metal and glass fuel filter warning
jrny99
jrny99 is offline
PostPosted: Mon Jul 16, 2012 5:50 am    Post subject: metal and glass fuel filter warning Reply with quote
This is a heads up for everyone who might use this type of fuel filter.
the threads caught only enough to catch and appear tight. when I tightened it it seemed to be stripped. while starting up one morning on the way to work I smelled gas. the filter was leaking like a stuck pig. i figured the plastic had to go and this one looked bullet proof. bought a metal one piece and I feel much safer. thanks for the post I read here concerning plastic fuel filters.
Cadaver
Cadaver is offline
PostPosted: Mon Jul 16, 2012 6:19 am    Post subject: Reply with quote
think about safety 1st
compatibility with the damn E10 ethanol. (avoid china plastics)
then compatibility with German 5mm lines (if still present?)
the filtering effectiveness
SAE J905 (tested) comes in the box pressure tested too.
safety.
how will does it work in a collision, steel wins hands down. no competition.
then the micro filter size, smaller is better. (wiz makes one )
then the fit. to the hoses. ?
if it falls off, with the clamps,. removed ,its no freaking good.
use clamps,
do not put 1/4" lines in the bug, and over stock nipple barbs .
its way too loose.
btw , those screw threads in there are way too course. IMO.
i like this one.
its not expensive, (why should it?)
http://www.summitracing.com/parts/WIX-33031/
keep in mind 1/4" is 6.25mm it may be tight on stock lines.
cjmck422
cjmck422 is offline
PostPosted: Mon Jul 16, 2012 5:26 pm    Post subject: Reply with quote
Been there, done that. Had an instant barbecue one night in my driveway. Had the fire out in about a minute or so. Lost all the rubber hoses, engine harness and ignition wires. Nothing that couldn't be repaired.
Chris
1971 Super Beetle
Luis ''Diablo'' Gutierrez
Luis ''Diablo'' Gutierrez is offline
PostPosted: Mon Jul 16, 2012 11:52 pm    Post subject: Reply with quote
my bug had one when i got it, mine was clear plastic not even glass
mexikanischen-deutsch
67'
68'
69' bugs
PostPosted: Mon Jul 16, 2012 11:57 pm    Post subject: Reply with quote
67'
68'
69' bugs
Q-Dog
Q-Dog is offline
PostPosted: Tue Jul 17, 2012 6:20 am    Post subject: Reply with quote
I've been running a glass filter since the mid 80s with no issues. But mine does not have plastic ends like that piece of crap in your photos.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
jrny99
jrny99 is offline
PostPosted: Tue Jul 17, 2012 6:41 am    Post subject: Reply with quote
just tryin to save lives . . .
70autostick
70autostick is offline
PostPosted: Tue Jul 17, 2012 9:50 am    Post subject: Reply with quote
I run a plastic filter right next to my carb, just gotta make sure the clamps are tight, been doing it this way for years. Those autozone glass filters with the plastic ends are junk, i removed one off a baja i purchased last year and smashed it, just to eliminate any temptation to save it.
Daily driven 1972 beetle, no more 70autostick
TjdTaylor
TjdTaylor is offline
PostPosted: Tue Jul 17, 2012 10:11 am    Post subject: Reply with quote
i use the cheapie 99 cent plastic filters. Dont even have a bard to keep them held onto the line (use use hose clamps). I keep my filter behind the firewall though so no worries.
1974 SuperBeetle Build
Beetle Bums VW Club Member
Jamies74sb wrote:
I can't see myself cutting up my super beetle . Maybe a oval or 61 or so with the small windows
Cadaver
Cadaver is offline
PostPosted: Tue Jul 17, 2012 5:58 pm    Post subject: Reply with quote
the less fuel parts next to
the sparking dizzy, that sparks at 6 nodes in side.
and the fuseless , coil #15 wire that love to short and burn the better.
it likes to short, then melt the the red hot wire falls and hits that silly
plastic filter, and then it melts, kills lots of bugs that way.
one way is to remove the ballast resistor or shunt it, certain coil burn up and short. and fire.
glass has no business in a fuel system. in the dark ages.
we had fire wall mounted glass fuel filters ,but in a accident they explode
and burn everthing up.
some carbs had glass float bowl windows. (lots of mazda's and others)
ever wonder why , not now? lots of dead bodies...
some plastic is weak too, if hell bent on plastic
keep it where gas squirting has some hope, like to the pavement.
be safe. please.
just because you did something unsafe for 20 years, don't make it safe.
ask a tow truck driver some time. he will tell you.
even Russian roulette is safe 5 times. , some times... but what does that matter.?
Cerot
Cerot is offline
PostPosted: Tue Jul 17, 2012 11:40 pm    Post subject: Reply with quote
I had that same filter (I think I got it from CIP1?), I was messing with my carb one day and the exact same thing happened, one end came unscrewed and dumped gas out, luckily car wasnt running it just spilled what was in the filter. My friend with a 69 beetle was not so lucky, his split at engine start up and had a minor car-b-que. My father also used one he bought at a local store on his 69 GTX, guess what? Luckily it happened when the car was off. I now tell everyone I know to steer well clear of those abominations.
dubllyou
dubllyou is offline
PostPosted: Wed Jul 18, 2012 12:29 am    Post subject: Reply with quote
I learned the lesson on those several years ago too. Mine was on a '59 Ford pickup where somebody had obviously "prepped" it for paint with the gas cap off. I thought I'd get this cool filter that I could take apart and clean as the paint plugged it up. It didn't take many times being taken apart before the threads stripped on that cheap-ass piece of pot metal crap.
It wasn't too much later I realized it was gonna take a looong time to filter all the paint out of the gas tank and maybe it might be better to pull the tank...
Ahhh, to be young and stupid again... Rolling Eyes
Two wrongs don't make a right...
three lefts do.
Wade
vwo60 wrote:
You cannot polish a turd, but you can roll it in glitter.
dubllyou
dubllyou is offline
PostPosted: Wed Jul 18, 2012 12:42 am    Post subject: Re: metal and glass fuel filter warning Reply with quote
I'm surprised they're even still around after 25+ years. And they even added more fail points! Mine at least had one-piece ends with pot-metal fittings... Confused
three lefts do.
Wade
fred69vert
Location: Home of the US Navy Atlantic Fleet, Norfolk, VA
fred69vert is offline
PostPosted: Wed Jul 18, 2012 10:45 am    Post subject: Reply with quote
Some idiots use these on their BOATS!!! Look at what I found at West Marine......
http://www.westmarine.com/webapp/wcs/stores/servle...sNum=50370
I'm not losing my hair, it's just retired and relocating further south.
1969 VW convertible, "Heidi"
dubllyou
dubllyou is offline
PostPosted: Wed Jul 18, 2012 11:02 am    Post subject: Re: metal and glass fuel filter warning Reply with quote
jrny99 wrote:
Stomp on that thing and post another pic!
Evil or Very Mad
Very Happy
three lefts do.
Wade
jrny99
jrny99 is offline
PostPosted: Sun Jul 22, 2012 2:01 pm    Post subject: Reply with quote
I reviewed the filter on the site and they never posted it....maybe I was a little to negative. hmm Very Happy
jrny99
jrny99 is offline
PostPosted: Tue Jul 24, 2012 5:45 am    Post subject: Re: metal and glass fuel filter warning Reply with quote
dubllyou wrote:
Evil or Very Mad
Very Happy
hope ya like it Smile
dubllyou
dubllyou is offline
PostPosted: Tue Jul 24, 2012 9:11 am    Post subject: Reply with quote
Another one bites the dust!
Thanks, that's at least two down. I trashed mine a long time ago.
Very Happy
three lefts do.
Wade
mschulze
mschulze is offline
PostPosted: Tue Jul 24, 2012 10:17 am    Post subject: Reply with quote
I've run one of these..all metal though...for several years and several changes with no problems or leaks. Everything doesnt have to be axel-nut tight. Sorry to hear about the bad luck of others though.
1971 Superbeetle
1963 Deluxe
1973 Superbeetle
