Considering third brake light.
Page: Previous  1, 2, 3  Next
ashman40
ashman40 is offline
PostPosted: Mon May 21, 2012 3:47 am    Post subject: Reply with quote
Eric&Barb wrote:
Just wire into the brake wire junction in left rear engine compartment where all the wires connect from the taillights to the wiring up front.
If you go with an interior 3rd light, run your wire down to the VR area under the left rear seat. The main harness that runs from the front to the rear passes through this area on the way to the rear. If you can find the black/red wire that runs from the brake switches you can tap into it with a splice and you are good to go. If you are unsure, use your test lamp (the one with the needle sharp tip). Ground the loose end of the test lamp and poke into the black/red wire while you step on the brakes (with key in ON position). If you have the correct wire the test lamp will light up!
AshMan40
mondshine
mondshine is offline
PostPosted: Mon May 21, 2012 12:41 pm    Post subject: Reply with quote
I use the Model 38 Hella center brake light which can be purchased from Daniel Stern Lighting;
http://www.danielsternlighting.com/products/products.html
I believe Daniel Stern is the only source for this item in the US.
Manufactured by Hella in New Zealand, it is a very nice quality piece; much nicer than the usual Chi-Com stuff. I made the electrical connection behind the driver's side trim panel in the back seat.
Also located there is the WebElectric BLP-1 Universal Brake Light Pulser Module. The BLP-1 pulser module connects to the center high mount brake light and automatically pulses it when you apply your brakes. The light will pulsate on and off for about a second, then stay on steady for as long as you press the brake pedal. The unit is designed to create a gentle fluttering of light, so your car is more noticeable, yet it doesn't aggravate the driver behind you. The "Delay-Repeat" circuit means the brake lights have to be off for at least 15 seconds before the cycle can be restarted. So, if you are in bumper-to-bumper traffic, the brake light isn't always pulsing.
Good luck, Mondshine
JerryMCarter1
JerryMCarter1 is offline
PostPosted: Mon May 21, 2012 12:51 pm    Post subject: Reply with quote
there is also a product that will allow the third brake light to triple flash each time you step on the brakes -- $20.00 on the net
Experience always triumphs over hearsay and You get to select which theory to believe
Willhelm
Willhelm is offline
PostPosted: Mon May 21, 2012 2:36 pm    Post subject: Reply with quote
Wow, some great info here! I picked up a pair of 12" red LED strips to mess around with. I really like that Hella unit. If it had been on display I would have grabbed that!
Willhelm
Willhelm is offline
PostPosted: Sun May 27, 2012 8:37 am    Post subject: Reply with quote
So here is the project in it's entirety. The pics pretty much tell the story. If you only have something crappy to say, please save it and just post your own superior work. I worked to the best of my abilities and it does what it is required to do. LED strips from Auto Zoned, the bracket was made from free discarded steel banding. I picked up the power next to the voltage regulator as mentioned by Ashman. Thank you everybody for the advice and recommendations.
1
2
3
4
5
6
7
8
9
10
11
12
13
13
14
15
16
17
18
JerryMCarter1
PostPosted: Sun May 27, 2012 12:01 pm    Post subject: Reply with quote
Man ----you knocked it completely out of the PARK ! ! ! !
Wow
love it - I need to get started on one for my vert !
Nepenthe88
Nepenthe88 is offline
PostPosted: Sun May 27, 2012 12:13 pm    Post subject: Reply with quote
WOW!! I don't know why anyone would have anything bad to say about that, it's gorgeous, and kicks the ass of MY craptastic 3rd. Nice thought process on the gusset by the way. I prob woulda left it out, got pissed when the bloody thing flopped all around like a bobble-doll like and ripped it out Laughing
a Black & Blue Su-BUS-aroo
Follow my adventures in the GoWAND'RLoST bus on Instagram:
https://www.instagram.com/gowandrlost/
CarlIseminger
CarlIseminger is offline
PostPosted: Sun May 27, 2012 1:12 pm    Post subject: Reply with quote
Does anyone have examples of a third brake light on a 'vert? I can see putting the Hella version in the window, so when the top is up you have the light, but what about when we drive with the top down?
Oh, and by the way, great work Willhelm. Using your head and spare parts to create something wonderful like that.
JerryMCarter1
PostPosted: Sun May 27, 2012 1:34 pm    Post subject: Reply with quote
Here we all thought you were some sort of a nerd ! Very Happy
PaRacer
PaRacer is offline
PostPosted: Sun May 27, 2012 5:17 pm    Post subject: Reply with quote
Here's mine - Trucklite led mounted inside. You don't even see it until you step on the brakes.
'73 Standard "Sunshine"
Willhelm
Willhelm is offline
PostPosted: Mon May 28, 2012 7:05 am    Post subject: Reply with quote
Thanks all. If nothing else let it inspire. I'm happy the thread grew into something so useful. The contributors here posted some really good information about options and wiring. Hopefully it comes up for people doing a search, I know all my questions where answered. Thanks again for the help and kind words.
68IHscout
68IHscout is offline
PostPosted: Mon May 28, 2012 7:20 am    Post subject: Reply with quote
hey take it easy we are not done with you here ,..I have to get in my two cents worth ,...that is some very creative well done work , and it looks great , one question , on the pic inside looks like there is glare on the glass from the light if so what you doing to direct the light just straight back ...
Redvolk65
Redvolk65 is offline
PostPosted: Mon May 28, 2012 7:40 am    Post subject: Reply with quote
here is mine not bad for $5.00 dollars
next
Willhelm
Willhelm is offline
PostPosted: Mon May 28, 2012 8:53 am    Post subject: Reply with quote
Ha! I thought I was getting off too easy. Smile Yes there is some glare on the rear window. It really does not trouble me, in fact it tells me the brake lamps are working which is good to know and I wondered about sometimes. I'm not really a frequent night time driver so for me I won't have to worry too much. Crossover and SUV headlights are my pet peeve. If I can put up with that in my rear view mirror a little red glare is a minor inconvenience. You make a good point though. I reckon one could go a step further and make a shroud but I opted for simple. I admire all the cool solutions people are posting. Seriously though, it is what it is. I'm going to leave the post alone. Awesome if others want to add to it.
JerryMCarter1
PostPosted: Mon May 28, 2012 9:23 am    Post subject: Reply with quote
The research has been conclusive and verified internationally to the point that every car maker has them- Apparently tail lights are not at eye level and people can see that third light quicker -which can save lives !
Jerry
Nepenthe88
PostPosted: Mon May 28, 2012 1:06 pm    Post subject: Reply with quote
Jerry
This is exactly why I put a 3rd on, and why I mounted it high. Everyone today seems to be driving SUV's might just as well have something closer to their height, so that they can see you (especially if they're tailgating!!). (ps, I'm also gonna go back and add a link to this in my build thread in case anyone's trolling thru and looking for ideas, cause there's some really good examples here! Kudos all!!)
68IHscout
PostPosted: Mon May 28, 2012 5:22 pm    Post subject: Reply with quote
After what Jerry Mc poste d I am inspired to come up with something of my on creatio n(like the (O P) Very Happy
JerryMCarter1
PostPosted: Mon May 28, 2012 5:39 pm    Post subject: Reply with quote
I will build one for my vert in late Sept -- for sure
Jerry M. Carter
cferry7
cferry7 is offline
PostPosted: Mon May 28, 2012 6:14 pm    Post subject: HISTORIC Vehicle Reply with quote
Hi Willhelm -
Thanks for the information concerning NY Police or NY Vehicle
Mechanical Lighting Violation Law's.
I feel fortunate that in states MD, VA, NC I've been stopped for Lighting on my Beetle in the past, they have always been very considerate - most times only a Verbal Warning.
Brings up interest about the Historic Vehicle Mechanical / Lighting
/ Operation Laws ?
1st : ' 71 Super , 1641 cc , ~ Stock - a keeper !
2nd: ' 70 Standard , Totaled 7-14-01 , R.I.P.
68IHscout
PostPosted: Mon May 28, 2012 6:41 pm    Post subject: Re: HISTORIC Vehicle Reply with quote
cferry7 wrote:
Hi Willhelm -
/ Operation Laws ?
lighting ?? Like a burned out bulb ????or for the lack of a third light???
Page 2 of 3
