Type 181 / 126 - Industrial heater box delete tin
Page: Previous  1, 2
ALB
ALB is offline
PostPosted: Tue Aug 21, 2012 6:27 am    Post subject: Reply with quote
durfeec wrote:
chrisdiehl wrote:
I'm glad I ran across this. I installed j tubes a couple of weeks ago and hadn't heard of these sleds until now. Stupid question.....engine doesn't have to be out to install right?
sleds are used even with factory heater boxes. they are what protect your push rod tubes. and it would be easier to install with the motor out since they bolt to the backside of the cylinder head tin. the tin that this thread is about is something different than just a sled and can be installed without removing the motor.
They do more than protect the pushrod tubes, they direct the air so it can join the airstream under the car while it is in motion. The faster the car is going, the harder it is for the expelled cooling air to join the airstream with out the sled tins and either heaterboxes or industrial tins. This layer of air under the car can be as much as 2psi higher than the air trying to exit the lower cylinder shroud area. This is why a car without the sled tins and heaterboxes or industrial tins will seem to cool okay around town but overheat at highway speeds.
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
volkaholic1
volkaholic1 is offline
PostPosted: Wed Aug 22, 2012 1:39 pm    Post subject: Reply with quote
also, if you are running the thermostat with J pipes, you MUST run all the lower tins, heater box sleds, 2 /4 lower rear air deflectors and industrial shields, or else the stat will see cooler air from below the engine and not open enough, or may not open at all = overheated engine. I've been making and selling them for years.
Volkaholic
gti1977
gti1977 is offline
PostPosted: Wed Aug 22, 2012 9:55 pm    Post subject: Reply with quote
I`m restoring and tuning type 4 2,0 wich have exchaust ports down of the heads.I plan to not use heater boxes.Are exist tins for this engine for J-tube use ?
jeff68
jeff68 is offline
PostPosted: Thu Aug 23, 2012 6:02 am    Post subject: Reply with quote
FYI - The Bergs also sell the industrial tins.
Dwayne_71SB
Dwayne_71SB is offline
PostPosted: Thu Aug 23, 2012 7:05 am    Post subject: Reply with quote
I seriously considered buying yours, and would have if it weren't for the fact that I enjoy making things myself. Yours are definitely very nice and worth the money for anyone who doesn't want to DIY. Smile
These are the ones I made, ended up painting them black to keep them from rusting:
'71 Super Beetle
ALB
ALB is offline
PostPosted: Thu Aug 23, 2012 8:24 am    Post subject: Reply with quote
Nicely done, Dwayne!
71beigeSB
71beigeSB is offline
PostPosted: Tue Sep 11, 2012 4:41 am    Post subject: Reply with quote
Our 71 super is only go'n to be a weekendend ride & Texas has rather mild winters.
What pieces do I need to change to go with the Jtubes & Ind tins? Heard I need to change/modify the doghouse. The motor is still out while we did some body repairs.
The deeper I dig the Worse it gets.....
71 Super Beetle stock 1600 dp
rattle can Pink & Black
View user's profile Send private message Yahoo Messenger Facebook Gallery Classifieds Feedback
AlteWagen
Troll
AlteWagen is offline
PostPosted: Tue Sep 11, 2012 9:26 am    Post subject: Reply with quote
The industrial tins just fill the hole left when the heater box is removed. They are held in place with two screws where the heater box attached to the sled tin. No modification to the doghouse is required.
Doodoob
Doodoob is offline
PostPosted: Sun Sep 23, 2012 11:16 am    Post subject: Reply with quote
I recently made up my own lower tins as I am running an old school S&S Header and it runs even closed to the push rod tubes and more inboard than most. So using the stock sleds and tins wasnt realy an option without a lot of cutting.
[/img]
Yarkle Premium Member
Yarkle is offline
PostPosted: Tue Dec 25, 2012 6:06 pm    Post subject: Reply with quote
Could you run these with the heaterboxes? would it make any difference?
75smith
75smith is offline
PostPosted: Tue Dec 25, 2012 6:35 pm    Post subject: Reply with quote
these replace the heater-boxes, so if you have heater-boxes you don't need/can't run these
these fill the void that a heater-box would fill normally
My 1975 Beetle Build Updated 8-21-12
My engine build
Yarkle is offline
PostPosted: Tue Dec 25, 2012 8:26 pm    Post subject: Reply with quote
ok, cool..thanks. Thats what I thought!
clonebug
clonebug is offline
PostPosted: Tue Mar 12, 2013 12:41 pm    Post subject: Reply with quote
I made mine from some cheap roofing flash material. It's easy to cut and bend to whatever shape you need.
Flashing
Trim it down
Find a way to bend it...
Trim it and bend to fit.
I use a small one inch by two inch piece of the waste and make a 90 degree bend in the middle and drill a hole to use it as a stop to hold the bend.
Trim the length to fit....
Test mount and drill the holes to mount the existing tin and you have sleds for about $4.00 in parts and a half hour or so labor.
richardcraineum wrote:
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah ..
cbeck wrote:
His user name in a previous life was dick head.
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
mrmarcdude
mrmarcdude is offline
PostPosted: Fri Apr 12, 2013 5:26 pm    Post subject: Reply with quote
Altewagon, this thread rocks! I have recently been thinking of fabricating some myself, and your plans are perfect. It gets pretty hot here in California, and I would love to do everything I can to ensure that my motor stays nice and cool. Thank you! Cool
- Marc M.
-65 Beetle -1600dp-
Mikedrevguy
Mikedrevguy is offline
PostPosted: Mon Apr 10, 2017 5:43 pm    Post subject: Re: Type 181 / 126 - Industrial heater box delete tin Reply with quote
Better late than never?
Finally got round to fabbing some up.
First attempt helped me realize that to accommodate the AJsims headers I ran, I had to cut the sleds.
Round two fit better. Plus, I have a set ready for stock sleds, if/when I get round to that.
Not pretty, but, should do the trick.
74 1303 (RevBug): plan for German Look
76 914 with 2260
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!!
daos
daos is offline
PostPosted: Sat Jun 01, 2019 12:40 pm    Post subject: Re: Type 181 / 126 - Industrial heater box delete tin Reply with quote
here's my contribution to j-tube heater box delete cooling tin goodness, this is for a 1969 type 3.
made in 1mm alu. drilled/tapped the 2 round protrusions on the heads. it's almost as if they were made specifically for this purpose.
been running a little hot without these, hope they help.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Jun 01, 2019 12:47 pm    Post subject: Re: Type 181 / 126 - Industrial heater box delete tin Reply with quote
I'm using the real deal.... not that hard to find.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
jason
jason is offline
PostPosted: Sat Jun 01, 2019 6:37 pm    Post subject: Re: Type 181 / 126 - Industrial heater box delete tin Reply with quote
Daos’s look better and screw to head, better design.
daos
daos is offline
PostPosted: Sat Jun 01, 2019 11:57 pm    Post subject: Re: Type 181 / 126 - Industrial heater box delete tin Reply with quote
i'll take that Cool
a nice bit of alu is hard to beat though. and there's also the satisfaction of doing something yourself, when you can.
Page: Previous  1, 2
Page 2 of 2
