Disc Samba Member
Joined: September 24, 2009 Posts: 633 Location: Europe
Posted: Sat Jun 02, 2012 5:35 am Post subject: Is this a split clock? |
!!! THE CLOCK IS NOT FOR SALE!!!
This clock is a gift to my boss from his friend with another bigger dash mounted ('55 - oval?) clock. My boss was told it is '47-'48 clock but not sure. Clock is hand wind up from behind, approx. 50 mm. in diameter, with all original parts and working, was mounted on a chromed plate for table use since many years. It's not VDO clock, may be ZF of or ZE? What is correct use of this clock?
I've found simmilar, but VDO clock in Ebay.
Click
More info about that clocks will be good Thanks!
_________________ The glory never gets old, just need new paint.
Nick |
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6606 Location: Downingtown, PA
Wiggy Samba Member
56reddy Samba Member
Posted: Sat Jun 02, 2012 7:30 am Post subject: |
This is the clock that I have. The face looks identical, but the rear winder looks different. Maybe my clock is a later model. _________________ New Vintage Specialist.
1974 ghia convertible
1981 Vanagon Westfalia
Making VW’s Fun Again.(MVFA) |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2550 Location: Australia
Posted: Sat Jun 02, 2012 5:38 pm Post subject: |
The clock in the OP appears to have raised dots at each hour. Is this correct or an optical illusion?
The clock shown above appears to not have these dots, and the thickness of the numbers are finer on the OP's clock. _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
Suboval Samba Member
Posted: Sat Jun 02, 2012 5:57 pm Post subject: |
IN2VWS wrote: |
The clock shown above appears to not have these dots, and the thickness of the numbers are finer on the OP's clock. |
Raised dots is correct. _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9408 Location: Northwood, NH USA
Posted: Sat Jun 02, 2012 7:53 pm Post subject: |
IN2VWS wrote: |
Don't you mean that the numbers on the clock above are *thicker* than the OPs clock? Looks that way to me.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Sat Jun 02, 2012 8:02 pm Post subject: |
There are definate differences in the faces upon closer inspection. My clock has thicker font and non-raised dots. I was under the impression that my clock was 1951-52 clock. _________________ New Vintage Specialist.
IN2VWS Samba Member
Posted: Sat Jun 02, 2012 9:25 pm Post subject: |
johnshenry wrote: |
IN2VWS wrote: |
Don't you mean that the numbers on the clock above are *thicker* than the OPs clock? Looks that way to me.... |
Yeah......thats what I said, didn't I? _________________ ( ⫏ ⫐ )
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
IN2VWS Samba Member
Posted: Sat Jun 02, 2012 10:04 pm Post subject: |
The user =Petri Nut*1= also has one the same as the OP's clock.
The VDO catalogs list both the VW and Tempo versions as having luminous dots.......but it doesn't list them as being for a split Bug. The clock that would go in a split bugs glovebox lid would be 60mm.....wouldn't it?
IMG_0013 by IN2VWS.INFO, on Flickr
IMG_0014 by IN2VWS.INFO, on Flickr _________________ ( ⫏ ⫐ )
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
Posted: Sat Jun 02, 2012 10:24 pm Post subject: |
IN2VWS wrote: |
The VDO catalogs list both the VW and Tempo versions as having luminous dots................... |
That would explain the dots and the extra paint(?) on the ends of the two clock hands. _________________ It all works on paper.
IN2VWS Samba Member
oval53/split52 Samba Member
Posted: Mon Jun 04, 2012 12:27 am Post subject: |
IN2VWS wrote: |
It depends on the glovebox lid. Perohaus glovebox doors has got 60mm holes, and the more common version used in split-dash-Karmann-Kabs got holes that will fit 52 mm gauges. _________________ http://outlavws.blogspot.com |
IN2VWS Samba Member
Posted: Mon Jun 04, 2012 5:43 am Post subject: |
oval53/split52 wrote: |
IN2VWS wrote: |
It depends on the glovebox lid. Perohaus glovebox doors has got 60mm holes, and the more common version used in split-dash-Karmann-Kabs got holes that will fit 52 mm gauges. |
Thanks.
Is the Perohaus version the same as the Happich version? The Happich version has the round horn grills mounted to it. _________________ ( ⫏ ⫐ )
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
Posted: Wed Jun 06, 2012 4:22 am Post subject: |
I assume you are refering to the aftermarket Happich version found in catalogues from the 50ties?
Perohaus version looks like this:
http://www.thesamba.com/vw/classifieds/detail.php?id=425540
ACO like this:
http://www.thesamba.com/vw/classifieds/detail.php?id=57017
And Karmann factory-delivered-look like this. There are different kinds of locks for these. (Happich) Some of these are probably period aftermarket.
http://www.thesamba.com/vw/classifieds/detail.php?id=412545
IN2VWS wrote: |
IN2VWS wrote: |
Thanks.
Is the Perohaus version the same as the Happich version? The Happich version has the round horn grills mounted to it. |
IN2VWS Samba Member
Posted: Wed Jun 06, 2012 3:57 pm Post subject: |
I assume you are refering to the aftermarket Happich version found in catalogues from the 50ties? |
Yes. The Happich and the Karmann versions look the same to me.
I have a set that came with my split, and they accept a 60mm clock.
So, is the Karmann version nearly the same as the Happich version, with the exception that the horn grill is 52mm?
I found some clearer pics for reference.
IMG_0450 by IN2VWS.INFO, on Flickr
1950 catalog
1953 catalog
1953 Happich catalog
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
