64 sundial. What do you think?
Page: Previous  1, 2, 3 ... , 13, 14, 15  Next
Jeff Power
Location: with any luck, in my garage building bass guitars.
Jeff Power is offline
PostPosted: Fri Apr 20, 2012 6:52 am    Post subject: Reply with quote
This bus is one of my favorites.
I build complete Westy Style camping interiors check them out here > www.rjcampers.com
Check out my basses here www.ellabasses.com
jerry wrote:
Nothing says "I love busses" more than picking up a mouse turd filled with horse hair seat padding
Busryder
Samba SuperHero
Busryder is offline
PostPosted: Fri Apr 27, 2012 4:48 pm    Post subject: Reply with quote
Well guys.... I have some bad news to report.
The effort to reach the Madera show this weekend, has been abandoned.
This is due to broken bleeders, and a lack of time to invest... Confused
This is all that I have the authority to comment on at this juncture... Dan will respond once he has the time off from work.
But seriously, all that's left is the brake pluming, and to wire the coil... fine tune the motor, and the carb... and an hour at most.
I/we did try though.... but Jedi luck was not on our side of the Force for this trip.
But....
Sorry Dan-Dan..... Crying or Very sad
Lind wrote:
Apparently I was just the lucky asshole that showed up at the right time.
I am a Dick, hear me roar- Laughing
Me, an OVP Lifer...
drumming123
drumming123 is offline
PostPosted: Fri Aug 03, 2012 11:41 am    Post subject: Reply with quote
After a long hiatus, I am back. I finished up the shift rod, which was giving me never ending problems, and now have 4 forward gears and 1 reverse gear.
I went to bleed the brakes today, and ran into a problem. Me and a partner were bleeding the brakes with the 'him pumping and I watch the fluid come through the clear plastic hose' method and everything seemed fine. After the air was out of all the lines, there still appeared to be no pressure at the pedal. Where did I go wrong? Dual circuit master cylinder, wheel cylinders, hard and soft lines are all new. Confused
busdaddy
busdaddy is offline
PostPosted: Fri Aug 03, 2012 12:07 pm    Post subject: Reply with quote
Did you adjust all the brakes before bleeding?
Слава Україні!
drumming123
PostPosted: Fri Aug 03, 2012 12:30 pm    Post subject: Reply with quote
The rear two yes, front are discs.
drumming123
PostPosted: Fri Aug 03, 2012 4:20 pm    Post subject: Reply with quote
I didn't know the bleeder valves had to be over the brake lines... Embarassed
Needless to say I took care of that. They still feel spongey, I'll have to go through and bleed them all again I suppose. Anyway, took her for a cruise around the block for the first time in at least 6 months. I've got a lot of bugs to work out, but it felt good to make some progress.
Here is a short video whipped together on my iPhone.
Busryder
Samba SuperHero
Busryder is offline
PostPosted: Fri Aug 03, 2012 9:51 pm    Post subject: Reply with quote
Applause Applause Applause Applause
I wish I could've helped out earlier in the week... but I have Life working against me too.... all apologies, my VW brethren Wink .
BTW: How'd you 'bench-bleed' the master cyl? If done correctly, you could've solved your own "squishy-ness" on your master cylinder.... before you posted this problem, brother-bear.
Just a thought...
Me, an OVP Lifer...
cru62
cru62 is offline
PostPosted: Fri Aug 03, 2012 10:26 pm    Post subject: Reply with quote
Dan-You do know the fronts need to be bled also, even though they are discs, right? That may explain some of the squishyness. The bleaders on those need to be as high as possible also.
And what is with the test drive? There were absolutely NO sparks or gouges in the asphalt. And you just cruised into your driveway. I thought you were going to slam that thang. Rolling Eyes
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Busryder
Samba SuperHero
Busryder is offline
PostPosted: Fri Aug 03, 2012 10:34 pm    Post subject: Reply with quote
Laughing Laughing
And I thought that I only saw 1 headlight too...
Me, an OVP Lifer...
Jeff Power
PostPosted: Sat Aug 04, 2012 5:01 am    Post subject: Reply with quote
Dont have much to add other than my compliments.
Did I mention I love this Bus!!
drumming123
PostPosted: Sat Aug 04, 2012 4:58 pm    Post subject: Reply with quote
Just a thought...
I didn't bench bleed the master cylinder.. I didn't know I had too.. Whoops.. Embarassed
I bled the front as well, just the top bleeder valve on one calliper was snapped off.. So instead of trying to spend all day getting that bleeder out, I removed the calliper, flipped it upside down to bleed it, then bolted it back on.. That was made my pedal go from hitting the floor, to having pressure.. Still didn't have complete stopping power though.. hmm..
And the test drive did goudge the driveway.. I just removed all the sound because all you could hear was the noisey electric fuel pump. Very Happy
The ride around the block was WAYYYY smoother than I was expecting.. plenty of suspension travel and it is nice and soft, like I'm floating..
Yeah yeah yeah.. I gotta get another Laughing
Thanks Jeff! I love this bus too.. haha
quartermilecamel
quartermilecamel is offline
PostPosted: Sat Aug 04, 2012 5:15 pm    Post subject: Reply with quote
Are you sure the floating wasnt from your mind in a vw induced high driving your bus around the block?
Waiting for santa to drop off funky green. I can wish can't I????
cage66
cage66 is offline
PostPosted: Sat Aug 04, 2012 6:58 pm    Post subject: Reply with quote
Awesome job Dan.
Looks great. Shit is SLAMMED!
Best thing I did bleeding wise was a simple gravity bleed.
Raise the front up and crack the furthest valve and put a tight tube on the valve into a can then let it sit for a few hours. Checking the fluid in the reserve often. It may take longer to fully bleed out but this has worked best for me.
a1steaksauce
a1steaksauce is offline
PostPosted: Sun Aug 05, 2012 6:49 pm    Post subject: Reply with quote
glad to see this is back!
enjoyed your work on this and i love the video of her cruising around the block.
drumming123
PostPosted: Sat Aug 25, 2012 10:36 pm    Post subject: Reply with quote
Found em' trying to hot rod my bus down the street, but he couldn't get the key right, so he asked me for help.
Busryder
Samba SuperHero
Busryder is offline
PostPosted: Sat Aug 25, 2012 11:41 pm    Post subject: Reply with quote
Busryder wrote:
Applause Applause Applause Applause Applause
Send my LOVE to the boy man... good job Dan-Dan!
http://www.thesamba.com/vw/forum/viewtopic.php?p=6226600&highlight=send#6226600
Me, an OVP Lifer...
RPGreg2600
RPGreg2600 is offline
PostPosted: Sat Jan 05, 2013 6:18 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=1412624
Why?! Confused
Salvarican
Salvarican is offline
PostPosted: Sun Jan 06, 2013 4:17 pm    Post subject: Reply with quote
My thoughts ^^^^^
I just finished reading this whole build. Bad ass thread. True inspiration.
drumming123
PostPosted: Sun Jan 06, 2013 4:31 pm    Post subject: Reply with quote
Why?! Confused
I lost interest I suppose.. The first year of ownership I busted my balls on it and putting all kinds of hours into it and think I just burnt myself out. This last year I've done practically nothing with it. I got it registered about a month ago in hoped that it would motivate me to get some use out of it, but it didn't. I drove it once and it went back to its parking spot. Sad I think I enjoy the hunt and the build more than actually utilizing it. I'm pretty happy with the way it turned out, and for being as low as it is, it drives incredibly smooth.
It just sold this morning. The new owner showed appreciation for the bumps and bruises the bus has and has led me to believe he will keep it as such. Cool
This is the car I've held onto the longest though, 2 years. Haha
I'll be back one day when I hunt down another Smile
LAGrunthaner
LAGrunthaner is offline
PostPosted: Sun Jan 06, 2013 4:48 pm    Post subject: Reply with quote
That's OK drumming123 we will look forward to your next project Cool
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Page 14 of 15
