Brendel20 Samba Member
Joined: October 21, 2010 Posts: 301 Location: Troy, IL
Posted: Mon Dec 03, 2012 10:23 am Post subject: |
I've recently replaced all the rubber on my windows and have a problem. I can't get my vent windows to close with the new rubber being so stiff. I've tried a heat gun with a little luck but still am about 1/2 in. from my latch catching my striker plate. I used WW seals. It seams the seal that sits in the frame is too thick. Specifically, the lower portion around the striker plate and pivot.
Any ideas??? |
2true Samba Member
Posted: Mon Dec 03, 2012 10:57 am Post subject: |
Another Vote for the 3M Rubberized Electrical Tape. Screw those Repop Seals!  _________________ AKA Destroyer of the Rants...... |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15253 Location: Casa de Oro, California
Posted: Mon Dec 03, 2012 7:18 pm Post subject: |
Isn't he talking about the big rubber that is in the stationary frame part? |
Posted: Mon Dec 03, 2012 8:23 pm Post subject: |
BarryL wrote: |
Yes, he is |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 993 Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota
Posted: Mon Dec 03, 2012 8:38 pm Post subject: |
Brendel20 wrote: |
BarryL wrote: |
Yes, he is |
He waa replyin to my response about the rubber tape.
Getting the seals to seat on the frame sux. What I can offer is to make sure the seal iz seated in the frame all the way down. Once you are certain you have it seated correctly, spend more time on it.
I had to leave the vents closed for quite awhile in order to have them be broken in. _________________ Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
Click to view image |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5928 Location: back to living where hell meets the suface
Posted: Mon Dec 03, 2012 11:11 pm Post subject: |
There are areas of the big vent seal that need to be trimmed before installing to get them to sit in the frame correctly _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
oldvolkz Samba Member
Joined: September 28, 2005 Posts: 321 Location: Hollister, Califaztlan
Posted: Tue Dec 04, 2012 12:07 am Post subject: |
http://www.youtube.com/watch?v=trzHLG1BUEQ&fea...5aDzmP-LQq
check this guy out. I've got a lot of info from Chris. I haven't used this method or any method for the vent windows, but it sure seems easy.
I hope this will help you.
-oldvolkz _________________ "if you want peace, you must work for justice" |
Posted: Tue Dec 04, 2012 6:15 am Post subject: |
Here's what I'm working with.....
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1802 Location: Fortuna Calif.
Posted: Tue Dec 04, 2012 6:47 am Post subject: |
It has been awhile since I have done a wing window seal, but if you make a small wooden drift(that fits in the channel of the seat)might help you seat the seal. It is harder to do with the glass in but you might be able to fit it in there and gentley seat it. Iam talking about the seal in the main frame itself. |
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2215 Location: Bulli Klinik, Colorado Springs
Posted: Tue Dec 04, 2012 7:44 am Post subject: |
Brendel20 wrote: |
Any ideas??? |
Spray the seating portion of the seal with some lube, then push the tail end of the glass in as you push the front, frame side out to close it as much as possible. If it doesn't seat, you may need to bump the latch retainer in a bit or even grind a little of the inner part of the latch away. Then close them for a couple-few months until it beds in. Good Luck! _________________ PM me about quality metal-work on your vehicle.
Mike K
Bulli Klinik
Colorado Springs |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2962 Location: Fresno, Ca.
Posted: Wed Feb 06, 2013 12:02 am Post subject: |
I just had a local glass shop do my vents for my 68 bus. Thay have done a few sets for me in the past. At ten bucks each I`ll let them do it. _________________ If you`re going to do something, do it right. |
Spiderwebb Samba Member
Posted: Sat Mar 30, 2013 3:40 pm Post subject: |
this might be a better thread to put this on so here it is again...
just did my 1st vent window rebuild and all was easy
used electrical tape two layers
waiting 24 hrs until I remove it from the jig to make sure the glass stays put...
had to use some hair spray to get the glass to stay put after removing from the jig
tinted glass, powdercoated parts and WW repop latch
jig
electrical tape trick
pressing it all together slowly with hair spray
'64 SC
Paul Botello Samba Member
Joined: October 18, 2008 Posts: 46 Location: Temecula
Posted: Sat Mar 30, 2013 6:14 pm Post subject: |
Paul Botello wrote: |
How do you trim under the swoosh??? |
since I used electrical tape I didn't have to do much if any trimming
make sure that you use a least 2 layers of that tape and a bit more on the top of each vent glass... mine needed 3 layers on the top and down the back side to get the glass nice and tight.
I used hair spray instead of soapy water since I heard that is better = tacky / sticky once dry... leave the glass under pressure over night to make sure it stays put once out of the jig.
If you can file the inside of the latch corners so it is smooth = won't pull off the tape while your pressing in the glass. happened to me |
OldVolks67 Samba Member
Joined: August 18, 2010 Posts: 161 Location: Boston Metro West
Posted: Sat Mar 30, 2013 8:06 pm Post subject: |
I am in the process of doing my windows as we speak 1 down 1 to go. I totally agree about the 3m rubber electrical tape! Its definetly the way to go, looks nice and clean and easy to work with. I tried the WW rubber and it just wasn't working out no matter what I tried. So I applaud the man who came out with this idea and posted it to help us all out! Thanks |
Scooterboyd Samba Member
Joined: January 18, 2009 Posts: 342 Location: Rancho Cordova, California
Posted: Sat Mar 30, 2013 8:17 pm Post subject: |
I just walked in a minute ago after doing both for my bus trailer and wished I saw this earlier. I used a bicycle innertube. What a hassle. Go with the tape method!! _________________ President of "Society of Unappreciated Overachievers"
62 - 23 Window Bus
60 - Karmann Ghia Convertible
59 - Convertible Raceable Baja Bug
63 - Dune Buggy
65 - Single Cab |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1361 Location: So. Cal
Posted: Fri Nov 22, 2013 1:32 pm Post subject: |
This is how i trim under the swoosh. Has worked well for the 4 buses i have restored.
- Take a #11 x-acto knife blade. A brand new, sharp one.
- Heat the tip with a torch and bend over 90 degrees the tip about 1/16" back.
- Got to do this quick so you do not dull the tip with the flame and you need as tight of a bend as close to 90 degrees as you can. You are annealing the metal in order to bend it which also means the blade will not last as long.
- Put the blade in a x-acto holder and use it to get down behind the swoosh and trim the rubber.
I have also thought about trying it with the #9 retractable blade as it is smaller.
Works well. You have to get used to manipulating the handle so the blade stays perpendicular to the class and the cutting edge stays in line with the edge of the frame. You also have to be careful not to scratch the glass getting the tool in and out and not remove paint from the frame or swoosh while you are working in there. Usually takes about 5 minutes to finish the job and usually pretty clean cut.
I would post a picture if i had one....
No to find someone local who has a home made press as i have a latch that needs replacing..... |
kirbyland Samba Member
Posted: Tue Nov 11, 2014 8:57 am Post subject: |
do you have to make a jig for both R/L sides? Seems the latch would cause issues?- |
