79 sage green/mexico beige kombi
Page: Previous  1, 2, 3  Next
1967250s
1967250s is offline
PostPosted: Sat Jun 29, 2013 4:14 pm    Post subject: Reply with quote
Maybe just new cv boots, cv's are tough, don't replace unless they "clunk". definite cleaning needed, though.
consvws Premium Member
consvws is offline
PostPosted: Sat Jun 29, 2013 7:50 pm    Post subject: Reply with quote
curtis4085 wrote:
If the engine cold then that thermostat is toast!!
Get a new one!! They are forsale in classifieds. New!!
Your Plugs seem to show your runnin lean?? I would get her sniffed and adjust mixture accordingly.
Yeah, the thermostat is goners! I just went & peaked at it now that it's cold & it's blown out for sure.
I'm going to set the timing then possibly drive the bus down to a local tune-up shop & see if they can hook it up to there diagnostics machine, but i did want to get it cleaned up and somewhat respectable looking before i drove it in.
As for the CV's, what do you think? They aren't making noise now that i can tell, but these were in the back of the bus when i got it. I'm going to swap the boots for sure anyway. Maybe i'll just keep these on the shelf for a rainy day.
consvws is offline
PostPosted: Mon Jul 01, 2013 8:39 pm    Post subject: Reply with quote
Cleaned up the under side of the engine today. I scraped the heater boxes & tin down with a razor blade then rubbed them down with some lacquer thinner & painted them.
Then i drove the bus up the ramps to run the gas all down to one side while i replaced the rest of the fuel lines.
Looks pretty good under the pedal cluster pan too!
And, one last pic before the the day is over.
consvws is offline
PostPosted: Tue Jul 02, 2013 2:55 pm    Post subject: BA-6 gas heater Reply with quote
pulled the belly pan off today. Here are a few pics of the gas heater setup.
and here is the pan after i hosed it off
1967250s
1967250s is offline
PostPosted: Tue Jul 02, 2013 6:14 pm    Post subject: Reply with quote
Looks like you have your work cut out for you. Still, looks pretty damn good.
consvws is offline
PostPosted: Fri Jul 05, 2013 8:15 pm    Post subject: Reply with quote
Replaced this oil soaked OPS, and was hoping that it was what was leaking, but i think oil cooler seals are next.
Then I put together my new CV boots. Ended up using my old CV's cause they were lookin' good & haven't been making noise.
Outlaw70
Outlaw70 is offline
PostPosted: Tue Jul 09, 2013 10:55 pm    Post subject: Reply with quote
That thing is looking good man! ill have to drive up and check it out..
85 Vanagon
consvws is offline
PostPosted: Thu Jul 11, 2013 3:55 pm    Post subject: Reply with quote
Yeah, cruise up & check her out anytime.
consvws is offline
PostPosted: Thu Jul 11, 2013 4:03 pm    Post subject: Reply with quote
Tore the engine down a bit so i could replace the oil cooler seals & weld up the exhaust pipes (hacked out the CAT). I ended up putting it all back together minus the AC for now, but she sounds much better & doesn't leak oil anymore Very Happy
and while i was at it, replaced the old petrified dipstick boot with a new one
consvws is offline
PostPosted: Tue Jul 16, 2013 7:56 pm    Post subject: BA6 Belly Pan Reply with quote
belly pans all sandblasted & painted Cool
Zhaph
Location: When you're talking home, you mean the Old Dominion!
Zhaph is offline
PostPosted: Tue Jul 16, 2013 8:25 pm    Post subject: Reply with quote
Just checked out this thread for the first time today; awesome bus and great pictures! Looks like your restoration is going really well; your attention to detail while cleaning and painting is admirable. Keep on keeping on, and nice work! Smile
1974 Westy - REBUS
catchrebus.blogspot.com
notchboy
notchboy is offline
PostPosted: Tue Jul 16, 2013 8:27 pm    Post subject: Reply with quote
^^DAYUM Sexy Work Cool ^^
Nothing like taking the old OG and making it new....Progress on the BA6?
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
eche_bus
eche_bus is offline
PostPosted: Tue Jul 16, 2013 8:33 pm    Post subject: Reply with quote
Wow Smile This is really coming along nicely! Great work! What did you use for paint on those pans?
consvws is offline
PostPosted: Tue Jul 16, 2013 9:44 pm    Post subject: Reply with quote
Yeah, the bus is coming right along. My friend gets all the credit for the pans, he paints for a living & i'm known to leave runs in my paint Laughing I think he used epoxy primer & clear. They do look pretty sweet though huh!
As for the BA6 i haven't done much. I pulled off the exhaust pipe from it & a buncha rust came out. Also found a tear in the rubber boot thingy right where the wires are sticking out of it. You can see in the right side of this pic
I think i'm going to just pop the whole thing out of there and try to make it run on the bench.
consvws is offline
PostPosted: Fri Jul 19, 2013 11:39 am    Post subject: Reply with quote
Decided to replace all these crispy old vacuum lines & in the process found a big leak in the tube going to the aux. air valve. The tube was like what i use on my fish pond pump & was barely zip tied on there.
consvws is offline
PostPosted: Wed Aug 07, 2013 6:56 pm    Post subject: Reply with quote
Pulled the gas heater, and i'm going to see if i can fire it up this week.
cool old eberspacher fuel pump
here is the ignition coil
and here is where fuel meets up with spark & makes fire hopefully Laughing
I also gutted the bus back out to clean it up some more
sanded down the cb steps a little & painted them with some Rustoleum green paint i had laying around
Then i hammered out a the little dent in the side from under the back seat & tatted it up with some of that paint too. Not a perfect match but it'll work until i get some paint mixed up if i ever fix the nose up all nice.
consvws is offline
PostPosted: Thu Aug 15, 2013 2:45 pm    Post subject: GAS HEATER!!!! Reply with quote
Got the gas heater laying here. The fuel pump spits gas, i've got a bunch of wires & i was hoping to make a quick wiring harness so i can make it run. Do i need to remove the switch from the dash & all the wiring loom to hook this up proper, or does anyone have a simpler way to bench test them? I found some black & white wiring diagrams that are pretty hard to figure out.
consvws is offline
PostPosted: Mon Aug 19, 2013 8:52 pm    Post subject: Reply with quote
front pedal cluster pan back on, some more cleaning the under chassis, and the scrubbed the floors down
1979westie
1979westie is offline
PostPosted: Mon Aug 19, 2013 9:24 pm    Post subject: Reply with quote
I love you guys out in Oregon....you just happen across an old bus that looks like it has been in a ditch for 20 years, pull it out and with some elbow grease find the original paint under the wheel arches to be far better than my bus has ever looked. You have no idea (or maybe you do) what it is like to live on the east coast where rust eats these things alive.
Will someone please keep an eye out for me for a 78-79 deluxe westy out there? It can be ratty, no engine, no trans, no interior...just a clean, rust free body and beam. I'll toss in a finders fee too. Wink
Great bus and good luck!
Your car may do 0-60 in under 5 seconds, but can it sleep 4 and cook a meal?
1979 Deluxe Campmobile (quickly rusting away)
33K miles when bought, now at 61K
Proud Member #2 SBS (Stock Bus Society)
ejon
ejon is offline
PostPosted: Mon Aug 19, 2013 9:56 pm    Post subject: Reply with quote
Did you forget where oregon is ? like west coast.
That big ol ocean out here is not fresh water. What we don't have is salted hyways. it freeze's or snows we're just SOL. The plus here is the rusted cars of any brand, come off the coast. There's a large mountain range within a mile of the ocean, which blocks the salt air.
so 10 miles inland and your out of the cancer zone.. but the rain .. these buses here just like you, when they sit the windshield, floors rain gutters so on get rusted out just like any where else
Page 2 of 3
