Engine to Carb to Distributor
andihowe
andihowe is offline
PostPosted: Thu Sep 06, 2012 3:23 am    Post subject: Engine to Carb to Distributor Reply with quote
Hi All,
I know this has been covered a hundred times, and then some but for a 1972 1300 beetle what carb and distributor should I have to be stock?
A link to the old posts would be jsut as good!! Just tried searching but cant find diddly... just one of those days I guess.....
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Thu Sep 06, 2012 4:39 am    Post subject: Reply with quote
On a 1300 twin port beetle, standard shift, in 1972, it was a 31PICT-3 carburetor. The originals used that year had base flange numbers VW 360-1 or VW 360-2. Used a 113905205AL distributor.
If you can open MSWord document files, my "master chart" of carbs and distributors can be found here:
https://www.thesamba.com/vw/archives/info/glutamodo/temp/CarbBaseFlangeNumbersA.doc
-Andy
andihowe
andihowe is offline
PostPosted: Thu Sep 06, 2012 5:48 am    Post subject: Reply with quote
Brilliant thanks.
andihowe
andihowe is offline
PostPosted: Thu Sep 06, 2012 5:50 am    Post subject: Reply with quote
When you say base flange numbers, where would I find those?
The Android
PostPosted: Thu Sep 06, 2012 6:28 am    Post subject: Reply with quote
Just across from where the throttle cable attaches. It's actually a "modification state number" as VW had many versions of any given carburetor, for different applications, different countries, different emissions, etc.
Here's some examples:
Cadaver
Cadaver is offline
PostPosted: Thu Sep 06, 2012 9:35 am    Post subject: Reply with quote
i have to pinch my self when Glutomodo post. nothing but perfect.
the document is gold.
solves many mystery.
for sale now.
in Samba classifieds....1968 T1.
andihowe
andihowe is offline
PostPosted: Fri Sep 07, 2012 2:22 am    Post subject: Reply with quote
Brilliant Thanks. Just need to get that bl**dy garden bench out the garage so I can get the engine and carb!
Joey
Joey is offline
PostPosted: Fri Sep 07, 2012 6:22 am    Post subject: Reply with quote
I couldn't agree more. He has been a BIG help to me. A great asset to these forums for sure.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
