Complete Guide to Performance VW Camshafts
Page: 1, 2, 3  Next
AlteWagen
Troll
AlteWagen is offline
PostPosted: Wed Dec 11, 2013 9:12 am    Post subject: Complete Guide to Performance VW Camshafts Reply with quote
I often refer to this list for customer inquiries so thought this would be useful for others.
If you find any typographic errors or have additional specifications @ .050 please let me know and I will update the sheets ASAP.
edit: fixed CB data
Official Dual Carb Thread
mark tucker
mark tucker is offline
PostPosted: Wed Dec 11, 2013 10:34 am    Post subject: Reply with quote
thats pretty good,I had another one but lost it in the big crash.I wonder why non of these charts have any of the crane or comp cams or other v8 grinders listed that did vw stuff in the old days(yes engle is a v8 grinder as is ersonn& some others,) crane did vw& porsche cams long ago. and also possiably made aluminum roller rockers,but they may of went to some special racers& not sold to the public. mr crane told me he didnt remember ever selling them to the public,so there are some sets out there somewhere...possiably.but probably all used up.
gooser
gooser is offline
PostPosted: Wed Dec 11, 2013 10:45 am    Post subject: Reply with quote
i also wonder why cb performance's famous cheater cam (2280) is not listed or is that not considered a performance cam?
AlteWagen
Troll
PostPosted: Wed Dec 11, 2013 10:58 am    Post subject: Reply with quote
Mark, if you have any of the crane, comp, crower, erson, clay, isky or any other old school grind numbers I will gladly add them
Shoot me any info you have
Ill ad the 2280 right now, dont know how I missed that one.
Thanks
johnwesley
johnwesley is offline
PostPosted: Wed Dec 11, 2013 4:39 pm    Post subject: Reply with quote
is there any info on the DRD cams?
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Wed Dec 11, 2013 4:44 pm    Post subject: Reply with quote
The Crower Cams are slightly different from what they currently have on their site. They have; (lift at 1.1)
61002 int 260 220 0.375 110 ex 268 227 0.381 110
61000 int/ext 268 227 0.354 110
61003 int 276 234 0.398 107 ex 284 244 0.421 107
61004 int 284 244 0.424 107 ex 290 252 0.446 107
61005 int 290 252 0.447 107 ex 298 260 0.460 107
61006 int 298 260 0.462 107 ex 306 272 0.482 107
61007 int 306 272 0.481 107 ex 312 280 0.500 107
61002 Smooth idle. Great all around stock replacement cam. Super torque profile. RPM 1000-5000+
61000 Fair idle. Good bottom end profile with mid-range power. Emphasis on torque. RPM 1800-6000+
61003 Fair idle. Competition profile. Super torque and mid-range profile for 1600cc engines. RPM 2000-7000+
61004 Fair idle. High torque profile with emphasis on the top end for 1800cc engines and under. RPM 2500-7500+
61005 Fair idle. Broad mid-range and top end power for 2180cc engines and under. RPM 2500-7500+
61006 Fair idle. Broad mid-range and top end power for engines with increased compression. RPM 3000-8000+
61007 Rough idle. Strong mid-range and top end power for 2000cc engines or larger with increased compression. RPM 3500-8500+
slalombuggy
slalombuggy is offline
PostPosted: Wed Dec 11, 2013 4:54 pm    Post subject: Reply with quote
there is a few of CB/Eagle on this page that you don't have. 2290, 2291,2295,2296 and 2297. Thanks for charting all this info. It's great to have it all in one spot and I know it must be a bit of work on all the data entry. Thanks for taking the time.
http://www.cbperformance.com/searchresults.asp?cat=195
brad
AlteWagen
Troll
PostPosted: Wed Dec 11, 2013 6:02 pm    Post subject: Reply with quote
Cant take all the credit, there was a list on line somewhere but had some out of date info. I updated it a few times but like the feedback and extra eyes as it all starts to look the same after a while.
Keep it coming!
neil68
neil68 is offline
PostPosted: Wed Dec 11, 2013 7:43 pm    Post subject: more camshafts Reply with quote
I've been using a JPM Raptor camshaft for a few years (the middle one below). These cams are designed to be run with less spring pressure at high rpm's. Here's their main list, but they also custom grind at various lobe angles, etc. Duration is at 1.27mm (0.050") and lift is at the cam lobe:
JPM01106 251° 10.00mm (0.394") 1.1-1.25:1
JPM01706 258° 9.57mm (0.377") 1.4-1.5:1
JPM00806 263° 9.64mm (0.380") 1.4-1.5:1
JPM01006 274° 10.35mm (0.407") 1.4-1.5:1
JPM06908 274° 10.80 mm (0.425") 1.4-1.6:1
JPM00206 280° 10.50mm (0.413") 1.4-1.5:1
JPM00406 282° 10.70mm (0.421") 1.4-1.5:1
JPM01306 287° 11.43mm (0.450") 1.4-1.5:1
JPM00906 293° 11.25mm (0.443") 1.45-1.6:1
Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
drumbum68
drumbum68 is offline
PostPosted: Thu Dec 12, 2013 8:21 am    Post subject: Reply with quote
Cb 2251, 2252, 2253, 2254 are hydraulic cams.
tncsparky
tncsparky is offline
PostPosted: Fri Dec 13, 2013 8:59 am    Post subject: Reply with quote
On the Norris Cams the advertised #'s are listed @020.
On the 336 it is 290@020 and 254@050
This page has good info on Norris stuff
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...highlight=
"My Daddy told me, son if your stupid today you will be stupid tomorrow"
scotth17
I think you are just waiting around for a high-five from a unicorn so you can feel better about yourself
posada
posada is offline
PostPosted: Tue Jun 05, 2018 7:40 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
friends can help me identify these cams codes
theKbStockpiler
theKbStockpiler is offline
PostPosted: Tue Jun 05, 2018 7:59 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
http://www.iskycams.com/cart/?main_page=advanced_s...=CAMSHAFTS
http://www.compperformancegroupstores.com/store/me...ry_Code=VW
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
earthquake
earthquake is offline
PostPosted: Thu Jun 07, 2018 1:26 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
Don't forget about Schneider cams
http://schneidercams.com/solidliftercamshafts-18.aspx
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
-Alex77-
-Alex77- is offline
PostPosted: Thu Jun 07, 2018 5:34 am    Post subject: Re: more camshafts Reply with quote
JPM; best cams in the industry Wink Wink
Lasercut parts and CAD design
Max Welton
Max Welton is offline
PostPosted: Thu Jun 07, 2018 8:05 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
I was going to say the SLR cams were missing, but a lot of what is on this SLR page you have under Babe Erson Cams.
http://www.piersideparts.net/SLRCAM.html
Max
1967 Type-3 Fastback
norris
norris is offline
PostPosted: Thu Jun 07, 2018 9:24 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
While in this cam discussion has anyone an idea of who ground this one? I've look everywhere!
Olli from NJ
Olli from NJ is offline
PostPosted: Thu Jun 07, 2018 9:37 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
On the CB site it states that all of their cams are 107 lobe center. The above chart has a lot of them listed at 108.
Olli
vwracerdave
vwracerdave is offline
PostPosted: Thu Jun 07, 2018 9:51 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
I wish CB would redo their entire listings of cams. It is very difficult to understand what they offer and compare all their cams together to make a choice. I don't ever buy CB cams because the way they list them in groups is too difficult to navigate.
I hope Pat Downs reads this. CB website listing of their cams sucks.
theKbStockpiler
PostPosted: Thu Jun 07, 2018 11:06 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
I'm pretty sure it's a Schneider. There was a thread on that number a few weeks back if I'm not mistaken.
Page: 1, 2, 3  Next
