Redbarnresto Samba Member
Posted: Wed Oct 10, 2012 11:12 am Post subject: Blown Engine, And How! |
Thought you guys might like to see this. This engine came out of a Bus a customer of mine bought. He never saw it running. We were hoping it'd be a perfectly good little engine, but were prepared for the worst. We sure got it!
The engine would spin back and forth but not 360 degrees. It'd spin maybe 330 degrees one way or another and then smack into something. I pulled the valve covers off and noticed that none of the valves open and close at all, they were all just dead level with each other and wouldn't move. I knew that could mean only one thing.
I started tearing the engine apart and found #4 rod up through the case, which the fan shroud was hiding.
Here's what's left of #4 connecting rod. Both nuts are still on!
Damage to the crank.
The camshaft, or should I say camshafts?
The entire case is filled with this stuff.
This is interesting. All the intake valves are black except that one that was on #4.
Not sure what happened first that caused all this, but I'm sure some of you will have theories. The oil was very low (though it could have been sitting for years and dripped out), and there was also no front engine tin which would have made the engine run hotter than usual. There was one of the six main case nuts missing, and some of the others were loose.
Definitely the worst failure I've seen!
Dan _________________ Red Barn Restorations |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5669 Location: On an island in VA
Posted: Wed Oct 10, 2012 12:17 pm Post subject: |
That is intersting that it was the #4 that let go. If it was the #3 it would be more understandable..... |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Wed Oct 10, 2012 1:12 pm Post subject: |
Picture was NO big deal for me as I've seen loads of them during my engine building yrs....comes with the territory.
One part fails or lack of oil and KABOOM. |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Wed Oct 10, 2012 2:22 pm Post subject: |
Thank you for a perfect picture of what I always tell people. Stock connecting rod bolts DO NOT BREAK. The rod itself will come apart before the bolt will.
Sorry about the engine though  |
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2700 Location: sacramento
Posted: Wed Oct 10, 2012 2:36 pm Post subject: |
spun rod bearing, rod got too hot and bam. Heads actually look pretty good _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
JoeD Samba Member
Posted: Wed Oct 10, 2012 3:12 pm Post subject: |
Yes spun rod bearing. Obvious in the photo. It burnt pretty badly. |
modok Samba Member
Joined: October 30, 2009 Posts: 27699 Location: Colorado Springs
Posted: Wed Oct 10, 2012 4:51 pm Post subject: |
#4 is the most common rod bearing to go out first. i don't know why, we'll probably never know exactly what started this one to go either, all the incriminating evidence has destroyed itself
Of course, it was probably just low oil pressure. |
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Wed Oct 10, 2012 5:09 pm Post subject: |
I love tearing into exploded engines, as long as they are someone else's. That looks like it was in an engine blow contest, about par for my experience with bus engines especially type 3. |
75smith Samba Member
Posted: Wed Oct 10, 2012 5:10 pm Post subject: |
modok wrote: |
huh, interesting I was talking with my dad today and we got on the subject of rod bearings and he said he see's the #3 or #1 go most often _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
Posted: Wed Oct 10, 2012 9:25 pm Post subject: |
#1 bearing is the one i've seen spun the most. _________________ 71 Super - Backroad Thrasher
modok Samba Member
Posted: Wed Oct 10, 2012 9:28 pm Post subject: |
Maybe it depends what caused it? |
1432 Samba Member
Posted: Sat Oct 13, 2012 7:22 am Post subject: |
modok wrote: |
oil delivery problems usally affect #1 & 4 rods first due to shared oil feed thru single passage at center main. |
