'78 Bay seat track repair (Horrific)
Doug Brown
Doug Brown is offline
PostPosted: Tue Dec 03, 2013 11:42 am    Post subject: '78 Bay seat track repair (Horrific) Reply with quote
Wanted to show off/complain-about how FUBAR the previous owner left the dirver's side seat tracks. It looks like an ape and a crowbar took out the original seats.
I'm open to suggestions on how to fix these, just picked up a pair of mint vanagon seats to replace the junkyard seat that had been bolted into the driver's spot. My current plan is to take a wide center punch and try to bend these back... Suggestions? I don't have access to a welder or Oxy setup.
Shocked
kkjellquist
kkjellquist is offline
PostPosted: Tue Dec 03, 2013 11:58 am    Post subject: Reply with quote
That is simply amazing...imagine all the blood, sweat, cursing, hammering, prying that all happened because he didn't know about the tab to slide the seats out!
1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/
aerosurfer
aerosurfer is offline
PostPosted: Tue Dec 03, 2013 12:10 pm    Post subject: Reply with quote
my outter driver seat tracks are totally rusted in place from poor seals and standing water on the metal. I'll have to take a cutter to that track to remove the seat.
I already sourced a new set with a WTB ad in the classifieds for reasonable cost, had a few offers real quick. But instead of recon with your safety your best be would be to cut those mangled ones out and secure new ones
Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
Doug Brown
PostPosted: Tue Dec 03, 2013 12:20 pm    Post subject: Reply with quote
No Kidding. Makes me shudder at the thought of what this neanderthal did with the rest of the bus. Shocked
There is a decent set in a late-'76 in a local junk yard... Are they just tack-welded in? (I haven't looked too closely yet)
aerosurfer
PostPosted: Tue Dec 03, 2013 12:47 pm    Post subject: Reply with quote
They are spot welded on.
Wasted youth
Wasted youth is offline
PostPosted: Tue Dec 03, 2013 1:01 pm    Post subject: Reply with quote
Man, I liked Everett! Cool Wish I'd stayed. Anyway, welcome to the Samba! You may find it very useful to get invested in some steel-working tooling...a small wire-feed welder and a grinder with both cut off wheels and grinding wheels, also a cup brush for the grinder would be a good start. Milwaukee tools makes a nice one for that, and you can get a flux-core wire feed welder that uses household current from Lincoln Electric. Try to get a welder that can have a gas kit installed later when money permits.
I know you state you don't have access to those tools, but I would not recommend doing the track replacement without them.
I cannot think of any practical way to remove those tracks...and install your new seats...without those tools. Those tracks are obviously garbage Shocked and will need serious repair or even better, replacement, and are welded in place at the factory. Keeping in mind the needed crash worthiness of your new seat installation, I would strongly recommend welding in your new tracks Exclamation
Doug Brown
PostPosted: Tue Dec 03, 2013 1:53 pm    Post subject: Reply with quote
Wasted youth/adulthood, you must just miss the rain!
You guys think just drilling out the spot welds on the brackets in the junk yard a good idea or would that affect the seats sliding too much?
mojogoat
mojogoat is offline
PostPosted: Tue Dec 03, 2013 2:06 pm    Post subject: Reply with quote
Install a swivel seat base with the new tracks already on them.
77 Riviera
78 CEII Westfalia
Doug Brown
PostPosted: Tue Dec 03, 2013 2:19 pm    Post subject: Reply with quote
Hadn't thought of that (new to the Bus world)...
This?
http://www.thesamba.com/vw/classifieds/detail.php?id=838963
Pricey, but that saves alot of labor...
busdaddy
busdaddy is offline
PostPosted: Tue Dec 03, 2013 2:24 pm    Post subject: Reply with quote
Wow, I'm not sure you could ever straighten that to a point where it'd be useable but it's worth a few minutes of trying, you'd have to notch the side of the end of a piece of ~1/2" bar with a cutoff wheel (anything will work, round, square or even the handle end of a cold chisel or cheap ratchet), make the notch the thickness of the seat track steel and situate the slot ~ 3/16" up from the end. By placing the slot over the damaged section you'll be able to pry it back inwards, don't try to get it all the way first try, work a large area a little at a time.
There's a spot weld at the bottom of each of those rounded cutouts, drilling it off may not be too bad but getting in there to weld back on will be challenging, the cutouts were for the spotwelder's electrode to have access.
Слава Україні!
danfromsyr
danfromsyr is offline
the early (93-95) eurovan front seat tracks unbolt.
if you have any in your local Upull or post out a WTB here & Craigslist.
vanagon seats and stock bay seat should fit into the EV tracks.
I can post up a image tomorrow of what they'd look like for you if needed.
*edit
you can see that the EV seat rails bolt on here in this image (of a swivel unit)
Abscate wrote:
mojogoat
mojogoat is offline
PostPosted: Tue Dec 03, 2013 3:54 pm    Post subject: Reply with quote
This?
They go for around $100 used, craigslist had a set for $125 over here a while ago.
77 Riviera
78 CEII Westfalia
Desertbusman
Desertbusman is offline
PostPosted: Tue Dec 03, 2013 5:59 pm    Post subject: Reply with quote
Laughing Laughing Laughing
That and all the other trinkets of important info that are in our owners manual. Free to anyone that downloads it from the technical Section and actually takes the time to read it.
71 Superbug
71 Westy
1967250s
1967250s is offline
PostPosted: Tue Dec 03, 2013 6:24 pm    Post subject: Reply with quote
maybe someone here on TS and in your area can help?
Doug Brown
PostPosted: Wed Dec 04, 2013 9:32 am    Post subject: Reply with quote
Fixed.
Fabbed a piece of steel the thickness of the seat rail to ensure I didnt over "adjust" the bracket down. Other than that, used a square punch and a peen hammer. I was shocked it worked as well as it did.
Wasted youth
PostPosted: Wed Dec 04, 2013 9:35 am    Post subject: Reply with quote
Hey, nice save! Razz
busdaddy
busdaddy is offline
PostPosted: Wed Dec 04, 2013 9:55 am    Post subject: Reply with quote
Impressive, nice job!
Слава Україні!
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Wed Dec 04, 2013 10:09 am    Post subject: Reply with quote
Nice work, Doug.
Hey, for a software guy you are certainly handy with heavy tools.
You should feel proud of what you accomplished there!
I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab
Doug Brown
PostPosted: Wed Dec 04, 2013 2:43 pm    Post subject: Reply with quote
Thanks guys. Now if only i could do the body work...
'78 Bus - My Flickr
My Bus Restoration Blog
eche_bus
eche_bus is offline
PostPosted: Wed Dec 04, 2013 10:44 pm    Post subject: Reply with quote
Wow! From the earlier photos it didn't look salvageable. You got real lucky this time!
