c21darrel Samba Member
Joined: January 22, 2009 Posts: 8246 Location: San Dimas
Posted: Thu Dec 08, 2011 2:25 pm Post subject: What's this Ghia part and Where does it go? |
I searched and suprised to find we dont have a thread with this question for all the things we (I) didnt document when removing.
Been 3 years since I removed these..they look familiar but..
Where do these go on my '68 Coupe??
Mod Edit: Not a bad idea for a Sticky. Don't forget to add the date of your Ghia and if it's a Coupe or Convertible. |
Disc Samba Member
Joined: September 24, 2009 Posts: 638 Location: Europe
Posted: Thu Dec 08, 2011 3:07 pm Post subject: |
This is remains of door alignment wedge:
_________________ The glory never gets old, just need new paint.
Nick |
Posted: Thu Dec 08, 2011 4:43 pm Post subject: |
| Awesome Disc, Thanks. They were in the bag w/ door stuff too, guess my organization isnt completely crap afterall. |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 4167 Location: In Molinya Orbit
Posted: Wed Dec 14, 2011 2:16 pm Post subject: |
Obviously it would sense that the staight part would be at the bottom of the hump, the split towards the back wall...and im guessing it wont fit there correctly...
Have you tried calling the maker of your carpet kit? Wish I could be more help. |
golfvt1 Samba Member
Posted: Sun Apr 22, 2012 10:15 am Post subject: hose to air cleaner |
| Where does this hose go to?? I have a stock air cleaner. Larger diameter hose, one end goes to the bottom front of the air cleaner, hose goes under the air cleaner to??????? Thanks in advance. |
Posted: Fri Apr 27, 2012 10:23 am Post subject: |
| ^^^Year? A pic wuold help to. |
ghia-13 Samba Member
Posted: Sun Jun 24, 2012 10:46 am Post subject: |
I have a 69 ghia and I'm opened up the motor i bought to figure out all the things i need to replace. Everything is perfect, but this thing popped out once we opened up the actual case. Its a 1600cc dual port engine.
Here is a pic of it, Hopefully someone can guide us on where it goes.
When it fell out, only thing left was the case and in the case, the rods, cam, crank, but no other components. |
Altema Samba Member
Joined: June 20, 2010 Posts: 2907 Location: Lower Michigan
Posted: Sun Jun 24, 2012 11:22 am Post subject: |
That is the cam plug. It seals the cam hole on the flywheel end of the case.
Altema Samba Member
Posted: Sun Jun 24, 2012 11:28 am Post subject: Re: hose to air cleaner |
| golfvt1 wrote: |
For a '73 Ghia, you will have a small hose that connects to the oil breather on the generator stand, and a large hose that connects to the preheater duct which collects warm waste air from the behind cylinders 1 and 2, and feeds it to the air cleaner. The duct should be between the pulley and the right heater hose.
Paul |
Posted: Sun Jun 24, 2012 10:41 pm Post subject: |
| thanks altema!! so on the cam where you have the gear aswlel it goes on opposite side of the cam where the opening is, to just cap off? |
Altema Samba Member
Posted: Mon Jun 25, 2012 1:28 am Post subject: |
| ghia-13 wrote: |
That is correct. The raised edge of the plug fits in the groove of the case with the flat side facing out.
Paul
Posted: Sat Jun 30, 2012 9:40 am Post subject: |
I'm stuck again guys, I'm putting the motor back together (seems to be such a pain getting the freaking crank/cam to sit perfect and we finally got it all done and put the pistons/cylinders and all in. We realize that there's a hole and I'm PRAYING i don't have to open the case to put something through this hole. It says in the book that it must be tightened first, but we don't have it..?
the hole to the right closest to the flywheel |
Posted: Sat Jun 30, 2012 8:48 pm Post subject: |
nvmd we figured it out now we're stuck wondering how it fits to put the distributor gear into the engine. theres a dot on it that we think we need to line up somehow hoping someone knows:) |
Posted: Mon Jul 02, 2012 12:40 pm Post subject: |
| you need to be at TDC on #1 first. need at least 2 greased dist shims. then drive gear, spring, then dist, look at the off center drive on bottom, align. do not counter rotate motor with out all in. I would familurize myself with the whole process or have someone knowledgable around. It can be a super simple process, parts might go in without issue...or you can mess up the gears on your crank and split the case... dont ask how i know. good luck. |
Posted: Fri Aug 31, 2012 10:53 pm Post subject: |
Alrighty guys finally back at it and should have the motor fully done by tomorrow.... This is the metal rod that goes in with the fuel pump. We don't remember if it goes in with the point end towards the motor or towards the pump. The two books we have to assist us covers up exactly where we'd need to see in the image.. and the writing doesn't mention that detail. Hope one of you know Thanks in advance!
EverettB  Administrator
Joined: April 11, 2000 Posts: 72023 Location: Phoenix 602
Posted: Sat Sep 01, 2012 8:32 am Post subject: |
| Thanks! Just out of curiosity, how did yours bend and brake the plastic?? |
arnold.mike1976 Samba Member
Joined: January 08, 2012 Posts: 1 Location: HALLSVILLE, TX
Posted: Thu Oct 04, 2012 7:32 am Post subject: |
| I had that happen to mine too the guy at Oak Hill Automotive "The Bug Shop" said the wrong push rod was installed with the fuel pump I had. I replaced the push rod and now it runs great. It's nice to have people that know the Classic VW's. |
