2 Cylinder AC VW Motor?
Dale M.
Dale M. is offline
PostPosted: Sat Mar 24, 2012 8:57 am    Post subject: 2 Cylinder AC VW Motor? Reply with quote
2 cylinder AC VW motor???
http://www.oocities.org/scottjjohnson2000/enginelog/logindex.html
Think a few may get a giggle out of this....
Dale
orangesuper
orangesuper is offline
PostPosted: Sat Mar 24, 2012 9:02 am    Post subject: Reply with quote
These turn up on eBay every once in a while there is (or was) a crowd of ultralight airplane guys that would do variations this mod for a (relatively) cheap alternative to airplane specific motors. I always thought this would be a cool engine for a vw powered motorcycle although you would likely have to do a ton of preformance mods to make enough hp for it to be much fun on a bike.
Mal evolent
Mal evolent is offline
PostPosted: Sat Mar 24, 2012 9:24 am    Post subject: Reply with quote
used in the Legal Eagle:
http://www.betterhalfvw.com/
http://www.betterhalfvw.com/engine.htm
four cylinder VWs are not noted for homesick angel performance at sea level with <200 pound pilots. Put my 335 pounds in half VW on a 4600 foot elevation airfield, and you get Nothing Happening.
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
slalombuggy
slalombuggy is offline
PostPosted: Sat Mar 24, 2012 9:45 am    Post subject: Reply with quote
We had a few at the ACVW shop I worked at. One guy built half an 1835 a couple others were half 1914s. Also hada few 4cyl airplne motors with twin plug conversions. Cool stuff.
brad
clonebug
clonebug is offline
I have a set of plans for the half VW engine that i bought in the mid eighties when I was heavy into the ultralight and experimental airplane scene.
My plan actually cuts the case in half too so you don't have to plug the holes.
It's pretty cool but you need to do a bit of machining in order for it to work out nicely.
richardcraineum wrote:
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah ..
cbeck wrote:
His user name in a previous life was dick head.
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
skabonner
skabonner is offline
PostPosted: Sat Mar 24, 2012 10:47 am    Post subject: Reply with quote
Even cooler, a while back I saw a video of some guys in brazil who were welding cases together to make 6 and 8 cylinder engines. Shocked But I couldn't find any other info, other than a grainy video of one of the engines idling. Sad
Douglas Adams wrote:
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
'68 Beetle "Sadie" (R.I.P.)
'67 Beetle "Ilsa"
'06 Gti "Heidi"
Joel Mohr
Joel Mohr is offline
PostPosted: Sat Mar 24, 2012 2:07 pm    Post subject: Reply with quote
COOL STUFF!
SEE YOU AT THE RACES!!!!
JustBuggy
JustBuggy is offline
PostPosted: Sun Mar 25, 2012 12:07 am    Post subject: Reply with quote
Now THAT is one I'd like to see!!!!
Multi69s
Multi69s is offline
PostPosted: Sun Mar 25, 2012 12:47 am    Post subject: Reply with quote
Unless they are doing something I didn't see, I suspect that emgine life is short. The thrust bearing is going to be put under one hell of a load. It was never intended to actually be put under a load (prop wash). I have seen other designs where a tarnsfer case was mounted to the case to handle this load though.
Still, the project looks cool and retro
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
Boolean
Boolean is offline
PostPosted: Sun Mar 25, 2012 4:27 am    Post subject: Reply with quote
I think they extend the crank and put a special prop bearing where the pulley was before. Thrust loads are taken there.
*edit* Can't see it clearly in the photo though... I know this is done on the full VW conversions.
mondshine
mondshine is offline
PostPosted: Sun Mar 25, 2012 1:00 pm    Post subject: Reply with quote
Lots of interesting stuff out there....
markhuebbe
markhuebbe is offline
PostPosted: Tue Mar 27, 2012 6:43 am    Post subject: Reply with quote
That's how my full VW engine is in my airplane. The 1/2 VWs normally don't need the bigger bearing and just use a stock bearing. The thrust loads aren't that high to require it.
Also, you can cut the case in half to save even more weight. My father had over 1000 hours on his 1/2 VW and it ran great.
1970 Beetle - Rally car
http://www.Rally-America.com
http://www.HuebbeRally.com
torsionbar
torsionbar is offline
PostPosted: Tue Mar 27, 2012 8:08 am    Post subject: Reply with quote
looks like suicide to me. you won't get me into any airplane powered by one of those things! a lycoming, sure, but not a hacked up beetle motor.
Max Welton wrote:
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed.
Michael Fischer
Michael Fischer is offline
PostPosted: Tue Mar 27, 2012 8:41 am    Post subject: Re: 2 Cylinder AC VW Motor? Reply with quote
Dale
Giggle?
I have been wanting to try this for a long time. People I have talked to claim 70 plus miles to the gallon.
markhuebbe
PostPosted: Tue Mar 27, 2012 8:45 am    Post subject: Reply with quote
The Beetle motor has been successfully used for millions of hours in experimental aircraft since the 60s.
wompninja
wompninja is offline
PostPosted: Tue Mar 27, 2012 8:46 am    Post subject: Reply with quote
I don't get the point, wouldn't this just make the engine run a lot rougher than it already is?
Pics of my 1970 Satin Black Type 1 build
View user's profile Send private message Visit poster's website Twitter Instagram Gallery Classifieds Feedback
Michael Fischer
PostPosted: Tue Mar 27, 2012 8:47 am    Post subject: Reply with quote
You get the point now? Laughing
wompninja
PostPosted: Tue Mar 27, 2012 8:49 am    Post subject: Reply with quote
Yeah, I don't buy it. If you are so worried about mileage and you want a two cylinder engine why not use a v-twin out of a Honda motorcycle?
wompninja
PostPosted: Tue Mar 27, 2012 8:50 am    Post subject: Reply with quote
Not to mention cutting the already too small 40hp in half... good luck driving that on the road.
Michael Fischer
PostPosted: Tue Mar 27, 2012 8:58 am    Post subject: Reply with quote
So you have tried it?
Or you are just rich and don't care? Laughing
