freddie89 Samba Member
Joined: November 20, 2010 Posts: 39 Location: Leicester, England
Posted: Sat Apr 21, 2012 11:10 am Post subject: Split shell on later chassis? |
Another question for the experts...
I am considering putting my 51 shell on a 64 chassis for the time being until I can find time to restore the orginal chassis propperly.
Also planning on running pretty low and dont fancy flatting pans on the 51 chassis.
What work is needed to fit a 51 bug shell on a 64 bug chassis?
Thanks
Freddie |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1290 Location: IRELAND
Posted: Sat Apr 21, 2012 11:50 am Post subject: |
| if your 51 runs lever shocks you`re gonna run into problems with the lack of any shock tower recesses in the rear inner arches. |
Posted: Sat Apr 21, 2012 12:39 pm Post subject: |
Sorry to sound dumb but whats a lever shock?
Cheers!
Freddie |
Posted: Sat Apr 21, 2012 12:40 pm Post subject: |
Only pic i have or rear inner arch...
mandraks Samba Member
Joined: November 28, 2004 Posts: 7124 Location: Lawrenceville, Ga
Posted: Sat Apr 21, 2012 12:43 pm Post subject: |
Freddie,
just crawl under the back and see if you see any shocks and shock towers.... i f you don't you have lever shocks, pretty much a friction kind of deal  _________________ regards
Uli
splitjunkie Samba Member
Posted: Sat Apr 21, 2012 1:09 pm Post subject: |
even if you have the telescoping shocks you will still have problems. The shock towers on a split are much shorter than on a '64 so it would involve cutting the body and adding reinforcing plates. _________________ Chris
eurodub Samba Member
Posted: Sat Apr 21, 2012 2:05 pm Post subject: |
just try and see for yourself!!
wherever the pan hits the body, cut parts from the pan
joking! _________________ 1960 1200 model 117 deluxe ragtop
1976 MK1 Golf |
Herbie3Rivers Samba Member
Joined: May 07, 2001 Posts: 1271 Location: Pittsburgh, PA
Posted: Sat Apr 21, 2012 4:42 pm Post subject: |
I've seen it done. A friend of mine had a 51 on a 64 pan and it worked fine. It was done years before he got it and restored the car and it worked fine. He drove it ass his daily driver. _________________ Yeah I like Herbie AND New Beetles. Got a problem with it? Tough.
2010 New Beetle Final Edition
2009 Ford Mustang Bullitt
1999 New Beetle GLS
1983 Mercedes 300D
1974 Karmann Ghia
1972 Super Beetle
1970 Beetle Sunroof
1959 Original Herbie #6
1956 Oval
Three Rvers VW Club
Pittsburgh Vintage Grand Prix
Visit Herbie the Love Bug at LoveBugFans.com |
VWKDF Samba Member
Posted: Sat Apr 21, 2012 8:24 pm Post subject: |
| Herbie3Rivers wrote: |
| I've seen it done. A friend of mine had a 51 on a 64 pan and it worked fine. It was done years before he got it and restored the car and it worked fine. He drove it ass his daily driver. |
51 is when they stopped lever shocks, so it's still 50/50 chance till he checks this car. |
Posted: Sun Apr 22, 2012 5:14 am Post subject: |
| VWKDF wrote: |
lever shocks or not, it does not matter. The body is the same on the lever shock and telescoping '51. The '64 shock towers are taller than the shock towers on a '51 pan so the body will need cutting. _________________ Chris
xeno Samba Member
Posted: Sun Apr 22, 2012 5:42 am Post subject: |
Here is mine...
You either have to cut the body or the tower... I choose to cut the 62 pan rather than to cut the 52 body...
_________________ Currenlty Corralled:
1952 Crotch Cooler Deluxe (US specs delivered to Stuttgart, Germany GI.)
1955 Early (Competition Motors - Hollywood, California)
1974 Thing (US specs - Mexicanos)
2008 Rabbit S (Wolfsburg DE)
2012 Golf TDI Tech Package (Wolfsburg DE) |
Posted: Sun Apr 22, 2012 12:44 pm Post subject: |
good picture. That shows it exactly. _________________ Chris
split bug boab Samba Member
Joined: April 18, 2009 Posts: 12 Location: Arbroath, Scotland
Posted: Sat May 05, 2012 2:58 pm Post subject: |
| xeno wrote: |
Here is mine...
I wil be doing the same thing with my 52 (when i get back to work on it). When you cut the chassis, where does the top of the shock mount to? Do you have a pic of the shock in place?
Cheers
Boab |
xeno Samba Member
Posted: Sat May 05, 2012 4:26 pm Post subject: |
I have the OG 52 pan, just using the 62 pan to transport the 52 body around while I get some things done to the pan/body.
I think a person could fab up something pretty quick. Maybe a bolt going through the hole in the tower with spacers??? I saved the tower tops to be welded back on if I decide to "restore" the 62 pan.
Another issue would be the 62 front end clears the 52 body but leaves no room for the bolt to pass trough top shock tower. (So the bolt end would rub the body because there is no cut out.) _________________ Currenlty Corralled:
ratlook63 Samba Member
Joined: November 10, 2003 Posts: 347 Location: Pittsburgh Pa.
Posted: Tue May 29, 2012 2:12 pm Post subject: |
My 51 shell is on a 54 chassis. Body was cut by a PO though. I think Ill just roll it as is ..... _________________ ‘60 SWR walk-thru Kombi
‘60 Mango Standard
‘66 EZ Camper |
Wannasplit Samba Member
Joined: February 18, 2009 Posts: 30 Location: Maryland, USA
Posted: Thu May 31, 2012 8:13 am Post subject: |
I don't see a problem with it. Honestly it's all a matter of perspective. Sure, a split shell on a somewhat later pan is not and never will be 100% original.
But consider this; one of the most covetted VW's in the world is the VW38 found in Lithuania.....yet practically nothing on that car is original.
The only difference is a gentlemen's agreement that the Lithuanian VW 38 is so important a car that later parts or reproduction parts were given some sort of Papal Dispensation and therefore the car is a 1938 VW.
Yet to some folks a split built 15 years later on a later pan isn't the real deal.
Interesting, huh?
Shadd Samba Member
Joined: January 18, 2007 Posts: 883 Location: Lancaster, Ohio
Posted: Thu May 31, 2012 2:27 pm Post subject: |
| Wannasplit wrote: |
...Yet to some folks a split built 15 years later on a later pan isn't the real deal.
Interesting, huh? |
Unfortunately that group of folks is known as the B.M.V.
Since the title follows the pan and not the body, legally what you will have is a 1964 beetle with a split window body. Most people take this into account when they buy a car which is why a split body on a later pan is not worth nearly as much as the "real deal"
That being said, if I had a split body laying around you can bet your ass that I would mount it on a later pan and drive it until I could afford to restore it. |
xeno Samba Member
Posted: Sat Jun 23, 2012 11:08 am Post subject: |
PO job.
What not to cut, when putting it on a new pan:
leeezard7 Samba Member
Joined: November 13, 2011 Posts: 262 Location: oklahoma
Posted: Sat Jun 23, 2012 11:56 am Post subject: |
| Shadd wrote: |
| Wannasplit wrote: |
Interesting, huh? |
my 52 split is on a 70's pan and the title follows the body on my car. the vin tag in the nose of the car has the id numbers on it. |
xeno Samba Member
Posted: Sun Jun 24, 2012 1:51 pm Post subject: |
| leeezard7 wrote: |
Your case is unique then. _________________ Currenlty Corralled:
