mrbigmax Samba Member
Joined: September 10, 2011 Posts: 1289 Location: Modesto, CA
wayne1230cars Samba Member
Posted: Mon Feb 18, 2013 1:00 pm Post subject: |
I could not get mine to work and so I obtained a new valve from German Supply @$28.00. It is identical to the old one and quite easy to change. There is a clip on the front of the air cleaner that you carefully pry off and the new valve just slips in from the inside of the air cleaner. It took me 5 minutes. Make sure you get the brass fitting on the correct side. I don't know how much of a difference it will make in engine warmup but I like things to work as original. Before you buy one of these valves, make sure the flap part in the air cleaner is working.[img][/img]
[img][/img] _________________ 1960 beetle
1970 beetle convertible |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11812 Location: Redding, CA
Posted: Mon Feb 18, 2013 8:16 pm Post subject: |
I have a follow-up, too. I spliced the two tubes together and the warm-air flap opened all the way when I started the engine. So the flap works, using this testing method. So I need a new thermo valve ... which I will get at German Supply.
Thanks, everyone.
Tim |
Kodok Samba Member
Joined: April 21, 2013 Posts: 1 Location: McMinnville, OR
Posted: Thu Mar 27, 2014 8:36 pm Post subject: Thermostatic Valve Function |
Gitchigumi Wrote:
| Quote: |
I suspect the valve works like this:
When the temp is below 20C or so, the bi-metal strip flexes just enough to close the ball check valve. As the brass tube valve floats freely, it is sucked open allowing vacuum to be applied to the vac can, closing the cool air intake and opening the warm air intake. Once the bi-metal strip reaches 20C or so it returns to normal out opening the ball check valve and breaking the vacuum link to the vac can, allowing the brass tube check valve to fall into the brass tube. Because this valve is free floating, air slowly re-enters the vac can via the little bleeder hole allowing the flap to close over the warm air intake and open the cool one.
Hi, I just read your post. It was clear and useful, especially the pictures. I was revisiting my own non-functioning valve again. I wanted to repair or replace it to improve the function of my engine in winter.
I carefully reviewed and followed the instructions you gave. Like with you, my valve was filthy, and sticky as a result. What I did realize when testing the valve is that the function is a little more complicated than you wrote.
First, I noticed that the pin hole allows air in no matter what the temperature of the valve. This bothered me at first. However, I realized that that is most likely on purpose. I believe the pin hole draws filtered air from the cleaner across the bi-metal strip to make sure it is the same temperature as the air. This does create a tiny but (I guess) harmless vacuum leak.
Second, I think the ball check valve screws in and out to adjust the high and low setting for the valve. For example, when screwed in with only a few threads showing it will keep the vac can open until a high air temp. When screwed out further the vac can closes at a lower air temp.
That is what I believe is happening. It still needs testing to be sure. But, perhaps this information is useful to those who are curious.
Sorry I did not post before. I tend to lurk and read the great posts by other more knowledgeable people. However, I thought this info would be something new to add. |
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
Weezle Samba Member
Joined: February 07, 2014 Posts: 687 Location: ORLANDO
Posted: Fri Mar 28, 2014 7:40 am Post subject: |
"Actually you can check it working by looking at this little indicator. It's an extention of the shaft holding the flap.
In cold weather it should be up at an angle. When the engine is warmed up or if the weather is warm, it should be horizontal (flap closed, carburetor sucking non-preheated air directly through the intake). "
I like this answer, thanks. Easy test. |
korfmach Samba Member
Joined: February 28, 2014 Posts: 267 Location: Fort Collins, CO
Posted: Sat Mar 29, 2014 1:31 pm Post subject: |
Someone disabled the vacuum circuit to my warm-air flap by removing the vac can and plugging both the supply and reference ports in the central idle tube junction. Does anyone know if there's an alternative routing for the hoses that will still allow the warm-air flap to work correctly? _________________ 1989 Westy, "La Barchetta Rosa" (Rosy)
2022 ID.4, "Ivy"
Gone, but not forgotten:
2016 Golf TSI
1974 Dorper Baywindow, "The Bleeding Trout"
1998 Jetta TDI, "Trixie"
1987 GTI, "Heike"
1974 Thing, "The Luftwaffel"
1974 Ghia
1966 Ghia |
Juanito84 Samba Member
Joined: March 17, 2012 Posts: 2436 Location: Colorado Mountains
Posted: Tue Apr 01, 2014 4:06 pm Post subject: |
| Boble wrote: |
To summarize the functions of this important little piece:
The thermostatic vacuum valve used on late models: (Note that the plastic pipe goes to the intake manifold or carb. The brass tube towards the vacuum operated flap in the air filter intake.)
Low temperature inside the air filter: The thermostatic valve is open, the flap is lifted up by the vacuum, and the carb gets pre-heated air:
Higher temperature inside the air filter: The thermostatic valve closes, the flap goes down to closed position, and the carb gets ambient (cold) air:
This function prevents carburetor icing, and also ensures that the air/fuel mixture is more correct. Typical failures are defect valve (engine always gets cold air), and defect air flap that don't lift to upwards position (engine always gets cold air + potential air leaks)
The mechanism is similar on the paper type air filters, although the flap is positioned a little differently. |
If you don't have the vacuum can it won't work, it must be set up like the diagrams above.
http://www.thesamba.com/vw/forum/posting.php?mode=quote&p=5805908 _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Posted: Tue Apr 01, 2014 4:33 pm Post subject: Re: Thermostatic valve in air cleaner test |
| Tim Donahoe wrote: |
| Hello, all. Has anyone figured out a way to check to see if the thermostatic valve in the air cleaner is actually working? |
I test it installed. Before testing you must have the engine thermostat working. Otherwise you may get a false error.
1. Have someone start the engine cold while you look down the snorkle to see if the flap pops all the way up. (Also you could have him floor the accelertor and let off (aka blip it) to see if it falls back down then pops right back up again. On earlier models like 1972, but not on the 1971 wax pellet type, it will do this. On later models and 1971 wax pellet type air cleaners its not supposed to do this when dead cold, although this is a very minor malfunction.)
2. Disconnect the charcoal canister hose from the air cleaner and secure a thermometer in there with at least a 50º F to 150º F range so it reads the internal air temp. Plug off the rest of the opening as well as the charcoal hose.
3. Drive it around like a normal driver should, the pull over and check the temp. It should be around 100º F. I wouldn't worry about it unless it were more than 120º or less than 80º especially on an average day. But even in hot or cold weather it should be between those temps.
4. Have someone floor it and let go to see if the flap falls and pops up. It should do this when the engine is warm on all thermostatic air cleaners except 1971 wax pellet thermostat type air cleaners. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Posted: Tue Apr 01, 2014 4:49 pm Post subject: |
Weezle has the easier way: just look at the center line on the small door-flap hinge pin.
The line will be horizontal when the flap is closed, and going toward vertical when the door is opening to allow warm-up air.
This hinge pin is about the size of a pencil eraser. It has a line in its middle. You can see it easily. It's right there in front of you.
Don't try this on a real hot day unless you do it in the cool morning. Start the car and see if the line in the hinge pin moves to the vertical position. That means the thermo valve is opening your flap/door.
Tim |
Posted: Tue Apr 01, 2014 5:11 pm Post subject: |
Ya, either way should indicate the flap movement. I just perfer looking directly at it.
IMO, whether the flap fully moves one way or another or even moves at all is not what is important. What is important is that the air temperature inside the air cleaner be about 100º F at low loads, regardless of ambient temps. Of course if it's over 100º outside the flap shouldn't move much if at all. But even in cool weather, if the air cleaner thermostat goes bad and causes the flap to stay up it will be pulling 165º F or hotter air off the cylinder head if the engine thermostat is working. That's too hot.
At WOT the flap should lie back down cutting off heated air. As you can see, both temperature and engine load should affect the flap's movement.
Just my 1.5 cents. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
bluebus86 Banned
Posted: Sat Oct 14, 2017 2:08 pm Post subject: Re: Thermostatic valve in air cleaner test |
I am tuning my motor, it is I think a 74 motor (its in my 61 Bug) It has the plastic air cleaner
I wanted to see if the hose that is connected to the intake manifold just below the carb is a source of a vacuum leak. sucking on it back to the aircleaner I found it dont hold vacuum.
The flap mechanism in the snorkel however does hold vacuum, the flap works fine when vacuum applied.
this lead me to the thermostat control unit, the one with the two hoses on it. I am not totally sure of its operation charectoristics. I have removed it, cleaned it, confirmed the ball valve is present and seals and also removed the brass outlet and found the rubber seal under it to be in nice condition, clean and flexible.
I also note a small drilling on the plastic body, possibly a vent.
When I suck on the hose from the intake manifold to the thermostat unit, this vent hole is a source of a vacuum leak. is this correct to leak from this small hole? should we assume this small vacuum leak, which leaks to the inside of the aircleaner is an intentional part of the design?
I also noticed that I think the amount that the brass pipe is screwed into the unit possibly effects the calibration, the more screwed in, the more the brass tube makes contact with the aforementioned little gasket under it.
at anyrate, can some one confirm or not if there is supposed to be a small vacuum leak from this unit on the port that goes to the hose to the intake manifold (I am testing at approximently 60F) ????
Not being framilur with this late VW aircleaner system I am a bit confussed, Normally any intake manifold leak is cause for concern, but from what I gather, this small leak might be normal part of operation of this thermo vacuum unit, Id like confirmation one way of the other.
Thank you
Keep Buggin! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sat Oct 14, 2017 3:06 pm Post subject: Re: Thermostatic valve in air cleaner test |
I don't know al lot about the valve. When mine failed to open four years ago, I tried to clean and refurbish it, but I ended up buying a new one.
I seem to remember a bi-metallic spring inside the unit, and most of all, I remember that if the unit fails in the open position, it can be a source for a vacuum leak. This vacuum leak is often hard to find, since most owners don't realize that a faulty thermostatic valve in the plastic air cleaners can be the culprit.
If your valve isn't working, I'd just get a new one from RockAuto (the Rabbit ones are the same, so look under Rabbit for parts).
As far as the hole in the thermostat is concerned, I can't remember it's function exactly, but I seem to recall that it has something to do--at some point--with letting off pressure within the unit itself. So this hole may be the source for the vacuum leak I heard of when the unit does fail.
You can always plug the line, or the male nipple on the manifold, and see if your vacuum leak goes away. At the least, you'll know it's not the valve.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53261 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Oct 14, 2017 5:11 pm Post subject: Re: Thermostatic valve in air cleaner test |
It's been a few years since I dismantled one of those valves and studied them but I do recall it being much more complex than it outwardly appears.
Yes it does direct vacuum to the dashpot that opens the heat flap when it's cold in the inlet. And when it's finally warm enough it cuts off the vacuum and allows air to return through the hose to the dashpot so it can close.
But I seem to recall it also becomes a pseudo idle compensator when it's warm by creating a vacuum leak and leaning the mixture slightly.
There should be no vacuum leak on the manifold port nipple when it's below the opening temp marked on the housing (usually ~90*F). The rubber seal on the end of the bimetal strip is likely petrified. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
bluebus86 Banned
Posted: Sat Oct 14, 2017 6:40 pm Post subject: Re: Thermostatic valve in air cleaner test |
has a small leak thru the vent hole when warm, but not after I frooze it via the tiny hole in the body of the unit once warmed up, the hole is what allows the vacuum to be released allowing the hot air flap to return to warm running position. so yes the unit does have a pin hole leak when warmed, and it needs that leak to release the flap to return to warm position.
Its ok, mine is working. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Jun 23, 2022 5:37 pm Post subject: Re: Thermostatic valve in air cleaner test |
The easiest way to test the air cleaner thermostatic valve on the paper-element air cleaners is this:
Make sure the ambient temperature is under 70 degrees Fahrenheit. Look at the air cleaner snorkel, and you will see a small hinge pin (my wife is pointing at it). Start the engine, and look at the pin. If cool enough outside, the line in the hinge pin will move to the vertical. This means the flap on the snorkel has opened to allow for pre-heated air o enter the air cleaner.
The thermostatic valve will operate the snorkel flap anywhere between full open and full closed, according to the ambient temperature.
If the line on the hinge pin stays horizontal on cold morning start ups, then your thermostatic valve is shot, or your vacuum is not hooked up correctly.
Richard O'Brien |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2579 Location: Seekonk,Massachusetts USA
Posted: Sun Jul 17, 2022 2:07 pm Post subject: |
| Gitchigumi wrote: |
I was one of the 26 or so that viewed this post with interest as I had one functioning themostate but a functing vac can. I decided to see if I could take one apart and here is what I found.
Two parts screw out. Under the large brass insert is a small plastic check valve that sits atop a bi-metal strip with the number 20 on it. I suspect 20 stands for 20 deg.C. Under the brass tube which unscrews, is a different check valve which stradles the other end of the bi-metal strip and is made of rubber with a plastic end that sits in the brass tube. Do not try and remove this one as it appears to have been installed before the two halves of the thermostat were put to-gether.
In my case the brass tube one was coated with hardened gunk and would not float freely. A bit of WD-40 and compressed air cleaned it up nicely. I suspect the problem with most "non-functioning" thermostats is simply dirt in the system after 40 years.
You will also see from the photos, a very small hole in the top of the thermostat housing on the brass tube side. This is a bleeder hole that allows air back into the vac can once vacuum is no longer applied, allowing the flapper to release and close of the warm air inlet and allow cool air to enter the carb.
I sprayed WD-40 in both ends of the thermostat and air dried it to make sure it was nice and clean.
The brass tube screws back in pretty much flush - see pictures. You should be able to detect movement of the little check valve by blowing and sucking on it.
The larger check valve with the ball, screws in leaving about 5 threads still showing - see pictures. Assuming you are working where it is above 20C that bi-metal strip should not be flexed but flat. The check valve ball sits open just a bit at this point, allowing air to be draw through the hole in the check valve and not through the brass tube check valve. I adjusted it by screwing it in until you can only see 2 threads. I blocked off the small bleeder hole with my finger and sucked on the black plastic tube. You should be able to draw air through the brass tube. I then unscrewed the check valve body, half a turn at a time until I began to draw air freely through the hole in the ball check valve. At this point the vacuum is broken to the vac can. You will sense the check valve ball vibrating as you get to this point. I back it out just past this point.
In any event, after cleaning and adjusting as described my flapper works like it should, and that is all that matters to me.
New thermostats should still available through your local Volkswagen dealer for about $100.00 plus tax - I checked with mine. But try cleaning and re-adjusting to save yourself a few bucks. |
Nice write up.  _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
Boble Samba Member
Joined: November 13, 2005 Posts: 744 Location: Oslo, Norway
Posted: Mon Aug 08, 2022 1:19 pm Post subject: Re: Thermostatic valve in air cleaner test |
Curious about what's inside this fella, I cut one open some time ago. As you can see below, there are TWO valves inside:
1. A piston valve that controls the vacuum flow to the air filter flap
2. A ball valve that opens up when warm and thus "zero'ing" the vacuum.
There are "no serviceable parts inside". If it don't work it's probably just dirt in there. Soak in solvent and blow though it with compressed air. Test with cold air (fridge) and warm air (hair dryer).
Boble Samba Member
Posted: Mon Aug 08, 2022 1:54 pm Post subject: Re: Thermostatic valve in air cleaner test |
Hi,
The piston valve that actually controls vacuum to the air filter is not adjustable.
The ball valve is, though.
You want it to open at around 77 F (25 Celsius). I think your description above makes sense. Like this:
1. The whole unit should be at 77 F (25 Celsius). Give it enough time to reach that temp
2. Block the piston valve tube (brass) and the "small bleeding whole" beside the ball valve screw on top
3. Suck on the plastic tube with your mouth
2. Adjust the ball valve screw until you find the point where it just opens
I cannot believe that it is super critical if you don't hit exactly 77 F, after all it just regulates the air temp to the carb. |
