nada Banned
Posted: Mon Oct 08, 2012 6:26 pm Post subject: Connecting Rod is too wide for crankshaft |
I'm building and upright engine for my bay. It has a stock 1600 case, 74mm stroke, and stock 85.5 bore. I started building it up and got to the point where I was going to attach the rods. When I went to attach the first rod, I found that it was too wide to fit.
Here is a picture of the rod.
I measured the inside width of the crankshaft and it was roughly .902" then I measured the outside of the connecting rod - roughly .930". Is this a commonly found problem? I am prepared to purchase new rods if that is necessary. I just found it to be very strange. _________________ Until they're all restored... |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1333 Location: south san francisco
Posted: Mon Oct 08, 2012 8:38 pm Post subject: |
?????????? strange. the crank is about normal. those rods are WAY wide? i measured a few i have and there no where near that wide? get another set of rods. or take the time to machine them to fit? not a normal problem. |
modok Samba Member
Joined: October 30, 2009 Posts: 27680 Location: Colorado Springs
Posted: Mon Oct 08, 2012 8:41 pm Post subject: |
where did you get those rods? |
GDOG57 Samba Member
Joined: March 19, 2006 Posts: 1066 Location: Gilbert,Arizona
Posted: Mon Oct 08, 2012 10:55 pm Post subject: |
Are you sure they are not type 4 rods? _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red) |
nada Banned
Posted: Tue Oct 09, 2012 4:04 pm Post subject: |
They very well could be Type 4 rods! I bought them attached to a supposedly 1600, 69mm crank, but they guy who sold it to me could've been wrong. I only paid 25 for the crank and rods, no big deal. What's odd is that it is setup for a Type 1 engine. I don't know the differences between a Type 1 crank/rods, and a Type 4. _________________ Until they're all restored... |
modok Samba Member
Posted: Tue Oct 09, 2012 4:49 pm Post subject: |
I think all type4 and WBX use a larger piston pin size..........right? that should be a dead giveaway
I donno man, better check the size of both ends and the length before you think about narrowing them, and if you do try to narrow then so the bearing is centered. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Tue Oct 09, 2012 6:39 pm Post subject: |
Doesn't look like a T4 rod to me, but it's hard to tell without a full pic. I have a set of recon Bus 2.0 rods in the garage, they are visibly beefier than that one. A lot heavier too.... _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
nsracing Samba Member
Posted: Tue Oct 09, 2012 7:20 pm Post subject: |
China rods from hell.
Waterboxer rods are same on the bigend as Type I..cept larger on the pin end. |
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1872 Location: Grass Pants, Orygun
GDOG57 Samba Member
Posted: Tue Oct 09, 2012 10:33 pm Post subject: |
Type 4 rods are .127 inches wider than type 1. _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
Slow 1200 Samba Member
Posted: Wed Oct 10, 2012 3:34 am Post subject: |
40hp rods? |
anthracitedub Samba Member
Posted: Wed Oct 10, 2012 5:42 pm Post subject: |
^. X2 |
modok Samba Member
Posted: Wed Oct 10, 2012 9:29 pm Post subject: |
Oh, yeah, I bet your right! 40hp are wider
Don't they use rod bolts instead of bolts and nuts? |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Wed Oct 10, 2012 9:49 pm Post subject: |
Slow 1200 wrote: |
40hp rods? |
First thing I thought of too. They can be resized by taking ~.020" off each side - but the pins are only 20mm - won't fit the pistons. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
nada Banned
Posted: Fri Oct 12, 2012 9:23 am Post subject: |
The crankshaft is not a crappy Chinese one to my knowledge. I've always heard of SCAT making nice parts. And I decided to not mess with machining rods and just went ahead and bought new ones since they weren't too expensive. Thanks for clearing up what the parts I had belonged to! _________________ Until they're all restored... |
1432 Samba Member
Posted: Sat Oct 13, 2012 7:15 am Post subject: |
OLD VW NUT wrote: |
Slow 1200 wrote: |
40hp rods? |
First thing I thought of too. They can be resized by taking ~.020" off each side - but the pins are only 20mm - won't fit the pistons. |
also shorter and much weaker than 1600 rods |
