decklid spring
c.j.
c.j. is offline
PostPosted: Sat Apr 21, 2012 6:25 am    Post subject: decklid spring Reply with quote
I took my engine lid springs off to paint them and now putting them back in is a pain. Is there a trick to getting them back in? Do I take off the lid to install the springs?
Disc
Disc is offline
PostPosted: Sat Apr 21, 2012 6:30 am    Post subject: Reply with quote
Just push harder!
Trunk springs have a trick - there is a bolt that stops open trunk lid, remove is put springs in place, close trunk lid a bit and screw bolts in place. But engine lid springs must be pushed harder in place! First install engine lid, make gaps equal, make it close and latch properly and finally install springs.
The glory never gets old, just need new paint.
Nick
c.j.
c.j. is offline
PostPosted: Sat Apr 21, 2012 4:44 pm    Post subject: Reply with quote
I have a 68. It has different hinges than the early ghias.
lemke
Samba Troll
lemke is offline
PostPosted: Sat Apr 21, 2012 6:55 pm    Post subject: Reply with quote
I don't think this is exactly the issue you are having - but here is some useful information from The House of Ghia Website - thanks Mike!
http://www.house-of-ghia.com/index.php?option=com_...p;Itemid=4
c.j.
c.j. is offline
PostPosted: Sun Apr 22, 2012 9:28 am    Post subject: Reply with quote
They're back in. Put the spring in the holes then pushed the top back down in the slot. Real tuff resistance but like you said push harder. thanks
16CVs
16CVs is offline
PostPosted: Fri Jan 20, 2023 8:36 pm    Post subject: Re: decklid spring Reply with quote
Does anyone know id Ghia decklid springs are the same as a Beetle or are they different and if so what s the difference.
Car is 74 Hardtop Ghia rebuild from an engine fire.
Stacy
Samba member # 14980
