DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7542 Location: Whittier,CA
Hot Air Samba Member
Joined: February 25, 2007 Posts: 672 Location: Baltimore, Maryland
Posted: Wed May 23, 2012 5:12 am Post subject: |
Well I just installed the center mount set up. Still need to get some stackes and rebuild it. I am just not sure who to send it too.here are some pics.
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img] _________________ 73' Bug
85' Porsche 911 Carrera 3.2 |
esde Samba Member
Joined: October 20, 2007 Posts: 6381 Location: central rust belt
Posted: Wed May 23, 2012 5:52 am Post subject: |
| If that's a shortened buggy you could probably swap jets without leaving the driver seat! Looks perfect for the buggy, be interested to hear how it runs. If the carb isn't too dirty, could you do with a soak, blow it out, and overhaul kit yourself? |
Posted: Wed May 23, 2012 6:59 am Post subject: |
| Hot Air wrote: |
| Still need to get some stackes and rebuild it. I am just not sure who to send it too. |
Send it to Mark Harney http://www.carburetorclinic.com/
For velocity stacks see my post above or let Mark take care of it. _________________
| Mitey62 wrote: |
| Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
| RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum.  |
Posted: Wed May 23, 2012 9:41 am Post subject: |
Thanks for the info Darthweber, I sent a pm to him..I also found ACE ( air cooled engineering) they had great feedback also. So we will see what they say, Thanks again got my fingers crossed .
You were correct on the 28 venturies. _________________ 73' Bug
Posted: Thu May 24, 2012 7:26 am Post subject: |
Is there a number for Mark Harney http://www.carburetorclinic.com/ I would like to talk to him, I hate typing what I have to say If it is possible. _________________ 73' Bug
