Identify this Part.
Page: 1, 2, 3  Next
greebly
greebly is offline
PostPosted: Mon Jul 29, 2013 7:50 am    Post subject: Identify this Part. Reply with quote
Found this hose , it goes through the rear frame member on the right side at the rear trailing arm. There is a grommet to prevent the hose from rubbing. I think it might be a vestige from the old motor prior to the engine conversion.
Ian
Ian is offline
PostPosted: Mon Jul 29, 2013 7:53 am    Post subject: Reply with quote
That hard plastic elbow indicates that is a vent tube from the bottom of a charcoal canister.
All your Buses are belong to us.
Love and good roads!
"I got the feeling that he and his buddies stay at the shop super-late every night wrenching on project VWs just for the sheer joy of it."
IN LOVING MEMORY OF ROB CRESS 1968-2012
View user's profile Send private message AIM Address Facebook Instagram Gallery Classifieds Feedback
greebly
greebly is offline
PostPosted: Mon Jul 29, 2013 8:03 am    Post subject: Reply with quote
Thank you Ian. I was pretty sure it was part of the old system. There should be a sticky titled "Name This Part" It would be entertaining and informative.
djkeev Premium Member
djkeev is offline
PostPosted: Mon Jul 29, 2013 8:33 am    Post subject: Reply with quote
That is part of the fuel tank venting system........ Not the engine. Even if you had an engine swap, you still have the charcoal filter for venting. I'd reinstall it as it should be.
Inside the Right Rear Wheel area.........
Dave
Ghia
Vanagon
Beetle
greebly
greebly is offline
PostPosted: Mon Jul 29, 2013 8:45 am    Post subject: Reply with quote
The charcoal canister is missing. I had Stephan convert the engine, he may of relocated it.
Thank you for the time to take some excellent pictures djkeev!
greebly
greebly is offline
PostPosted: Wed Feb 11, 2015 2:41 pm    Post subject: Reply with quote
I found a box of parts and have identified some of them as MK IV VW stuff, and some Vanagon items. I have not identified these parts. Any ideas?
Part number listed on item as 06A103 500
No part number on part, there is a post on one corner.
oil pickup tube, but for what engine?
no part number
greebly
greebly is offline
PostPosted: Wed Feb 11, 2015 2:59 pm    Post subject: Reply with quote
These are definitely Vanagon parts.
listed as :
Manufacturer: Volkswagen
Part Number: 255-035-479
Part: BAL. PEACE
And this piece is listed as a Vanagon camper cap?
#255 843 188
syncrodoka
syncrodoka is offline
PostPosted: Wed Feb 11, 2015 6:34 pm    Post subject: Reply with quote
255-035-479 Looks like the base for the rear speaker pods on non A/C equipped vans.
255 843 188 There is a rubber bumper strip that covers the upper slider door track and that piece finishes off the rear of it. My non campers have it.
eeebee Premium Member
eeebee is offline
PostPosted: Wed Feb 11, 2015 6:40 pm    Post subject: Reply with quote
That's the bracket for the ECU/Fuel pump relay box
Eric
1987 Vanagon Wolfsburg Special Edition
GoWesty 2.3
Democracy is the recurrent suspicion that more than half of the people are right more than half of the time.
greebly
greebly is offline
PostPosted: Wed Feb 11, 2015 6:42 pm    Post subject: Reply with quote
Nice call syncrodoka, I will try to locate the location of the cap tomorrow and put it on.
greebly
greebly is offline
PostPosted: Thu Feb 12, 2015 2:05 pm    Post subject: Reply with quote
another great call eeebee, thanks! You guys amaze me with your spatial recognition and memory. I was left with a box of parts after the conversion. I will post some of them on the karma thread once everything is identified.
greebly
greebly is offline
PostPosted: Thu Feb 12, 2015 2:16 pm    Post subject: Reply with quote
Thanks Syncrodoaka , that is where it went.
I found some clamps that I have no idea where they go. the look like retaining clamps for a cable?
syncrodoka
PostPosted: Thu Feb 12, 2015 5:53 pm    Post subject: Reply with quote
Middle seat mount hardware.
greebly
greebly is offline
PostPosted: Thu Feb 12, 2015 5:56 pm    Post subject: Reply with quote
I realized as soon as I read your post, yep, I have no middle seat, I removed the tracks. And the brackets must of been removed at the shop and thrown in the box. Thanks again.
xflyer
xflyer is offline
PostPosted: Tue May 05, 2015 4:47 pm    Post subject: Reply with quote
FYI! The hose in greebly's orig post is probably part of cost cutting on VW's part. That is a vent for the EVAP charcoal canister. In '87 and older Vanagons that hose went back into the engine compartment and hooked up to the clean side of the air filter housing.
Hose connection is at end of tape measure on an '84.
On the '88 and later when VW cheaped out on buying 4' of hose they just stuck that into the frame with a rubber grommet.
Whenever the engine is above idle the EVAP valve opens and air is drawn into the bottom of the charcoal canister through that hose.
No problem? That is right next to the wheel and if you do any driving on dirt/gravel/no roads dirt will go in there also. There is a small filter in the bottom of the canister which can get packed with dust/dirt. Then the pressure in the fuel tank will be drawn lower than atmospheric. The top of the tank can get pushed down until the van is stopped. The EVAP valve is closed at idle, no more connection to the intake manifold.
The top of the tank pops back up to normal, CLUNK.
I fixed mine by buying another charcoal canister from a junk yard and ran a hose from that bottom fitting into the engine area. Hooked it up to a aftermarket crankcase breather filter made for motorcycles and hot rods.
No trouble in over 15 years.
I don't think I have to mention that it took a looong time to get this figured out.
I can post a photo of the 'fix' in my '89 if anyone needs it.
jyck
jyck is offline
PostPosted: Mon Jun 15, 2015 8:43 pm    Post subject: Reply with quote
Found this while under my van tonight. It's a black box with an exposed nipple sticking out behind the spare tire carrier on the driver side.
What is this and is something supposed to be connected to it?
1985 Vanagon GL Westfalia 1.9L Watercooled Automatic
Skidub
Skidub is offline
PostPosted: Mon Jun 15, 2015 9:13 pm    Post subject: Reply with quote
EGR / oxygen sensor mileage counter. 90.15 in the Bentley. Looks like your speedo cables bypass it now, which I believe is just fine. Others I am sure know more than I.
86 Syncro GL Tin Top
Subaru 2.5L Swap
Rblt Transaxle w/ R Locker + Decoupler
jyck
jyck is offline
PostPosted: Tue Jun 16, 2015 5:30 am    Post subject: Reply with quote
Wow, Thanks!
Did you already know what this was and looked up the page # in the Bentley or was there some way you looked it up directly in the Bentley and found out what it was?
Trying to be more self-sufficient....
Gnarlodious Premium Member
Gnarlodious is offline
PostPosted: Tue Jun 16, 2015 6:33 am    Post subject: Reply with quote
There is a dedicated discussion for this topic, lets not continue this duplicate:
http://www.thesamba.com/vw/forum/viewtopic.php?t=515977
Vanagon 83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD.
Campton Slow
Campton Slow is offline
PostPosted: Tue Jun 16, 2015 6:54 am    Post subject: Silver hole/ring in dashboard next to air controls Reply with quote
I've seen this on a couple dashboards, but never really knew what it was for. Best guesses so far are an antenna for some reason, or a socket for a map light (thanks to detroitzoran on reddit), but I can't find a mention of that light anywhere.
Page: 1, 2, 3  Next
