SO42 corner cabinet
jpeters
jpeters is offline
PostPosted: Tue Mar 12, 2013 11:33 am    Post subject: SO42 corner cabinet Reply with quote
Did all non-walkthru 65 Westies come with the corner cabinet:
'73 Westy
'68 Westy http://www.thesamba.com/vw/forum/viewtopic.php?t=484180
'65 Westy SO-42 http://www.thesamba.com/vw/forum/viewtopic.php?t=435614
'66 Bug
'63 Bug (Big Bore 40hp)
@neverdnf on Instagram
BulliBill
BulliBill is offline
PostPosted: Tue Mar 12, 2013 11:37 am    Post subject: Reply with quote
I "think" so, but look at your rearmost yellow vinyl mattress. In that rear left corner, if there is a cut-out in the mattress for the "condom cabinet", then your Campmobile used to have one. My '67 has it...
Bill
I'm looking for these license plate frames from old Volkswagen dealerships for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
jpeters
jpeters is offline
PostPosted: Tue Mar 12, 2013 11:47 am    Post subject: Reply with quote
Mine did not come with the corner cabinet when I acquired it and I don't recall the mattress having a cut out either, but you never know when someone has redone the mattress to conform to the already missing cabinet. I also don't recall any mounting holes for a corner cabinet, but I'll have to check when I get back home.
'73 Westy
'66 Bug
kombisutra
kombisutra is offline
PostPosted: Tue Mar 12, 2013 12:01 pm    Post subject: Reply with quote
Look to see if you have screw holes for "A" and the "bolt" hole for "C". My SO44s of course were both non walk-throughs and both did have the corner cabinet. If you have the holes, it would be safe to say it used to have the cabinet. Are you sure you have a 42 instead of a 44?
jpeters
jpeters is offline
PostPosted: Tue Mar 12, 2013 12:15 pm    Post subject: Reply with quote
Yes, the plate states 42, not 44 and all of the other interior that I have resembles so42.
'73 Westy
'66 Bug
crofty
Judas of the North
crofty is offline
PostPosted: Tue Mar 12, 2013 12:16 pm    Post subject: Reply with quote
I should have bought your SO44. Thanks for bringing that up...
HamburgerBrad wrote:
crofty
Judas of the North
crofty is offline
PostPosted: Tue Mar 12, 2013 12:17 pm    Post subject: Reply with quote
You should have it.
mandraks
mandraks is offline
PostPosted: Tue Mar 12, 2013 1:23 pm    Post subject: Reply with quote
hmm,
must be getting old, but i do not remember my 9/65 westy so42 non walk through having the cabinet, nor cut-out, or i am getting old...
i doubt my wife would have been able to crawl back there with the seat up and take naps on long trips...
regards
Uli
jpeters
jpeters is offline
PostPosted: Tue Mar 12, 2013 1:31 pm    Post subject: Reply with quote
I'm guessing mine had it at one time. It has the hole for "C" but not the insert panel needed for "A." I'm assuming someone removed the panel and cabinet at the same time.
'73 Westy
'66 Bug
jpeters
jpeters is offline
PostPosted: Mon Apr 01, 2013 11:50 am    Post subject: Reply with quote
Does anyone have a picture of the actual insert panel labeled "A" in the diagram above. I think it would help me out if I could see what I'm looking for.
'73 Westy
'66 Bug
roberto
roberto is offline
PostPosted: Mon Apr 01, 2013 3:11 pm    Post subject: Reply with quote
It looks just like the close out panel on the other side behind the closet, just mirrored.
srfndoc
srfndoc is offline
PostPosted: Mon Apr 01, 2013 3:43 pm    Post subject: Reply with quote
This what your looking for?
http://www.thesamba.com/vw/classifieds/detail.php?id=1455235
jpeters
jpeters is offline
PostPosted: Mon Apr 01, 2013 3:55 pm    Post subject: Reply with quote
Yes...sort of. I do need the corner cabinet, but I also need the close out panel that is labelled "A" in the diagram above.
'73 Westy
'66 Bug
big bus mike
big bus mike is offline
PostPosted: Mon Apr 01, 2013 3:59 pm    Post subject: Reply with quote
They pop up from time to time in the classifieds. It's the mirror image of the passenger side.
View user's profile Send private message Visit poster's website AIM Address Facebook Gallery Classifieds Feedback
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Mon Apr 01, 2013 9:30 pm    Post subject: Reply with quote
You can cut that "close out" panel from a scrap of laminate. Someone here can surely make a paper template for you of their "close out" panel, either left or right.
jpeters
jpeters is offline
PostPosted: Sat Jun 01, 2024 4:57 pm    Post subject: Re: SO42 corner cabinet Reply with quote
Does anyone have a picture of the inside of the corner cabinet once the cabinet door is open? I’m curious if the side Baltic birch panel went all the way behind the corner cabinet into the rear corner or does the birch panel just meet up with the closet and it is bare metal inside the closet.
'73 Westy
'66 Bug
Clara Premium Member
Clara is offline
PostPosted: Tue Jun 04, 2024 12:44 pm    Post subject: Re: SO42 corner cabinet Reply with quote
There is metal visible when you open the corner cabinet.
If there was a panel covering that space the shelf would not fit. There is not much space between the shelf and the outer skin of the bus.
From the gallery, I searched for “corner cabinet”:
