MARKYSTEW Samba Member
Posted: Tue Nov 20, 2012 5:01 am Post subject: 1915 40IDF Jetting |
Hi
Could someone give me a starting point for jet and venturi sizes for:
1915
40 IDF's
engle 120
CB round port heads 40X35
1.25 rockers
55cc cylinder volume
8.5-1 compression
38mm headers
it's a weekend fair weather car (62 beetle) not a race car so am looking for driveability rather than top speed. I live at sea level in the U.K.
Thanks |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2373 Location: Mount Airy, Maryland
Itisa1835 Samba Member
Joined: September 02, 2011 Posts: 123 Location: Norco
Posted: Tue Nov 20, 2012 11:50 am Post subject: |
Main jet -135-140 Air correction 190-200 |
modok Samba Member
Joined: October 30, 2009 Posts: 27687 Location: Colorado Springs
Posted: Tue Nov 20, 2012 7:06 pm Post subject: |
Could use 30mm or even 32mm venturies
with the 30 vent try 125 main and 200 air
with the 32 vent probably need 135 main and 200-220 air |
Posted: Wed Nov 21, 2012 3:40 am Post subject: |
Thanks Modok +Itisa1835
Do I need to change the idle jet(.50), starter jet(80F5), and emulsion tube(F67) or will these work ok?
The carbs are 40 IDF 83 which I believe come from an Alfa or Fiat |
modok Samba Member
Posted: Wed Nov 21, 2012 4:59 am Post subject: |
If you are not planning to use the starter system then it does not matter what size the starter jet is.
I have never encountered an f-67 emulsion tube.
That changes things......... these webers may be very different than what we have in the US, thus what works for US, may not work for you.
These f-67 emulsion tubes may work well,........... but I have no idea what jets or vents they will work with.
If you want to jet it like our "american" webers, then you'll need different tubes, f-11, f-15, or f-9 emulsion tubes, but if the idle circuits of YOUR carbs are different than normal it won't be quite right.
Please check the number of transfer ports(4 or 5) and the idle air bleed size, this will tell us if the idle system is the same, or not |
Posted: Thu Nov 22, 2012 4:19 am Post subject: |
Apologies for the slow reply! time difference and shift working patterns tend to interfere with important stuff I thought I would post some pictures so you can see what we're dealing with. they have 5 transfer ports , but am not sure where to measure for idle air bleed size? excuse my ignorance
modok Samba Member
Posted: Thu Nov 22, 2012 1:22 pm Post subject: |
No problem man, I'm impressed with the pictures
I can SEE that yes, in fact these carbs are very different. They have all the same features as my alfa 36 IDFs, and MORE.
I see LARGE idle air bleeds, these are the brass inserts pressed into the top of the main body, about 1 CM away from where the idle jets screw in.
The large idle bleeds and five large transfer ports REQUIRE a large idle jet. I'd start with .60
I also see they have large diameter tops and extended aug.vents (much like the 44idf ) SWEET
SO, yeah, they are quite different than usual, but different in a GOOD WAY
A lot of folks have wished the desirable qualities of dellortos and webers could be combined, to create the web-orto I believe that these hybrid carbs already exist, and YOU have a set!
The odd emulsion tubes may also be part of the improvements, but unfortunately I don't know for sure. If I were you I'd get some normal emulsion tubes(like I listed earlier) to use to get these running and tuned in on your engine, then go back and try these f-67 tubes later on. |
Posted: Thu Nov 22, 2012 4:22 pm Post subject: |
Did you buy these from the guy on Samba that had 6 for sell? Mo is right these are for an Italian car, such as a alfa..... |
Posted: Fri Nov 23, 2012 3:29 am Post subject: |
I think it may have been a guy on here yes,it was a while ago?he was over here in the UK.
Thanks Modok ,a picture speaks a thousand words as they say!
It's nice to know I have something good how many times do we buy used stuff for our cars only to end up disapointed
I have measured the idle air bleed and it is a 2mm (0.078-0.079") hole
Another oddity with these is the bore size which measures 41.9 mm, meaning they need venturis from 44IDF which with a quick search of carb shops I can find no smaller than 32 mm !
So should I go with 32's or hunt around for some used 30's?
A pic of the pump jet which seems a different style as well?
modok Samba Member
Posted: Fri Nov 23, 2012 5:17 am Post subject: |
as far as the venturis, EMPI has also used the larger diameter for all their weber copies, so 30mm empi HPMX vents should fit.
The old e-bay guy in italy, Alfa1750, may have some OE vents, or I know he also can bore them out to 30mm, or 31mm or whatever size desired if needed.
Ah yes, those acc squirters are also a little different. I bet they are small 35? I'd drill them to 50 |
Posted: Fri Nov 23, 2012 9:29 am Post subject: |
I believe the old Italian ones used a 200 Idle Air Bleed, and worked best with 60 idle jets. They setup differently than the later IDFs. The procedure is the same, but you can't follow the normal "rules" when jetting those ones.
Harney has posted this info in the past, I'm just going from memory. Searching his old posts will gleen the info you need. Bruce Tweddle may also know more about these than we do, he's a very sharp guy and been doing this a while. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
modok Samba Member
Posted: Sun Dec 02, 2012 3:24 pm Post subject: |
NEW INFO
I have purchased some of these for myself, idf 40-78/79 from an alfa.
they are identical to the carbs of the OP
UNLIKE the earlier alfa carbs, these come with 3.5mm aux. vents(also much like a dellorto, interestingly)
I do not know the effects of these smaller nozzles, but in general the smaller nozzle is not preferable for using venturies on the large side. I will be replacing them with 4.5 aux. vents that I already have, so I can directly compare them with my spanish 40IDF 70s
Islandman Samba Member
Joined: March 20, 2008 Posts: 671 Location: Clarksville, TN
Posted: Sun Dec 02, 2012 8:06 pm Post subject: |
I love em. I've been running these on a 1904 for some time now. Very smooth transitions with a solid idle. I tried F11s with a few different idle/mains. No joy. They appear to run best with the F67s on my setup.
My favorite part are the bleed screws for synchronizing. This lets you use a manometer. Unlike a single snail, you can adjust balance on both sides throughout the RPM range.
Homemade manometer: Baby bottles, brass tubing, vinyl tubing, rubber stoppers, and Auto trans fluid.
modok Samba Member
Posted: Sun Dec 02, 2012 8:53 pm Post subject: |
What size idle jets are you using with those things?
I see the idle air bleed is also a little different VS the 36 IDF, more of a mixing well rather than just T drilled, also has 80 degree throttles instead of 78..........(also like the dellorto)
makes you wonder.......who copied who? |
ridenrace6 Samba Member
Joined: May 24, 2009 Posts: 80 Location: moulton,alabama
Posted: Sun Dec 02, 2012 9:27 pm Post subject: |
more details and pics of the manometer please |
modok Samba Member
Posted: Sun Dec 02, 2012 9:36 pm Post subject: |
That DIY manometer is cool! mine usues mercury, but I bet it works no better than if it used water
modok Samba Member
Posted: Mon Dec 03, 2012 3:24 am Post subject: |
TEST DRIVE
HOLY CRAP, they run SMOOTH. Smoothest webers I have ever driven, WOT feels even crisper and more even than the spanish webers I had on it yesterday, and I don't even know why that would be. Lean spot after each shift is gone, just like the dells. Idled at 800 rpm bench set and two turns out on the screws, not rich. Idle to 1/4 throttle feels just slightly lean, but there are no hickups or spots in there at all.
And this is without any fine adjustment of any kind, simply WAG jetting and eyeballed sync.
32 vents, 4.5 aux vents, 137 main, f-11 tubes, 215 air, 50 pump jets, about half pump volume .......
and you don't wanna know how big idle jet, I just used the biggest I had, they are huge, I bet it will never clog
THe web-orto is indeed, the cats ass! |
Posted: Mon Dec 03, 2012 11:55 am Post subject: |
it would be nice to try a set of these in a 44 or 48 if they are made but i take it they are only made in the 40? |
Doktor Samba Member
Joined: December 12, 2006 Posts: 101 Location: Croatia, Europe
Posted: Mon Dec 03, 2012 4:36 pm Post subject: |
[email protected] wrote: |
Harney has posted this info in the past, I'm just going from memory. Searching his old posts will gleen the info you need. |
That's correct.
Here is thread we're talking about: http://www.thesamba.com/vw/forum/viewtopic.php?t=315815&highlight=f67
I have two sets of these Weber 40 IDF's, but also several sets of DRLA 40 in really nice condition. It will be a hard decision...  |
