RAMZROD Hammered™ Apparel
Posted: Fri Apr 20, 2012 3:28 am Post subject: |
Hell Yeah, your bus looks sweet!! Congrats bro! Major transformation from when I first laid eyes on your bus. Sick, sick, sick!!! See you at the Piquete this Saturday??  _________________ |o\®/o|
Bus Build Page |
Sidbus Samba Member
billybob57 Samba Member
Posted: Mon Apr 23, 2012 11:27 am Post subject: |
Love your Panel!!!!! great that its back on the road...mine will be that way one day too!!! very nice Mate!! _________________ "It is what it is"
55 Panel
56 Double Door |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71956 Location: Phoenix 602
Posted: Mon Apr 23, 2012 11:50 am Post subject: |
| Sidbus wrote: |
| Were there two sizes for rearview mirror mounts? My bus's threaded holes are wider apart than the holes in the mirror. I haven't found any on classifieds or repros w/wider holes so trying to figure out if a previous owner did a modification at some point or if there's a different mirror the early 57 takes. |
Panels didn't come with mirrors so it was probably some random mirror a previous owner installed. _________________ How to Post Photos
Sidbus Samba Member
Posted: Mon Apr 23, 2012 2:24 pm Post subject: |
| EverettB wrote: |
| Sidbus wrote: |
Panels didn't come with mirrors so it was probably some random mirror a previous owner installed. |
Ok so looks like I'm drilling or maybe I'll copy a mount that goes under fresh air vent panel that I recently saw on an so34 which apparently also lacked a rearview mirror. thanks. _________________ 57 Panel http://www.thesamba.com/vw/forum/viewtopic.php?t=453943
62 so34 http://www.thesamba.com/vw/forum/viewtopic.php?t=533160
76 Westy http://www.thesamba.com/vw/forum/viewtopic.php?t=520076 |
Sidbus Samba Member
Sidbus Samba Member
Sidbus Samba Member
Posted: Fri May 25, 2012 8:19 pm Post subject: |
Two nights work:
Repaced all missing/loose hubcap clips
Redid front wire harness. Discovered the ground screw was touching running light bulb holder and causing short which also burned up my running light wire so had to replace.
Installed new decklid brakelight w/new reproduction lens and housing from samba classifieds. way way way better than the one I originally bought which turned out to be a painted clear lense that shined a pinkish-clear hue and the housing turned out to be a few running light bulb holders soldered together. Now I understand the sarcastic comments I received when I posted pics of my "original" decklid. Live and learn.
Marked/drilled my door panels and then found out a PO must have widened the screw holes in the doors so I was not able to install. Also I cracked (beyond repair) the driver's side headliner so hopefully I can get a replacement from Clara. Now I need to figure out a way to attach using bigger screws...hopefully the nice polished bezels will still fit.
I put the bulkhead divder in so it's a lot quieter in the cabin now. Not sure I'll be able to put my son in the back for any long trips...It is loud :2gunfire:
Having a blast driving it around Miami! _________________ 57 Panel http://www.thesamba.com/vw/forum/viewtopic.php?t=453943
ccb_dan Samba Member
Joined: August 03, 2009 Posts: 321 Location: Cocoa Beach, FL
Posted: Sat May 26, 2012 4:25 am Post subject: |
| That little video made me smile! Bus is DOPE! Congrats! |
Sidbus Samba Member
Sidbus Samba Member
Sidbus Samba Member
dmuis Samba Member
Joined: September 01, 2004 Posts: 381 Location: Sunny Alberta, Wild Rose Country.
Posted: Sun Jun 03, 2012 8:06 pm Post subject: |
| Nice video! Looks super! |
Sidbus Samba Member
ricekooker Samba Member
Joined: April 09, 2006 Posts: 1792 Location: Sanford, FL
Posted: Fri Jun 08, 2012 7:27 pm Post subject: |
| When is the subhatch getting some love? Oh BTW, put the seat down before your Wife yells at you. |
Sidbus Samba Member
Sidbus Samba Member
Posted: Sun Jun 10, 2012 4:30 am Post subject: |
| Loved the A1A video! |
Sidbus Samba Member
Posted: Mon Jun 11, 2012 7:08 pm Post subject: |
Finally got the interior door panels on. Thank you Clara, they look amazing!
Somewhere along the line someone enlarged the screw holes but I was able to find a wider screw with a flat head that sat flush with the little bezel. Store only had philips head but I like the way they look. Still have some work to do w/fresh air vent and under dash and then I'll install the other panels. Clara does really nice work.
Also, started having a problem with the front brakes not releasing. Ronnie (Splitpile) informed me that the 67 master cylinder comes with a residual valve that can cause this problem. I removed the valve and Miguel (aircooledhead.com) bled the brakes and viola, problem solved.
Met my wife and son at the neighborhood park later in the evening.
Sidbus Samba Member
