posted: Thu Mar 08, 2012 11:02 pm Post subject: |
If you want it to ride lower you could use lower springs.
These Fox shocks are also designed to work with stock syncro springs. _________________ 81' Single Cab Syncro 1.8T GMW
www.gmwerks.com
hans j Samba Member
Joined: May 06, 2006 Posts: 2746 Location: Salt Lake City UT
Posted: Thu Mar 08, 2012 11:10 pm Post subject: |
Yup I am definitely leaving what ever old suspension is on mine there until I can get those! Looks great! _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
madspaniard Samba Member
Posted: Thu Mar 08, 2012 11:14 pm Post subject: |
There is a lot of contact in that pic. I had less contact with my Burkey UCAs and Loogys 3mm spacers didn't fix it _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Thu Mar 08, 2012 11:18 pm Post subject: |
| madspaniard wrote: |
| There is a lot of contact in that pic. I had less contact with my Burkey UCAs and Loogys 3mm spacers didn't fix it |
Good to know this before wasting time trying 3mm spacers. |
Posted: Thu Mar 08, 2012 11:27 pm Post subject: |
... _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
Posted: Thu Mar 08, 2012 11:32 pm Post subject: |
| No problem borrowing the rims and tires off of the perpetual project syncro |
Posted: Fri Mar 09, 2012 12:56 am Post subject: |
| Jon_slider wrote: |
I think you are talking about 215x75x15 tire contact in a 2wd with what, 18" ride height on stock springs?..
if 3mm spacers did not fix it, Im guessing you needed to move your tires further out, with a bigger spacer.. or a smaller tire, and or a rim with lower ET, or taller springs?..
how did you end up solving it? What tire size and rim width ET or spring caused the problem, and or solved the problem..
215x70x15 tire contact in a 2wd with 17.5" ride height on syncro.org plus spring pads to level ride.
Fix: not there yet but two options, thicker spacers (don't want to do that and change even more my Rhein ET) or grinding as suggested above. I will grind away... _________________ 1991 Westy auto w/ Peloquin TBD
AnmlMthrM60 Samba Member
Joined: July 10, 2007 Posts: 228 Location: Prescott, AZ
Posted: Fri Mar 09, 2012 1:16 am Post subject: |
| Jon_slider wrote: |
Fix: not there yet but two options, thicker spacers (don't want to do that and change even more my Rhein ET) or grinding as suggested above. I will grind away... |
Interesting. My 2wd has 215/75/15 and doesn't rub. It is VERY close though. This is with the 1.5 in GW springs and ball joint spacers. My wheels are ET45 but I have them pushed back out with 15mm spacers. _________________ Justin
Posted: Fri Mar 09, 2012 8:39 am Post subject: |
.... _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
