Westy's with Dormobile Roof
Rippers
Rippers is offline
PostPosted: Wed Jun 12, 2013 1:22 pm    Post subject: Westy's with Dormobile Roof Reply with quote
I have a 1970 LHD tintop Westy and the Family have out grown it! The kids are too big to share the cot now Laughing
I really like the bus and have done a lot of work to it and the kids and wife are sentimental about it so its not going!
I had read about Westy's that had Dormobile roofs fitted as an option from new and I really like the Dormobile roofs and when one popped up for sale I jumped at it and picked it up last night!
It came from a RHD complete with the roof cut, both bunks, all the metal frame, wooden battens, canvas, hoops, shaving mirror, lights & fittings, interior trim parts the lot. It needs repairing on the fibre glass cap and both of the opening vents are missing, the roof canvas is surprisingly good and it lifts up and down fine.
Now from the research I done over the last 24hrs I worked out out that the Dormobile buses had the roof mounted a lot further forward like the one on my transit vans roof rack, but Westfalia fitted them further back almost inline with the B-piller. I'd like to get this to look as factory as possible so if anyone one could get me some measurements of one of these uncommon conversions I'd really appreciate it
First question/problem I have thou is the position of the sink units vent (stink tube) which come out of the roof in a position which I would say would be under the roof cap possibly even under the canvass.
I haven't yet found pictures of a Westy with Dormobile roof that has the sink unit can anyone advise? I could remove it I guess as it seems unnecessary anyway?
Picture of my van and the reason I need more room! lol
busdaddy
busdaddy is offline
PostPosted: Wed Jun 12, 2013 2:49 pm    Post subject: Reply with quote
There's some good pics in this thread, look carefully in the backgrounds.
http://www.thesamba.com/vw/forum/viewtopic.php?t=539958
Слава Україні!
jakokombi
jakokombi is offline
PostPosted: Wed Jun 12, 2013 7:31 pm    Post subject: Reply with quote
I too am adding a Dormobile top to a Tin Top.
A few years ago I bough a rotted Westy with a Dormobile top that I am using for parts.
The top is placed about even with the slider door.
I can get you the exact measurements tomorrow morning when I get home from work.
My donor bus was a 69' and had no sink vent, I'm not sure if 70's had them either.
70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja
grandpa pete
grandpa pete is offline
PostPosted: Wed Jun 12, 2013 8:48 pm    Post subject: Reply with quote
The sink vent is totally unnecessary Shocked ...It was put in ONLY to comply with California"s building codes for "mobile homes" Confused ...If you have a working inline trap under your sink you can't get any toxic fumes from your grey water tank.
I have cut the roof off a bus and dropped it on another...not as big of a challenge as you might think
trim off the old roof leaving two inches on the back and sides ,up to the front door post,cut straight across from door post to door post leaving the original roof over the front seats...I cut the outer lip off the "new"top roof gutters and dropped it into the original gutter(200 holes plug weld the new top to the old along the flat bottom of the gutter)
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
jakokombi
PostPosted: Wed Jun 12, 2013 11:30 pm    Post subject: Reply with quote
Westfalia used sunroof busses for early bay, pop top, conversions. However, they used a regular Kombi when installing a Dormobile top, so no need to graft on a whole new top. Just cut a hole and drop the frame in. Very Happy
I plan to install belly pans, like my sunroof Kombi has, although Westy did not do this.
70 Sunroof Kombi
73 Thing
72 Baja
Bulli Klinik
Bulli Klinik is offline
PostPosted: Thu Jun 13, 2013 6:22 am    Post subject: Reply with quote
Westfalia Dormobiles most definitely had belly pans. The SO-69 conversions, of which the Dormobile top was one of the options, was also available with a sink. No vent is present on the sink with a Dormo top.
You are correct about the placement of the top on Westy's, The frame goes right up to the overhead support above the B-pillar. Martin Walter built VW Dormies moved the top forward to vent the cooker located behind the passenger's seat.
Looks like a nice Bus for the conversion. Belly pans will be a must as the hole in the top is BIG.
Mike K
Bulli Klinik
Colorado Springs
jakokombi
PostPosted: Thu Jun 13, 2013 1:59 pm    Post subject: Reply with quote
Measuring from the widest part of the forward roof support, the hole is cut 10mm rearward of the flange (where the flange is glued to the top).
70 Sunroof Kombi
73 Thing
72 Baja
Rippers
Rippers is offline
PostPosted: Mon Jun 17, 2013 8:18 am    Post subject: Reply with quote
Hi, thanks for the measurement but I am having a bit of trouble understanding which bit you are talking about Embarassed any chance of a picture?
Rippers
Rippers is offline
PostPosted: Mon Jun 17, 2013 8:19 am    Post subject: Reply with quote
Found a few spare minutes to have a play with the new roof and inspect the damage
Roof cap need refinishing and the support where the tape is if broken so needs fibre glass repairing
Canvas is actually ok but too ratty for me, Pretty sure I'm going to change it
Hoops look ok
Top curtain rail is missing
Put a small amount of lube on the bunks and they opened and closed fine both sides
Bunks where ok ish but too ratty again so I'll replace them too
I think one of the springs has snapped
Going to try and keep this original sticker
So next job with be dismantling the entire roof
jakokombi
PostPosted: Mon Jun 17, 2013 10:24 am    Post subject: Reply with quote
O.k... when you remove the plywood roof panels from your Tin Top's interior, you will find a support that crosses the roof just behind the front doors. The hole is cut 10mm back from the flange where this support is glued to the roof.
I could get a pic later.
70 Sunroof Kombi
73 Thing
72 Baja
Rippers
Rippers is offline
PostPosted: Sat Jun 29, 2013 9:43 am    Post subject: Reply with quote
Made a bit more progress with the roof, some of the screws are rusted badly and where a bugger to undo.
Sorry for the bad quality pics they looked better on the phone at the time.. must have been the dust in my eyes Laughing
Removed the alloy frame holding the canvas on the roof cap
Roof cap off
Bunks and hoops removed
Roof cap lifting assembly, sadly one of the springs has snapped to will need replacing
After some advise from those with Dorma roofs or that have restored one before.. do I cut the hinge mounting plates out of the roof incase they had gone rusty?
I think as I'm going for a fairly stock look I'm going to replace the canvas with 13mm Red and White Candy like what was on there
Sallyvan
Sallyvan is offline
PostPosted: Mon Aug 19, 2013 11:39 am    Post subject: dormobile roof Reply with quote
Just removed the roof on my 71 dormobile as the final stage on the refurb. One of the plates had completely rusted and the fibre glass cracked , so I took a chance and cut the fibre glass away from the other two and found they had both rusted into oblivion. I would recommend cutting the old ones out and replacing them.
Sallyvan
Sallyvan is offline
PostPosted: Fri Aug 23, 2013 12:18 pm    Post subject: Reply with quote
Found this if it helps
http://forum.earlybay.com/viewtopic.php?f=4&t=31348
richparker
richparker is offline
PostPosted: Fri Aug 23, 2013 10:28 pm    Post subject: Reply with quote
Just get an add a room. Westy or bus depot brand. That's my plan. A ton of less work and keeps you bus in tact
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
Rippers
Rippers is offline
PostPosted: Fri Aug 30, 2013 6:13 am    Post subject: Reply with quote
FAO of Westy/LHD Dormobile owners.. do you guys have the Dormobile Plaque like this:-
..and if so was it mounted to the right hand or left hand side of the dash board.
I have seen them on the left passenger side on the Right hand drive Dormobiles but I haven't manged to spot if and where Westy/left hand drive Dormobiles had them
jakokombi
PostPosted: Fri Aug 30, 2013 5:50 pm    Post subject: Reply with quote
I have never seen that plate before, are you sure that they were installed on Westies?
70 Sunroof Kombi
73 Thing
72 Baja
Rippers
Rippers is offline
PostPosted: Sat Aug 31, 2013 1:47 am    Post subject: Reply with quote
That's what I was trying find out as I haven't seen a picture of a Westy Dorma dash to see if it has the plate.
jakokombi
PostPosted: Sat Aug 31, 2013 1:59 am    Post subject: Reply with quote
It seems unlikely that Westfalia would put a nameplate from a competing company anywhere on the bus.
Of course stranger things have happened.
Here in the states we have very little experience with the Dormobile, as only the top was available from Westfalia, probably as a premium priced option.
70 Sunroof Kombi
73 Thing
72 Baja
