davesclassicvws Samba Member
Joined: January 09, 2003 Posts: 55 Location: Camas, WA
Posted: Sun Feb 03, 2013 9:22 pm Post subject: |
Hey Drew,
I live in Camas and would like to come by some time and check out your ride. my eamil address is [email protected] drop me a line. Do you ever go to the vanagon events in Portland at Lucky Lab? _________________ 1969 VW Beetle
1972 Karmann Ghia
1982 Vanagon Westfalia ('OlBlue)
2000 New Beetle |
Ibuprofen Samba Member
Posted: Sun Feb 03, 2013 9:27 pm Post subject: |
Drew,
I'm the guy who bought your 1.9 muffler, cat and coolant junction. Looks and sounds great! Nicely done! _________________ Filbert: 85 Westy, 1.9 AHU mTDI, LR 300 pump stock fueling, 520 nozzles. |
theDrew Samba Member
Posted: Sun Feb 03, 2013 10:55 pm Post subject: |
Thanks all for the kind words!
I still am in the honey-moon phase w/ the van. I want to tell everyone about it!
Just spent the weekend at the coast and had the joy of setting the cruise to 65 and just sit back and enjoy the ride all the way there and back. Love this thing!
Using passing lanes TO pass cars is pretty freaking sweet. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
zippyslug31 Samba Member
Joined: July 20, 2007 Posts: 799 Location: Central Oregon
Posted: Mon Feb 04, 2013 1:50 pm Post subject: |
Have you found any new issues during your honeymoon phase? New costs or gotchas?
Can't recall... did you re-gear your trans? I've heard some say that you don't strictly need to, but if you don't then at freeway speeds you will be buzzing the motor a little higher RPM than needed.
Any feedback on this? _________________ previous:
'80 westy
current:
'90 syncro westy 2.5L subi, triple knob, 16" wheels.
'84 sunroof van, 2.1L motor. |
Posted: Mon Feb 04, 2013 2:04 pm Post subject: |
No more issues other than what I covered in part 5 of the videos.
I've got 1000 miles in it now, and it runs like a champ!
I would love to re-gear the transmission cause to hit 70, the engine's whining at like 3800rpm -- but I have no rush on that yet. Eventually! _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15411 Location: Syracuse, NY
Posted: Mon Feb 04, 2013 2:06 pm Post subject: |
the engine is fine at 3800 rpms.. that was the 70mph rpm for your previous engine and it was fine (designed) at that too.
Kuods to a nice install. _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
Fritz Samba Member
Joined: July 24, 2009 Posts: 68 Location: The Big Mitten
Posted: Tue Feb 05, 2013 6:16 pm Post subject: |
Drew- just got around to watching video 5. Referencing the fuel tank hose you uncapped-you should not vent your gas tank directly into your engine compartment. When the van is sitting fumes are going to come out that hose and collect in the engine compartment. Need to figure out where that hose is supposed to go.
Great job on the conversion. |
dkeirsbilck Samba Member
Posted: Wed Feb 06, 2013 2:59 pm Post subject: coolant transfer pipes |
| really nice job what coolant pipes did you use and did you go with the pipes for a 1985 vanagon? |
vanonimous Samba Member
Joined: October 19, 2013 Posts: 366 Location: Burien, Center of the Universe
Posted: Wed Nov 05, 2014 12:21 am Post subject: |
Nice, going out for the first ride is like unclogging a kitchen sink. It's finally flowing. Your PS pump sounded very loud have you ever adjusted pressure in the pump relief valve? _________________ If happiness is being a mechanic, owning a Vanagon is nirvana.
Lighting upgrades: https://www.thesamba.com/vw/forum/viewtopic.php?t=578291 |
Posted: Mon Aug 27, 2018 4:13 pm Post subject: Re: Project EJ25: Complete (Now with Video!) |
Hard to believe I did this 5+ years ago -- thought I'd give you all an update.
Got about 20k on the conversion now.
Problems I have encountered with the conversion:
- Leaking throwout bearing -- turned out to be a defective TOB, slowly leaking fluid. Just a pain to change out
- Ate the steering/alt belt up in Canada cause I failed to tighten one of the adjustment bolts. I now carry a spare just cause jerry rigging the house battery to run the engine so we could drive to a town was less than fun.
- Dirty air filter x 2 (too many dusty forest roads I guess) -- It was throwing some system trim codes. I finally ditched the air filter that RMW sold and use a big K&N cone filter. More surface area to help mitigate things.
- Cracked oil pan -- somehow in our travels we hit something that put a hairline crack in the oil pan and I finally got tired of the drips and replaced it.
- Cracked coolant level sender -- the 200lb gorilla that put it on must have over tightened it and it finally gave way one trip so we had to drive around spilling coolant until we made it to a town that carried one.
So basically, nothing major, just stupid little stuff thats usually my fault. No regrets in the conversion. We've taken it everywhere, it just works great. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
11BC2 Samba Member
Joined: August 27, 2017 Posts: 496 Location: Cool, California
Posted: Mon Aug 27, 2018 6:10 pm Post subject: Re: Project EJ25: Complete (Now with Video!) |
| Thanks for the update!! |
