type3 to type 1 empi dipstick adapter fit issues? (pic)
Kommercial
Kommercial is offline
PostPosted: Tue Sep 18, 2012 9:18 pm    Post subject: type3 to type 1 empi dipstick adapter fit issues? (pic) Reply with quote
Anyone have trouble with these? Mine is at least 3 inches off of where it should come through the german tin hole next to the pulley. A friend put one on 20 years ago and I remember his had the same issue. No evidence of being bent. Should these match up to original tin? Tube angle matches the angle of the hole where it is drilled through the base plate of the part. I'm guessing bending it would cause the dipstick not to fit and the epoxy around the tube base to crack.....
R.C.N. Bugs
R.C.N. Bugs is offline
PostPosted: Wed Sep 19, 2012 1:58 am    Post subject: Reply with quote
in the middle of the same problem and i did crack the epoxy i dont know what to do either
Jody '71
Jody '71 is offline
PostPosted: Wed Sep 19, 2012 3:40 am    Post subject: Reply with quote
Been some 30 years since I owned a type 3, but that doesn't look like an adapter, more like the regular tube for a type 3. If it were an adapter, shouldn't the tube go straight up and pass through the pulley tin hole? Why not ask the type 3 guys on their forum here??? Are there any more pics of this application in the Gallery???
'66 Beetle
2011 Hyundai Elantra Touring
mxracer
mxracer is offline
PostPosted: Wed Sep 19, 2012 5:56 am    Post subject: Reply with quote
I suspect that is a "nice try" at an adapter.
The Type 3 oil fill comes off the case and has about a 5 inch "bend" to the right. That wouldn't work in a Type 3 either.
Have you thought about just having the case machined for a "correct" Type 1 dipstick tube? Looks like it would be easier in the end.
That or drill a new hole in your breast plate and run it. Confused
Keith
Keith is offline
PostPosted: Wed Sep 19, 2012 8:18 am    Post subject: Reply with quote
Its an adapter. The type 3 tube is about an 1 1/4" i.d. and has about a 90 degree bend in it. An upright dipstick would fall right in it handle and all. A type 3 doesnt use an upright style dipstick instead it has a large twist cap like a small gas cap with the dipstick connected to it because the dipstick tube is also the oil fill tube. I made my own adapter just like this for a conversion I did.
Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind
R.C.N. Bugs
PostPosted: Mon Sep 24, 2012 10:52 am    Post subject: any one Reply with quote
any one else can help with this issue
Kommercial
PostPosted: Wed Sep 26, 2012 1:35 pm    Post subject: Reply with quote
Ok so my workaround was to heat up the epoxy with my mapp gas torch and the tube pulled right out. Then I clamped the adapter base into my vice and drilled straight down into it with my drill press. Slid the tube back in and since I drilled right on the drill depth, the dip stick is still at the same height. A little epoxy around the base and I'm in business.
R.C.N. Bugs
PostPosted: Wed Sep 26, 2012 6:00 pm    Post subject: Reply with quote
so all you did is change the angle it was originally drilled at??? i drilled the tin. i know i hacked it. and still jb welded the dip stick so it dosnt leak
Kommercial
PostPosted: Wed Sep 26, 2012 6:08 pm    Post subject: Reply with quote
Yes
mxracer
mxracer is offline
PostPosted: Wed Sep 26, 2012 6:52 pm    Post subject: Reply with quote
That's not a workaround that's a fix. Very Happy
Nice work.
R.C.N. Bugs
PostPosted: Wed Sep 26, 2012 7:26 pm    Post subject: Reply with quote
good work now i know.
houseofboyd
houseofboyd is offline
PostPosted: Tue Dec 02, 2014 5:19 am    Post subject: Reply with quote
Nice job...I'm facing the same situation right now...would rather try to modify the tube/adapter than to modify the tin.....thanks for the heads up....
Our 1968 Zenith Blue Beetle: http://www.thesamba.com/vw/forum/viewtopic.php?t=619501
My '74 SB Build On The Samba: http://www.thesamba.com/vw/forum/viewtopic.php?t=609943
Our Web Site: http://www.kentuckyhotwheels.com
1968 VW Beetle
2012 Turbo VW Beetle
grandpa pete
grandpa pete is offline
PostPosted: Tue Dec 02, 2014 9:58 am    Post subject: Reply with quote
Another idea is leave the original tube and bend the flexible hose straight up...secured in place with tye wrap
66 sedan delivery with type 3 engine
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
