Transmission Leak from CV's?
Phishman068
Phishman068 is offline
PostPosted: Wed Feb 20, 2013 9:03 pm    Post subject: Transmission Leak from CV's? Reply with quote
So i'm heading to a friends this weekend to help him with a long time transmission leak he's had. It leaks from the drive cups (CV's attach to) and is pretty significant. He assures me he has purchased all the necessary parts.
I have done a search, but can't find just what's involved in repairing this problem. Getting the shafts off and rebuilding them will be no big deal for me (I seem to be doing alot of them lately...) but i've never gone deeper than that.
Any advice or sources of knowledge?
Thanks!
http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry."
Racerrojo
Racerrojo is offline
PostPosted: Wed Feb 20, 2013 9:07 pm    Post subject: Reply with quote
There's this post
http://www.thesamba.com/vw/forum/viewtopic.php?t=249639&highlight=
its an easy job with the trany out, but doable with the trany in place
Tight is tight... too tight is expensive!!!!
Too many vans and mostly all projects Smile
?Waldo?
?Waldo? is offline
PostPosted: Wed Feb 20, 2013 9:12 pm    Post subject: Reply with quote
Be sure the atmospheric bleed is not clogged or all your labors will be for naught.
Phishman068
PostPosted: Wed Feb 20, 2013 9:28 pm    Post subject: Reply with quote
Wonderful!
I'm having a bit of a senior moment and have forgotten just where the vent is on a 2wd manual trans?
I know autos and syncros.
I must be getting old.
Racerrojo
PostPosted: Wed Feb 20, 2013 9:30 pm    Post subject: Reply with quote
mine was working great... I notice 1/2 quart on the floor of my garage, from having the trany upside down on the stand while cleaning it Embarassed
?Waldo?
?Waldo? is offline
PostPosted: Wed Feb 20, 2013 9:39 pm    Post subject: Reply with quote
Phishman068 wrote:
Wonderful!
Follow the leak trail up.
?Waldo?
?Waldo? is offline
PostPosted: Wed Feb 20, 2013 9:40 pm    Post subject: Reply with quote
Arrow
syncrodoka
syncrodoka is offline
PostPosted: Wed Feb 20, 2013 11:55 pm    Post subject: Reply with quote
If your friend has a syncro there is no breather hole there.
cellerdoor
cellerdoor is offline
PostPosted: Thu Feb 21, 2013 4:48 am    Post subject: Reply with quote
Here she blows:
1986 Westy
Wildthings
Wildthings is offline
PostPosted: Thu Feb 21, 2013 5:09 am    Post subject: Re: Transmission Leak from CV's? Reply with quote
Thanks!
Is it leaking from the shaft seal behind the flange or from the CV itself? Sometime the cap inside the flange pops out (or was never installed) and gear oil will fill the CV and pour out. Either is an easy enough fix. If the cap has popped out, you might consider using Permatex or some other goop to glue the replacement in.
cellerdoor
PostPosted: Thu Feb 21, 2013 5:42 am    Post subject: Reply with quote
Heres what I discovered when I took mine part. Had a pretty good leak but cant exactly determine where it was coming from since I sent it out to rebuild.
Looks like the PO gooped it up but it was still dripping when i got it. I also have a rear main engine seal leak which was getting into the bell housing and into the starter hole and dripping out at the starter flange.
1986 Westy
srmpf
srmpf is offline
PostPosted: Thu Feb 21, 2013 7:31 am    Post subject: Reply with quote
just checked the DK from an air cooled vanagon that I have in the garage - no breather hole in there as well. Is that right?
?Waldo?
?Waldo? is offline
PostPosted: Thu Feb 21, 2013 7:58 am    Post subject: Reply with quote
No, that's not right. DK has the bleed hole as pictured above.
srmpf
srmpf is offline
PostPosted: Thu Feb 21, 2013 9:39 am    Post subject: Reply with quote
was probably too early in the morning - Andrew, you're right. checking a second time I saw the hole smack in the middle, like the one on your left in your picture.
BC Westie
BC Westie is offline
PostPosted: Thu Feb 21, 2013 5:15 pm    Post subject: Reply with quote
Is the auto breather in a similar spot on an Air Cooled auto? To clean just wipe the gunk away from the outside? My auto leaks from behind where the CV joints attach as well.
I went to replace the seals but the kit I ordered was wrong. I think mine had dust caps and an outer ring. The kit was just the outer ring so mission aborted an still leaks from time to time. What kit should I order next time? I want to correct this soon so I will have to find the breather 1st.
1980 Vanagon Cali Import 86,000Miles
1981 Vanagon (Auto) 219,000kms
1981 Westfalia (Auto) Cali Import 169,000Miles
1981 Westfalia 300,000kms
1982 Westfalia Cali Import 193,000Miles
1982 Westfalia (Auto) 205,000Kms
1984 Vanagon 306,000kms
1987 Vanagon GL 300,000Kms
Racerrojo
PostPosted: Sun Feb 24, 2013 8:40 pm    Post subject: Reply with quote
i'm about to re install the CV on one , should I just use the grease that comes with the kit, or is there something better that I can get at the FLAPS?
Wildthings
PostPosted: Mon Feb 25, 2013 4:35 am    Post subject: Reply with quote
I have found the grease that comes with the kits to be insufficient in volume, as I like to fully pack the CV and the recess in the flange. I never cared to use the grease that comes in the little packages as some of the packaged grease used to harden with time and leave the joints dry. I have just used Moly fortified #2 grease for years, usually Valvoline and have been happy with it.
Racerrojo
PostPosted: Mon Feb 25, 2013 7:29 am    Post subject: Reply with quote
Cool thanx.
I have to do 4 joints, and have 6 packages.
You would think that this things should have greaser nipples.
insyncro
Banned
insyncro is offline
PostPosted: Mon Feb 25, 2013 7:39 am    Post subject: Reply with quote
I toss the grease that comes with new CVs and clean out any that has been packed in pre assembled and rebuilt units.
Alaric has posted some really good greases.
Yup a grease needle or CV greaser is a great tool.
