ncstagger Samba Member
Joined: June 04, 2010 Posts: 284 Location: Fayetteville, NC
Posted: Wed Mar 27, 2013 5:47 am Post subject: Distributor advice needed |
I'm currently running an 009 with a 34 PICT3 on a 71 AE 1600.
Ran across a 205Q DVDA which is the correct stock distributor for my bus and was having it rebuilt but have hit a snag. It is apparently missing an advance spring. The guy doing the rebuild says he could swap in a spring or even the whole adv mechanism out of a similar model. Is this a good idea?
I want to have either the correct DVDA or an SVDA as my primary distributor and keep the 009 as a backup. Was going to go for the SVDA 034 before I ran across the 205Q. Any advice is appreciated. _________________ 71 Westy Tintop - 1600 DP 34PICT3/009 - Pastel White
Resto thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=549162
"Take your most realistic time frame and dollar amount.. then add half of that amount. When you get that total... double it. Only then will you be in the ballpark." - sofaking |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42999 Location: at the beach in Northern Wokistan
Posted: Wed Mar 27, 2013 6:26 am Post subject: |
wait for one that works. Keep the can if both sides are good. If it is missing a spring it has been apart before. There is no way he can match the curve it came with. Save the old one for parts. I like the idea of using the parts that it was designed with if you can find ones that all work. My old 1971 with the DVDA ran like a charm when it was tuned right. You can use the 009 until you find one. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
Posted: Wed Mar 27, 2013 6:45 am Post subject: |
Sounds like solid advice, thanks. _________________ 71 Westy Tintop - 1600 DP 34PICT3/009 - Pastel White
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53264 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Mar 27, 2013 7:47 am Post subject: |
Do some research in the distributor list on Oldvolks, some auto Cali bug distributors have very similar mechanical advance curves, with your vacuum can it is possible to build yourself a frankenstien facsimile. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Mar 27, 2013 8:51 pm Post subject: |
Thanks BD. Looks like both 205D and 205AH have the same mech advance curve data listed as the 205Q. Does that mean the adv mechanisms interchange? _________________ 71 Westy Tintop - 1600 DP 34PICT3/009 - Pastel White
Posted: Wed Mar 27, 2013 10:03 pm Post subject: |
Someone like Glenn would have better knowledge of that but IMO it's much closer than many of the other curves, like I said....frankendistributor that's really close  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Mar 27, 2013 11:54 pm Post subject: |
| ncstagger wrote: |
| Thanks BD. Looks like both 205D and 205AH have the same mech advance curve data listed as the 205Q. Does that mean the adv mechanisms interchange? |
I have swapped parts between many Bosch distributors, they will typically interchange. You want to limit the amount of mechanical advance, no more the 20° is usually all you want. |
