Studt's 73 Samba Member
Joined: April 09, 2010 Posts: 145 Location: Pacific, Missouri
Posted: Thu Jul 26, 2012 10:04 am Post subject: |
Did some work over the past weekend, just been to lazy to upload the pictures. I was able to get the top-hats and frame in the cargo painted up before I started putting down the floor. I was also about the get the section of floor put in and started on the second. Things are starting to move along pretty quickly now, at least I hope so. I'll try to get some pictures up by the end of this weekend, with the progress from that as well. _________________ Got YJ |
Posted: Mon Jul 30, 2012 6:34 am Post subject: |
Here are some of the newest pcitures. All the top hats in, sanded, and frame is prepped.
Painted the top hats and frame.
First section of cargo floor going down. I've got a lot of holes to weld up.
It's coming along.
Next section going down.
It's finally starting to look like it should. Still have one section on the floor behind the drivers seat that needs to be taken care of.
Posted: Thu Sep 27, 2012 9:07 am Post subject: |
A little update, and pictures to come. I've been working hard on our Bus for the past couple weekends. The cargo floor is now completely installed, and primed. Man it does feel great to finally have a floor in the bus. We're now moving on the front of the bus, and what hopes to be the final stage of the "body" repair. Today I ordered the remaining parts, windshield repair panel, front floor pan, left & right front inner wheel arche repair panels, left & right front inner step, and left & right outter step. I seem to be getting back into wanting to work on the bus lately. After doing so much repair, wondering if it will ever get, wondering what the hell I've gotten into, and even thinking about walking away from this project. I can now see the end in sight, and will hopefully have her painted this winter. The wife wants it painted this fall, but I'm no miracle worker. I'll try to get some pictures up of the progress I've made. _________________ Got YJ |
Pinetops Samba Member
Posted: Thu Sep 27, 2012 11:12 am Post subject: |
That's great to hear that you are in the home stretch on the body work. Like I said before, I think you've done too much to back out now. Earlier in the thread you mentioned painting it with rustoleum, which I've done myself. My suggestion is that you should use real car paint on this bus if you can. I think you've put too much work into it so far to do a cheap paint job.
A decent paint job will be nothing compared to the work you've done already. Rustoleum is fine and it will protect the metal and everything but the durability is not in the same league as real car paint. Don't get me wrong, it is impressive for what it is. All in all though, a roll on job is actually more work than a spray job because of all the hours of wet sanding you'll have to do to get it flat. Since you have it apart, go ahead and do it right. If you want to make it simple you could do a single stage paint or maybe something like the hot rod flatz line, the flat paint will help hide imperfections.
Either way, great job on your bus and I'm looking forward to your futher progress. |
Posted: Fri Sep 28, 2012 8:39 am Post subject: |
| stuco wrote: |
| My suggestion is that you should use real car paint on this bus if you can. I think you've put too much work into it so far to do a cheap paint job. |
Yeah, we do plan on getting good paint, and using cheap paint. On a down side to getting new part. Bus Depot has NOT come through once again. I seem to get email after email saying they do not have parts in stock. But, they can get them from one of their venders, for an extra shipping charge. Halfway tempted to cancel the entire order with them and go to someone else. The main thing is the front floor pan, but I've found it from Cip1, and for a little less money as well. We'll see what happens. _________________ Got YJ |
Posted: Mon Oct 01, 2012 6:55 am Post subject: |
Made some progress this weekend, to bad my progress is so slow. I'm trying to tie up the loose ends on the cargo floor. Had to pull up the center section between the front seats due to rust. Who would of thought, rust on my bus. From my understanding this is, or in my case was a vent. After I cut up that section out, removed what was left of the tube that supplies the air. There was a metal elbow on the back of this box that the hose connected to, but that was it. I crawled under the bus and found another round metal duct with a cable controled gate in it. But where does this go, where do I tie in the air supply? I'll try to get some pictures up of what I'm talking about, but here is the progress I made on this section.
The center section is removed, and the passenger side of it is gone due to rust.
I capped of the drivers side.
Since the passengers side was completely gone. I had to build a box that fit into the opening that matched how the other side was. Without having a metal brake, that meant lots of cutting and welding.
Both sides in place, and the new lower section is welded in as well.
Another shot of it welded in.
The back welded on. I still need to cut a hole to supply the air, but I can do that at a later time.
Another shot of it.
I must say, this bus and this forum have thought me so much. I came into this project with no fabricating skiils, and no knowledge about VW's. Because of this forum, and all the great people on it. I still don't know much about VW's, but I do know a lot of body work. Thanks to all the help from everyone, and the support. _________________ Got YJ |
Posted: Mon Oct 01, 2012 11:41 am Post subject: Heating help |
I'm not sure what the box is actually called, but it's what I'm currently working on. I found this diagram, which shows me everything I'm currently missing.
Just pass #4, where the tube curves up and vents into the cargo area. Where can you find these parts? _________________ Got YJ |
Posted: Wed Dec 05, 2012 3:28 pm Post subject: |
Really haven't been able to get anything done on this. I've had some parts on order with Bus Depot for 10 weeks now, and still no product. _________________ Got YJ |
chrisradioman Samba Member
Joined: September 20, 2007 Posts: 4872 Location: Swansea (Sunny Penllergaer) Wales UK
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon Dec 31, 2012 1:22 am Post subject: |
keep it up! looking good.
did you ever figure out the engine you have? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Jan 21, 2013 8:21 am Post subject: |
I haven't even messed with the engine as of yet. I was hoping to have the engine out already, but things have been going slower on the bus then I'd like. We're still hoping to have her running and on the road this summer. _________________ Got YJ |
Posted: Fri Apr 19, 2013 10:34 am Post subject: |
Found some time this weekend to show some love.
Passenger side
Passenger side
Driver side
Posted: Fri Nov 07, 2014 11:26 am Post subject: |
I have zero updates on the bus. I'm actually selling this project on the 15th. I simply don't have time to complete it anymore, and don't want it sitting around rotting. _________________ Got YJ |
Posted: Fri Nov 07, 2014 3:55 pm Post subject: |
206-841-7324
[email protected] |
Posted: Tue Nov 11, 2014 7:16 am Post subject: |
| Stuartzickefoose wrote: |
At least it's going to someone who plans on finishing it. _________________ Got YJ |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22696 Location: Escondido CA
Posted: Tue Nov 11, 2014 9:33 am Post subject: |
Hey. You did a lot to further this bus. All that back breaking grubby rot cutting metal work can make the best of intentions crumble. I wouldn't of done it. Im glad to see that you accomplished what you did. Sorry you didn't get to experience the pay off. _________________
| t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
