Dead mouse in Vanagon vent system!!!!! Ughhh!!!
ourv12
ourv12 is offline
PostPosted: Fri May 17, 2013 1:16 pm    Post subject: Dead mouse in Vanagon vent system!!!!! Ughhh!!! Reply with quote
How in the heck did a mouse manage to get into the vents? Is there a way to get in somewhere other than from inside the van? The van was parked with the doors and windows shut! I cant even turn the blower on it smells so bad! I saw signs of nesting material in the wire harness opening at the drivers side door jam. I cant see how it got in from outside? Are there any openings to the interior from under the van?
Vango Conversions
Vango Conversions is offline
PostPosted: Fri May 17, 2013 1:24 pm    Post subject: Reply with quote
Yeah, it's been talked about before. the battery vent hole is an entry point and so is the front air intake behind the grill. even if the front screen isn't broken it has gaps on the side. Mice can get in through the smallest openings.
Bubusse
Bubusse is offline
PostPosted: Fri May 17, 2013 2:19 pm    Post subject: Reply with quote
It only takes a hole the size of a dime, so yeah... don't worry, they can get inside the van and almost anywhere. There are many threads about this. Best way to avoid them : cats. I also put moth balls underneath the van when it's in storage. Been lucky so far, but I think it's mostly thanks to my cats !
89 manual Vanagon GL Wesfalia
gbrandt
gbrandt is offline
PostPosted: Fri May 17, 2013 2:27 pm    Post subject: Reply with quote
You can put steel wool into the holes in the battery compartment. I've seen pictures of someone that put a steel mesh behind the grill for the air intake.
I put peppermint oil onto cotton pads and place it in a jar with holes in it. Then place that in the van. The van smells like peppermint and mice hate that smell so never go into the van.
Haven't had a mouse in the van since I did two of the three things mentioned above (didn't put steel mesh over the air intake).
Before that we had a mouse fall down the pillar behind the drivers seat. The mouse came through the tunnel in the door and fell down the shaft. Of course it could not get out and died a horrible, stinky death. Gross. I feel your pain.
Gregor
'Lucky' our 1987 Red Westy, ASV 1.9 TDI, Peloquin differential
We driven in 49 countries and 5 continents to date
Canada to Argentina and back, January 2015 to April 2017.
Canada to Europe and back (including Turkey, Morocco and Iceland), October 2017 to January 2020
Currently back home.
https://www.instagram.com/live.travel.play/
http://livetravelplay.ca
dobryan
dobryan is offline
PostPosted: Fri May 17, 2013 3:07 pm    Post subject: Reply with quote
Use hardware mesh (1/4 inch openings) and silicone glue (or glue gun) it into place on the openings around and in front of the fresh air intake behind the grill, in the pillar openings underneath and the battery vent openings, any any other place of entry way you can find.
Dave O
Join the Vanagon Rescue Squad on the VanAlert app.
http://vanalert.com/
Building a bus for travel in Europe
BoneMachine
BoneMachine is offline
PostPosted: Fri May 17, 2013 3:46 pm    Post subject: Reply with quote
Our '83.5 was parked for a couple of years and became completely fouled by mice. Totally disgusting. I traded it toward our current van. We discovered Fresh Cab;
http://www.earth-kind.com/products/repellent/
We put some in the dash, one in the jump seat and another in the rear cabinet. The stuff seems to really help and it has a pleasant scent as well.
Good luck
'85 Wolfsburg Edition Westfalia Weekender, Zetec #36, w/ Peloquin TBD
'83.5 Westfalia, full camper (we'll never forget you)
randywebb
randywebb is offline
PostPosted: Fri May 17, 2013 3:57 pm    Post subject: Reply with quote
1. put stainless steel wool into the hole below the RH side battery compartment
- just 1 hole correct? and only for the starting battery, not the aux. battery compartment?
2. watch out when you have any door open - I had a desert mouse (Zapus?) invade my '73 Bus once upon a time
3. the sides and/or top of the front vent by the radiator - this is supposed to be covered by that plastic piece with the square holes in it
- what do people suggest here? metal screening?
4. & etc. what other entry points are there??
Dead mice or live mice - they all can and do carry diseases; and some of the diseases can be transmitted thru the air, or by a flea or tick jumping onto you or your leg then crawling up. Never touch one, and use bleach on the area it was after you get rid of the carcass.
I also suggest this be made into a sticky after it is fleshed out
1986 2.1L Westy 2wd Auto Trans.
Gauche1968
Gauche1968 is offline
PostPosted: Fri May 17, 2013 8:54 pm    Post subject: Reply with quote
Wear a mask that is at least N100 and wear gloves when cleaning up mouse nesting material or dead mice. Spray it down with bleach and let it set for an hour before attempting to clean it up.
With increased awareness of the dangers of Hantavirus, many insurance companies will now total older cars that have been infested with mice rather than pay someone to properly remediate them. Sad
1984 Vanagon GL
1984 Vanagon Westy
Danwvw
Danwvw is offline
PostPosted: Fri May 17, 2013 9:12 pm    Post subject: Reply with quote
I Get them in my Subaru if I don't keep d-CON in the shed during winter months, They seem to like to nest on the cabin filter. After you clean out the mice and whatever they added to your VW use Lysol deodorizer to freshen up the car. If the smell persist you have more dead mice that have not been found. Best to get rid of the mice in the Garage all together as they can chew up a wire somewhere inside the car and it will cause something to go wrong when you least expect it.
tam_shops
tam_shops is offline
PostPosted: Sat May 18, 2013 5:23 am    Post subject: Reply with quote
Do you have pictures of where I need to put the steel wool? Or the Bentley page#? I'd rather prevent than clean up!
Gregor
I once watched a mouse go completely flat and slide between the floor board and the floor. Wouldn't have believed it if I hadn't watched it more than once. Since I was working graveyard, actually thought I was hallucinating until I saw it two nights in a row!
1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885
randywebb
PostPosted: Sat May 18, 2013 1:28 pm    Post subject: Reply with quote
crawl under the pass. seat and look for ~~ 3" vent hole directly behind the seat area
do NOT use regular steel wool - it will rust and spread
get brillo or other stainless steel cleaning scrub pad or brass and shove it up in there
tam_shops
PostPosted: Sat May 18, 2013 1:43 pm    Post subject: Reply with quote
Will do, thank you! And, thank you for the specific thing I need to use, would so have used steel wool!
tam
Making it special:
dobryan
dobryan is offline
PostPosted: Sat May 18, 2013 3:08 pm    Post subject: Reply with quote
You can also use hardware cloth, about 1/4 inch mesh that you can glue over the opening. I use this everywhere to keep the buggers out.
http://www.lowes.com/pd_90-16418-122410_0__?productId=3160773
Dave O
Wildthings
Wildthings is online now
PostPosted: Sat May 18, 2013 4:19 pm    Post subject: Reply with quote
I have just filled the gaps on my Vanagons with polyurethane caulk.
ourv12
ourv12 is offline
PostPosted: Sun May 19, 2013 7:38 am    Post subject: Reply with quote
Thanks for all the replies! I now know all the areas to screen. Now I wish I knew how to get the dead mouse out!! Do I need to pull the dash? Can I somehow disassemble the ducting to clean it out without removing the dash? I know for sure its in the front air ducting cuz when I turn on the blower it smells foul....really bad.
Wildthings
PostPosted: Sun May 19, 2013 9:57 am    Post subject: Reply with quote
All depends on where the mouse is. If he is in one of the flex hoses that run to the side vents you are in luck as they can be removed. If he is in the main heater box you might be able to suck him out with a shop vac through the ports for the side vents, but will probably in the end have to pull the dash and take the heater box apart.
