oldvolkz Samba Member
Joined: September 28, 2005 Posts: 321 Location: Hollister, Califaztlan
Posted: Sat Dec 15, 2012 1:42 am Post subject: Will this cause no reverse in my 57 SC |
57 Single cab
later bus trans with RGB's and DP Enginge
Concept 1 Nose Cone Conversion Kit
I didnt do the conversion. I drove the SC and all 4 forward gears work great but reverse is hard to find but I find it here and there.
I decided to check the shifter stop plate and this is what I saw.
Would this cause no reverse.?
Where can I get a plate?
I know there interchangeable from bug to bus. But a 57 is old. Will any work for my SC?
_________________ "if you want peace, you must work for justice" |
bubblehead Samba Member
Posted: Sat Dec 15, 2012 7:28 am Post subject: |
That's a common place for those to break. Pretty much one size fits all as far as replacement. And remember the longer/bent tab goes on the right side pointing
up. |
G-wood Todd Samba Member
Joined: January 11, 2005 Posts: 1047 Location: Colorado
Posted: Sat Dec 15, 2012 12:10 pm Post subject: |
Thanks guys. Going to get one asap. _________________ "if you want peace, you must work for justice" |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71896 Location: Phoenix 602
Posted: Sat Dec 15, 2012 3:45 pm Post subject: |
| EverettB wrote: |
I don't know if that would cause no reverse at all but that would definitely mess stuff up. I've had things not work right just from wear, let alone a broken plate.
Your plate has some clear wear too, along that same reverse lockout piece that is sticking up. |
I do have reverse (sometimes) its hard to find. I also don't have a front bushing.
Can I replace the bushing without removing the transmission? _________________ "if you want peace, you must work for justice" |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4121 Location: Margaritaville.....24/7
Posted: Sat Dec 15, 2012 3:52 pm Post subject: |
| oldvolkz wrote: |
| EverettB wrote: |
Can I replace the bushing without removing the transmission? |
The bushing may be causing more problems than the crack. And, yes, you can replace the front bushing w/o removing the engine. The front section is removable from the long shift rod.
FWIW Counselors/Therapists call what you did there "Door-Knobbing". It is where you talk about one problem for a while and then as you are leaving, with your hand on the door knob, you drop the bomb. Shoulda mentioned that one first!  _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
bugcollections Samba Member
Posted: Sat Dec 15, 2012 6:16 pm Post subject: front bushing |
| YOUBUGME2 wrote: |
| The rear bushing on the other hand isn't as user friendly |
Neither is the front one when you try to uncouple the front rod from the rear with that frozen collar that you will probably have to cut off. |
Posted: Sat Dec 15, 2012 6:46 pm Post subject: Re: front bushing |
| bugcollections wrote: |
| YOUBUGME2 wrote: |
Going to get all the bushings and collar if I have to cut it out.
Thanks Everett for the knowledge.
@cru62 just keeping you guys on your toes. _________________ "if you want peace, you must work for justice" |
Posted: Thu Dec 20, 2012 7:36 pm Post subject: |
Should the shifter be so in an angle like that? its on 1st gear in this picture. It has the concept 1 nose cone.
But I have reverse now. I installed a new bushing and clip plus the center shift rod coupler. I had to use the red urethane coupler. (for now) will get the WW coupler soon.
Coupler
Bushing & Clip
now to do the center pin _________________ "if you want peace, you must work for justice" |
