How long will it run? Clunker 1835.--It's running!
Marks67
Marks67 is offline
PostPosted: Wed Nov 14, 2012 11:43 pm    Post subject: Reply with quote
I might have seen the brand new playtech you are talking about last week in his shop getting finished up.
DonziGT230
DonziGT230 is offline
PostPosted: Thu Nov 15, 2012 7:43 am    Post subject: Reply with quote
Hammertone grey frame and gloss black panels? It's a fun ride, unfortunately engine issues stopped it short. Whoda figured??-mine stayed running and his has a crank knock.
I refuse to call a distributor a dizzy--earthquake.
The glass is always full and I can prove it!--me
DonziGT230
PostPosted: Sat Dec 01, 2012 2:51 pm    Post subject: Reply with quote
Last trip out it seized up solid. Took a casual cruise for gas, came back to camp then let er rip! It did fine, then I backed off and cruised for a few seconds and with no warning it just locked up at about 1300 RPM. The JB welded mains and all my other BS is fine, it was that one rod bearing that still had a tight spot I'd ignored. It spun & stacked instantly, no discoloration or major new damage. I'm gonna sand down the crank, put an old bearing in and run it again 'till it blows proper like! This time I'll stake and JB the rod bearing so it won't spin again. If it's gonna blow up I want some REAL damage with parts hanging out so there's no doubt as to what happened.
Boolean
Boolean is offline
PostPosted: Sat Dec 01, 2012 3:54 pm    Post subject: Reply with quote
Still can't find a "like" button here, but it there was one - i'd click it!
I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379
DonziGT230
PostPosted: Sat Dec 01, 2012 6:05 pm    Post subject: Reply with quote
Very Happy --like button.
The rod's back in and torqued, tomorrow I'll try & get the rest back together and test run it.
Tbirdusa
Tbirdusa is offline
PostPosted: Sun Dec 02, 2012 9:32 am    Post subject: Reply with quote
I'm trying to get motivated enough to take the pressure plate off mine today and to think you've got enough energy to build a piece of crap just for shoots and giggles. I wish I had your get up and go. Hell, I'm pondering whether I've got it in me to make another pot of coffee or just sit here.
Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus!
Wayne26
Wayne26 is offline
PostPosted: Sun Dec 02, 2012 10:07 am    Post subject: Reply with quote
lol sounds like me anymore..
Boolean
Boolean is offline
PostPosted: Sun Dec 02, 2012 1:58 pm    Post subject: Reply with quote
Sometimes it is easier to just open another can of beer.
Build thread here:
Tbirdusa
Tbirdusa is offline
PostPosted: Sun Dec 02, 2012 4:10 pm    Post subject: Reply with quote
Quick update: Since the dog had to go out, I made another pot of coffee. Whew... thought I wasn't going to get anything done today.
Did you get it running !!!! ! ! ! ! !
DonziGT230
PostPosted: Mon Dec 03, 2012 6:01 pm    Post subject: Reply with quote
Coffee through the morning hours and now rum. I roast my own beans and sometimes make the rum, but I've been slacking on the latter.
Just got done running her, sounds better than the first time around. I got rid of the little tight spot the one rod had and for good measure I peened and locktited the bearings to the rod. All the JB weld I could see inside the case was still there and holding and end play is still good. Oil pressure is good and no abnormal sounds at all. If I find some spare time and $ I'm gonna strap one of my nitrous kits to it for the next outing, just need a fogger nozzle.
DarthWeber
DarthWeber is offline
PostPosted: Mon Dec 03, 2012 6:07 pm    Post subject: Reply with quote
Oh S**t!! Laughing Laughing Laughing
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
Tbirdusa
Tbirdusa is offline
PostPosted: Wed Dec 05, 2012 7:17 am    Post subject: Reply with quote
for this build, just find some copper tubing and hammer the tip flat and hook up the go juice.
You do have a helmet and fire ext. nearby, right?
DonziGT230
PostPosted: Wed Dec 05, 2012 4:54 pm    Post subject: Reply with quote
That's plain silly talk, hammering it flat would restrict flow.
To keep with the "spare all expenses" theme going I guess I really should make my own injector set-up. I'll think up some kinda bastardized back-yard engineered redneck spray system. I'll try & find a way to employ JBweld into it for good measure Wink
Bill271
Bill271 is offline
PostPosted: Thu Dec 06, 2012 7:40 pm    Post subject: Reply with quote
Ive got nozzles and and a full tank lets put it on my dyno!!!!
Seen stuff like this and just CANNOT beleive the abuse a vw will take!
VenturaGhia
VenturaGhia is offline
PostPosted: Thu Dec 06, 2012 7:55 pm    Post subject: Reply with quote
BEST......THREAD........EVER!
71 Ghia Coupe
In a society that has destroyed all adventure, the only adventure left is to destroy that society.
DarthWeber
PostPosted: Thu Dec 06, 2012 7:58 pm    Post subject: Reply with quote
A splash of nitromethane couldn't hurt. Wink
mark tucker
mark tucker is offline
PostPosted: Thu Dec 06, 2012 8:21 pm    Post subject: Reply with quote
we (my brother)made a setup for the gokart,I think he had it spraying through the carb so it would pull extra fuel and you reached around & tuned the carb while you were standing on it to get it just right. It out run a few mustangs in the late 80's early 90's. it was kinda fun. bot would that sucker sing, it only had a cam,springs,piston&rod in it, but other than that a stock 5hp brigs. so it shouldnt be hard to build your own for this mess you have there.take some vid's too.
DonziGT230
PostPosted: Sat Dec 22, 2012 2:11 pm    Post subject: Reply with quote
I'd love to dyno it.
Been away distracted by other toys & projects. I'm taking the clunker out to Ocotillo Wells for the holidays so I'll get to see if it holds together. We've got plenty of toys in case this one takes a dump, but I'm relatively confident it'll go for a while. If it lives I'll see about bringing it back again and taking up Bill's offer. The toys all stay in storage down there, but I could pull the motor and bring it back again.
I'm glad people are entertained by my ridiculous "rebuild", makes it all the more worth while doing what I did. Very Happy
DonziGT230
PostPosted: Tue Jan 08, 2013 6:13 pm    Post subject: Reply with quote
I forgot to report after the desert trip. It ran great! It didn't get a lot of hours, but got plenty of hard revs. Much faster than the stock motor I had and definitely has a meaner sound.
slalombuggy
slalombuggy is offline
PostPosted: Tue Jan 08, 2013 6:50 pm    Post subject: Reply with quote
Dude, you're my hero. I was hatin' at first but now I'm lovin' it. Hat's off to ya buddy, for showing me I'm full of #$%^.
Very Happy Very Happy Very Happy CHEERS Very Happy Very Happy Very Happy
brad
Page 4 of 5
