Vent window press device...
Brendel20
Brendel20 is offline
PostPosted: Mon Dec 03, 2012 10:23 am    Post subject: Reply with quote
I've recently replaced all the rubber on my windows and have a problem. I can't get my vent windows to close with the new rubber being so stiff. I've tried a heat gun with a little luck but still am about 1/2 in. from my latch catching my striker plate. I used WW seals. It seams the seal that sits in the frame is too thick. Specifically, the lower portion around the striker plate and pivot.
Any ideas???
2true
2true is offline
PostPosted: Mon Dec 03, 2012 10:57 am    Post subject: Reply with quote
Another Vote for the 3M Rubberized Electrical Tape. Screw those Repop Seals! Twisted Evil
AKA Destroyer of the Rants......
View user's profile Send private message AIM Address Facebook Gallery Classifieds Feedback
BarryL Premium Member
BarryL is offline
PostPosted: Mon Dec 03, 2012 7:18 pm    Post subject: Reply with quote
Isn't he talking about the big rubber that is in the stationary frame part?
Brendel20
PostPosted: Mon Dec 03, 2012 8:23 pm    Post subject: Reply with quote
Yes, he is
KevinAlbrecht
Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota
KevinAlbrecht is offline
PostPosted: Mon Dec 03, 2012 8:38 pm    Post subject: Reply with quote
Brendel20 wrote:
Yes, he is
He waa replyin to my response about the rubber tape.
Getting the seals to seat on the frame sux. What I can offer is to make sure the seal iz seated in the frame all the way down. Once you are certain you have it seated correctly, spend more time on it.
I had to leave the vents closed for quite awhile in order to have them be broken in.
Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
Click to view image
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Mon Dec 03, 2012 11:11 pm    Post subject: Reply with quote
There are areas of the big vent seal that need to be trimmed before installing to get them to sit in the frame correctly
"no more hacking my sig line"
oldvolkz
oldvolkz is offline
PostPosted: Tue Dec 04, 2012 12:07 am    Post subject: Reply with quote
http://www.youtube.com/watch?v=trzHLG1BUEQ&fea...5aDzmP-LQq
check this guy out. I've got a lot of info from Chris. I haven't used this method or any method for the vent windows, but it sure seems easy.
I hope this will help you.
-oldvolkz
"if you want peace, you must work for justice"
Brendel20
PostPosted: Tue Dec 04, 2012 6:15 am    Post subject: Reply with quote
Here's what I'm working with.....
Big Bill
Big Bill is offline
PostPosted: Tue Dec 04, 2012 6:47 am    Post subject: Reply with quote
It has been awhile since I have done a wing window seal, but if you make a small wooden drift(that fits in the channel of the seat)might help you seat the seal. It is harder to do with the glass in but you might be able to fit it in there and gentley seat it. Iam talking about the seal in the main frame itself.
SkooobaSteve
SkooobaSteve is offline
PostPosted: Tue Dec 04, 2012 7:14 am    Post subject: Reply with quote
Looks like some of the people here have made a rig alot like the factory did. Found this in one of my factory bus repair manuals.
Jonathan
Romans 6:13
WTB 67 beetle rear seat belts.
59 Euro ragtop build with my dad
http://www.thesamba.com/vw/forum/viewtopic.php?t=493553&postdays=0&postorder=asc&start=0
65 dlx Slow build
http://www.thesamba.com/vw/forum/viewtopic.php?t=391061
SkooobaSteve
PostPosted: Tue Dec 04, 2012 7:28 am    Post subject: Reply with quote
-oldvolkz
Looks like this is what I will be doing so much easier.
Jonathan
Romans 6:13
65 dlx Slow build
Bulli Klinik
Bulli Klinik is offline
PostPosted: Tue Dec 04, 2012 7:44 am    Post subject: Reply with quote
Any ideas???
Spray the seating portion of the seal with some lube, then push the tail end of the glass in as you push the front, frame side out to close it as much as possible. If it doesn't seat, you may need to bump the latch retainer in a bit or even grind a little of the inner part of the latch away. Then close them for a couple-few months until it beds in. Good Luck!
Mike K
Bulli Klinik
Colorado Springs
Bryan67
Bryan67 is offline
PostPosted: Wed Feb 06, 2013 12:02 am    Post subject: Reply with quote
I just had a local glass shop do my vents for my 68 bus. Thay have done a few sets for me in the past. At ten bucks each I`ll let them do it.
If you`re going to do something, do it right.
Spiderwebb
Spiderwebb is offline
PostPosted: Sat Mar 30, 2013 3:40 pm    Post subject: Reply with quote
this might be a better thread to put this on so here it is again...
just did my 1st vent window rebuild and all was easy
used electrical tape two layers
waiting 24 hrs until I remove it from the jig to make sure the glass stays put...
had to use some hair spray to get the glass to stay put after removing from the jig
tinted glass, powdercoated parts and WW repop latch
jig
electrical tape trick
pressing it all together slowly with hair spray
'64 SC
Paul Botello
Paul Botello is offline
PostPosted: Sat Mar 30, 2013 5:01 pm    Post subject: Reply with quote
How do you trim under the swoosh???
https://www.thesamba.com/vw/gallery/pix/medium/1043763.jpg
Spiderwebb
PostPosted: Sat Mar 30, 2013 6:14 pm    Post subject: Reply with quote
since I used electrical tape I didn't have to do much if any trimming
make sure that you use a least 2 layers of that tape and a bit more on the top of each vent glass... mine needed 3 layers on the top and down the back side to get the glass nice and tight.
I used hair spray instead of soapy water since I heard that is better = tacky / sticky once dry... leave the glass under pressure over night to make sure it stays put once out of the jig.
If you can file the inside of the latch corners so it is smooth = won't pull off the tape while your pressing in the glass. happened to me
OldVolks67
OldVolks67 is offline
PostPosted: Sat Mar 30, 2013 8:06 pm    Post subject: Reply with quote
I am in the process of doing my windows as we speak 1 down 1 to go. I totally agree about the 3m rubber electrical tape! Its definetly the way to go, looks nice and clean and easy to work with. I tried the WW rubber and it just wasn't working out no matter what I tried. So I applaud the man who came out with this idea and posted it to help us all out! Thanks
Scooterboyd
Scooterboyd is offline
PostPosted: Sat Mar 30, 2013 8:17 pm    Post subject: Reply with quote
I just walked in a minute ago after doing both for my bus trailer and wished I saw this earlier. I used a bicycle innertube. What a hassle. Go with the tape method!!
President of "Society of Unappreciated Overachievers"
62 - 23 Window Bus
60 - Karmann Ghia Convertible
59 - Convertible Raceable Baja Bug
63 - Dune Buggy
65 - Single Cab
matthew henricks
matthew henricks is offline
PostPosted: Fri Nov 22, 2013 1:32 pm    Post subject: Reply with quote
This is how i trim under the swoosh. Has worked well for the 4 buses i have restored.
- Take a #11 x-acto knife blade. A brand new, sharp one.
- Heat the tip with a torch and bend over 90 degrees the tip about 1/16" back.
- Got to do this quick so you do not dull the tip with the flame and you need as tight of a bend as close to 90 degrees as you can. You are annealing the metal in order to bend it which also means the blade will not last as long.
- Put the blade in a x-acto holder and use it to get down behind the swoosh and trim the rubber.
I have also thought about trying it with the #9 retractable blade as it is smaller.
Works well. You have to get used to manipulating the handle so the blade stays perpendicular to the class and the cutting edge stays in line with the edge of the frame. You also have to be careful not to scratch the glass getting the tool in and out and not remove paint from the frame or swoosh while you are working in there. Usually takes about 5 minutes to finish the job and usually pretty clean cut.
I would post a picture if i had one....
No to find someone local who has a home made press as i have a latch that needs replacing.....
kirbyland
kirbyland is offline
PostPosted: Tue Nov 11, 2014 8:57 am    Post subject: Reply with quote
do you have to make a jig for both R/L sides? Seems the latch would cause issues?-
Page 3 of 4
