jbclem Samba Member
Posted: Sat Sep 14, 2013 10:34 pm Post subject: oil pressure buzzer comes on for 1-2 minutes |
I've just started driving a 1986 Vanagon and the oil pressure(?) buzzer (and oil light flashing), comes on just after I start it up and drive away...then goes off after one or two minutes. On a one hour drive around town, including 20 mins up and down a steepish canyon road, the buzzer only came on twice: once right after starting up as mentioned, and once after parking for half an hour and then starting up.
This wouldn't seen to suggest an oil pressure problem, although the Vanagon has a lot of miles on it. And both times this occurred when I was going down a short slope right after starting up. Other times after parking and starting up on level ground, there was no buzzer nor oil light flashing. Does the pressure switch(s) fail this way? |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10484 Location: Orbiting San Diego
Posted: Sun Sep 15, 2013 8:13 am Post subject: |
I would start by spending about $25 for oil and a filter unless you personally just did it and know all is ok.
The hated retailer sells 20w50 in a 5 quart jug, as well as filter TG2870A. Don't buy their cheaper filters, make sure it is a TG version. Use 4 1/2 quarts of the oil. Make sure the oil light goes out soon after it starts up. Run it a minute, then shut it off and let it set on level ground for a minute. Then check the oil a couple times to make sure the dipstick is reading correctly with the known correct amount of oil just put in.
You could also use a 15W40 oil for heavy duty engines but that mostly comes in 4 quart jugs so you need to buy a loose quart to make 5. I like Delo 400 LE 15w40 but oil brand isn't important for your alarm issue.
Mark |
jbclem Samba Member
Posted: Sun Sep 15, 2013 6:42 pm Post subject: |
Thanks for the oil filter tip, there's a hated retailer in the area and I'll stop in and check the TG oil filters.
For me, oil pressure problems will show up when you're driving on the freeway at speed, and the engine's hot. Assuming you don't have an idling problem, if you take your foot off the pedal at 65 mph and the oil light comes on, that's the sign of a pressure problem. When the engine's hot the worn bearing clearances will expand and become too great, then when the rpm drops the pressure will also.
I don't know what it means when the oil light/buzzer comes on after starting up the engine and going down a slope...I'm hoping someone will be familiar with that syndrome. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15411 Location: Syracuse, NY
Posted: Mon Sep 16, 2013 7:38 am Post subject: |
sounds like a oil starvation issue, or loosing it's prime.
possibly from a bad relief valve sticking in the case ? or oil filter.
I'd change the oil and filter. but I believe the oil pressure relief valve is servicible in the vehicle.
Q in this image from www.Bus-boys.com
motor mount may be in the way?
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
spacecadet Samba Member
Joined: June 02, 2012 Posts: 158 Location: San Francisco
Posted: Mon Sep 16, 2013 9:40 am Post subject: |
| danfromsyr wrote: |
It is accessible from under the van, no mount in the way. _________________ Daily Drivers Only
1990 Volvo 740 Turbo(Sold)
1986 Mercedes 300 Coupe (Sold)
1954 Volvo PV544 (Sold)
1990 Dodge D250 Cummins (Totaled)
1990 Vanagon GL 2.1 Automatic (Sold)
1968 Ford F250(Current) |
jbclem Samba Member
Posted: Mon Sep 16, 2013 4:04 pm Post subject: |
| Since I have a high milleage engine, an oil pressure gauge would be a good idea. Can someone suggest something a little less pricey than the Van-Cafe combo ($120-160). |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Mon Sep 16, 2013 4:36 pm Post subject: |
It could be serious or it could be simple. When I was first into vans Jiffylube did an oil change and the same thing happened. Changed out the filter to the correct one and it went away. Why not try to narrow the problem before saying the engine is in imminent danger of imploding? _________________ 89 Westy 2.1 Auto |
Pascal Samba Member
Joined: January 13, 2006 Posts: 836 Location: Fredericton, NB, Canada
Posted: Wed Sep 18, 2013 3:43 am Post subject: |
| jbclem wrote: |
You can try to find a used vdo gauge and sender and have the hose made up at a hydraulic hose shop. Not that if you go this route that the oil light switch in the used vdo senders are .5 bar. The WBX switch is .3 bar so you will want to put a brass "t" and keep your OE oil pressure sender. _________________ '84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby |
Posted: Wed Sep 18, 2013 5:47 am Post subject: |
you can use an off the shelf grease gun hose (~$ to fit your oil pressure sender. just don't forget to ground the sender to the engine. *the hose isolates the ground path. _________________
| Abscate wrote: |
markz2004 Samba Member
Joined: November 13, 2007 Posts: 947 Location: Portland, OR
Posted: Wed Sep 18, 2013 8:43 am Post subject: |
| jbclem wrote: |
First, if your worried about $120 for something that will last your lifetime with the van, think this one through a second time. The gauge will payback itself everytime you use the van. It's a great way to monitor a critical operating system. Second, let's say your engine is really on its way out, the gauge will work on your new(er) engine, so it's an add on, not a throw away.
While you are at it, why not order the type of filter from VanCafe that has been successfully used by most of the people on the forum. Dare I say the 'correct' filter.
How many miles on the engine? _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
Posted: Wed Sep 18, 2013 9:20 am Post subject: |
Have you changed the oil and filter yet? I mean YOU, personally.
Installing an oil pressure gauge won't save the old motor or help a new motor. What saves motors is driver diligence. Adding gauges to stock motors is way down the list of things that will do much good in the long run. Make sure the stock dash indicators work properly and keep them working. Keep fluids at proper levels. Drive the thing, but pay attention to it.
Mark |
