1971 Yugoslavia Squareback
Donnie strickland
Donnie strickland is offline
PostPosted: Thu Dec 26, 2013 6:55 am    Post subject: Reply with quote
Mike Fisher wrote:
The new ones have black & white wiring diagrams I think. If you buy a used 1971 edition on www.amazon.com it will have the Color wiring diagrams in it. Take it to Kinkos and have the color wiring diagram blown up to 11X17 and laminated for the Electrical! Twisted Evil
Or just have these printed and laminated: Smile
http://www.thesamba.com/vw/archives/info/wiring/type3_71.jpg
http://www.thesamba.com/vw/archives/info/wiring/type3_71_key.jpg
http://www.thesamba.com/vw/archives/info/wiring/type3_71_lighting.jpg
http://www.thesamba.com/vw/archives/info/wiring/type3_8_70_additional.jpg
71 Elm Green FI A/T Squareback
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Thu Dec 26, 2013 7:56 am    Post subject: Reply with quote
Hoping for used to cut costs anyway. Just couldnt find any last time i looked...i gotta look harder though.
Stuart Zickefoose
206-841-7324
[email protected]
Stuartzickefoose
Samba Post Whore
PostPosted: Thu Dec 26, 2013 7:58 am    Post subject: Reply with quote
Stuart Zickefoose
206-841-7324
[email protected]
Mike Fisher
Mike Fisher is offline
PostPosted: Thu Dec 26, 2013 8:04 am    Post subject: Reply with quote
Try www.books4cars.com in Seattle too.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Stuartzickefoose
Samba Post Whore
PostPosted: Mon Jan 06, 2014 12:31 am    Post subject: Reply with quote
eh oh!
thanks JSMSkater for the help! turns out the distributor we put in had a flipped drive tooth, so it was 180! swapped the wires and fired up. then it woulding go above an idle, so we swapped on a spare throttle position sensor and she revved ! also, before figuring out the spark issue, there was a lack of fuel for some reason. ....turns out i hadnt gotten the pump trigger wire all the way back on so it wasnt turning on. works now!
the smoke was oil spilled from the air cleaner onto the header, no biggy.
the popping however is a biggy! each pop soulds like a hammer on glass, and is accompanied by a puff of black! im suspecting a sticky valve or something along those lines.
next on the list:
FUEL LINES! leaking badely, got all the new stuff, just gotta install. i suspect a tank leak, so gonna have that hot tanked and pressure tested somehow....and got new tank screen and fittings and filter and spare pumps from joe. thanks again!
TUNE IT! this includes: dynamic timing, valve adjust, valve cover gaskets, oil change, run with a full case of AFT for a hour or so, then drain and refill with oil to really wash the gunk out. stuffs been sitting for 12 years or so....then new plugs, and maybe wires, and all new vacuum lines and a full once over with joe again if i dont have a purring engine yet. Cool
THEN:
drive it around the block, and make a new list of to dos! Very Happy
Stuart Zickefoose
206-841-7324
[email protected]
Tram
Samba Socialist
Tram is offline
PostPosted: Mon Jan 06, 2014 12:37 am    Post subject: Reply with quote
Popping: sounds like timing way off or two wires crossed.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
Stuartzickefoose
Samba Post Whore
PostPosted: Mon Jan 06, 2014 12:40 am    Post subject: Reply with quote
ill do a dynamic time next time i tear into it...what should i set it to and how will i know where its at?
and ill triple check wires, but if they are off, we can all give joe a hard time since he is the one who told me where to put them....as if i didnt know...
Stuart Zickefoose
206-841-7324
[email protected]
Tram
Samba Socialist
Tram is offline
PostPosted: Mon Jan 06, 2014 1:15 am    Post subject: Reply with quote
Also could be two injector plugs reversed. Are your boots intact- a grey and black boot on each side?
Bryan67 wrote:
Those who can- do.
Stuartzickefoose
Samba Post Whore
PostPosted: Mon Jan 06, 2014 11:58 am    Post subject: Reply with quote
joe took the right two off and put em back on....i have no idea if any are placed correctly...
i really gotta get that book, im gonna order it now and my text books for class to. Smile
Stuart Zickefoose
206-841-7324
[email protected]
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Jan 06, 2014 1:25 pm    Post subject: Reply with quote
Black boots go to the FRONT (as in front of car) pair of injectors, greys to the REAR.
compdrag
compdrag is offline
PostPosted: Mon Jan 06, 2014 2:26 pm    Post subject: Reply with quote
Progress can't wait to see this thing drive down the road!
61 Type 1 Patina
61 Type 1 Convertible
68 Type 2 Rivi
Joeys1969
Joeys1969 is offline
PostPosted: Tue Mar 04, 2014 8:26 am    Post subject: Reply with quote
Awesome Stuart! I have been out of the loop so long I didn't even know you got a squareback! They great cars, my grandpa had one as his work car for 15 years.
Good luck to you on this project, what are the overall plans?
Joey
Old VW's and Old Motorcycles.
joey1320
joey1320 is offline
PostPosted: Wed Mar 05, 2014 8:23 pm    Post subject: Reply with quote
Great looking square Laughing
1971 Super - Sold
1984 Puma GTC - Sold
1971 Campmobile
Stuartzickefoose
Samba Post Whore
PostPosted: Wed Mar 19, 2014 7:46 am    Post subject: Reply with quote
ill be getting out to the garage again today to clean around the square...who knows...maybe ill dig in and see if it will start again.....let it run for a bit....
i should be makings some fresh progress soon, i JUST finished school monday, so time should free up a bit....assuming the Girl doesnt mind giving up a bit of her time with me...
Stuart Zickefoose
206-841-7324
[email protected]
Tram
Samba Socialist
Tram is offline
PostPosted: Wed Mar 19, 2014 12:14 pm    Post subject: Reply with quote
She called me looking for 3 or 4 more projects for you.
Bryan67 wrote:
Those who can- do.
Stuartzickefoose
Samba Post Whore
PostPosted: Wed Mar 19, 2014 1:53 pm    Post subject: Reply with quote
Laughing
she would...
Stuart Zickefoose
206-841-7324
[email protected]
Stuartzickefoose
Samba Post Whore
PostPosted: Mon Jun 30, 2014 10:58 pm    Post subject: Reply with quote
so its been a while....
i moved the square out to monroe for storage...we are selling our house and it had to be out of the garage.... so its sitting again Sad
but ill be back at it someday...promise. if not...i have many offers for buyers....which i would rather not do yet.
Stuart Zickefoose
206-841-7324
[email protected]
Joeys1969
PostPosted: Wed Jul 16, 2014 5:07 pm    Post subject: Reply with quote
It happens man I had to sell my bus due to moving Confused
Good luck on keeping it!
Joey
Stuartzickefoose
Samba Post Whore
PostPosted: Wed Aug 27, 2014 12:40 am    Post subject: Reply with quote
its still in my head i promise i havent lost the motivation yet. rather, the curiosity is building, and im about ready to drag it back home to get to work on it. saving a bit at work here and maybe this winter will drag it back to the garage and tackle the fuel lines and oil seals it needs. first i gotta get the transmission done on my 78 bus. Wink
Stuart Zickefoose
206-841-7324
[email protected]
Stuartzickefoose
Samba Post Whore
PostPosted: Wed Sep 17, 2014 11:05 pm    Post subject: Reply with quote
visited the square last friday...
really getting motivated to get it on the road soon! got a transmission install to do to my bus, and once thats going well, i really want to drag this thing back onto the road. may even make a trip out to just work on it where it is, rather then transport it back to continue the work.
suggestions on the tank...i suspect rusted holes in it.....thoughts on checking for leaks? i dont , repeat, DONT want to reseal it with a POR kit or anything...never heard anything good about those. just want to clean it out....
really just getting excited overall for VW's....bus transmission, looking for a splitty, and wanna get this running so i can use it! just super pumped up overall!
Stuart Zickefoose
206-841-7324
[email protected]
Page 3 of 6
