LT Mirror Installation (Photos and Installation Tips)
Page: Previous  1, 2, 3  Next
robertgriner
robertgriner is offline
PostPosted: Thu Jan 16, 2014 8:20 am    Post subject: DIY Heated LT Mirrors Reply with quote
Great post on how you installed these.
I'm looking for a heated version as well...or someone who has done a DIY version.
Here is a European site that lists a "heated" mirror part, but not the complete kit: http://syncro-services.com/en/accessoriesexternal
Bob
boulderdrop
boulderdrop is offline
PostPosted: Thu Jan 16, 2014 6:51 pm    Post subject: Reply with quote
Good job on the install! Specifically, knowing about those rivet-nuts. I was sad GoWesty didn't include any fasteners with the install. I ended up using sheet metal scews and your method is much, much better! wtg.
== My Rides ==
1984 Westy, Bostig, AC, PS, Recaro
1980 24' J-Boat
1979 Sears Freespirit Moped
2012 Toyota Camry Hybrid (Wife's)
2024 Toyota Grand Highlander MAX/Pro
jrasite
jrasite is offline
PostPosted: Fri Jan 24, 2014 9:03 pm    Post subject: Reply with quote
FWIW, vagcat shows the top fasteners as being M5.5 x 22 sheet metal screws. I have the Rivnuts and brand new M6 x 1.0 stainless oval head screws (Fastenal has them) and I think I'll put sheet metal screws to start. If it's a problem, I'll have pilot holes for the Rivnuts!
http://www.vagcat.com/epc/cat/vw/T2SY/1988/59/56/600849/
Solrider
Solrider is offline
PostPosted: Sat Jan 25, 2014 10:47 am    Post subject: Reply with quote
I just got a set of these from GW and I'll be heading out to the hardware store to pick up what I need. This is a very clean installation, but a bit more than I bargained for! I have minimum mechanical skills and while I want this done right and I'm not afraid of the challenge, I wasn't expecting to have to go out any buy extra tools for installation.
Have those that have just used the sheetmetal screws had any issues with them coming off or coming loose? Should I just break down and get all these extra parts and do it this way, the first time?! Shocked
Heidi - KF7CKI
85 Vanagon GL 1.6NA - Otto Von Wunderwagen
Gone but not forgotten:
71 Super Beetle - Gretel
92 Jetta GL - Jerry
97 Passat TDI - Penny
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Sat Jan 25, 2014 10:59 am    Post subject: Reply with quote
I have had three vans with the LT mirrors mounted with just sheet metal screws. One I bought that way and two that I installed. All three have worked fine. They have never loosened. Just be sure to use stainless steel screws and dab some high quality silicone sealant in the holes and on the screws as you install. There is no need to drill such large holes to get a good install.
If you live in an area of high theft, you might consider using the anti-theft hardware.
Currently:
All that's needed for evil to prevail is for good people to do nothing.
robertgriner
PostPosted: Sat Feb 01, 2014 3:30 pm    Post subject: LT Heavy Duty Heated Mirror -- [HEATED] Reply with quote
I know I've seen several people inquire about these and I've been on a search myself.
I discovered them on a site in Germany. They're $295 shipped to me in Kansas City. All included except the attaching screw/bolts.
I'm attaching the photo they sent me. The indicated that I would get everything in the picture, with the mirrors swapped for "heated" versions.
Hope this helps those who are looking.
[/img]
tarandusVDub
tarandusVDub is offline
PostPosted: Sun Feb 02, 2014 9:23 am    Post subject: Reply with quote
Let us know how you hook up the heater wiring. I got mine from CIP1 but the non-heated version.
1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD.
mtnphan
mtnphan is offline
PostPosted: Sun Feb 02, 2014 10:58 am    Post subject: Reply with quote
Nice tutorial thanks for posting. This is on my to do list for the summer.
'85 Wolfsburg Westfalia 2.2 Subie
DAV!D
DAV!D is offline
PostPosted: Sun Feb 02, 2014 11:13 am    Post subject: Reply with quote
Good post on installing them. I'm still not sold on LT mirrors as they look a bit big too me, but after finally getting some drive time on my Westy I can understand the want for bigger mirrors.
I'm not sure I want that much mirror hanging on the side of my van when doing trails, I'm curious what the off road guys think of them? Also is there maybe something between the stock mirrors and there LT mirrors?
86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion
ajdenette
ajdenette is offline
PostPosted: Sun Feb 02, 2014 11:39 am    Post subject: Reply with quote
I have had several of the smaller stock manual mirrors break of when getting bumped or rusted in place and unmovable and break trying to adjust them. The LT mirrors have a much more robust pivot and fold in nicely for working on the van in the garage or to keep them out of the bushes on the trail plus the visibility is amazing one of my favorite things about my Syncro.
1985 2wd Westy with 2000 Subaru 2.2 current driver
https://www.thesamba.com/vw/forum/viewtopic.php?t=685635
1986 Syncro Doka Project next in line
https://www.thesamba.com/vw/forum/viewtopic.php?t=732777
1990 Vanagon Syncro Base awaiting body work
designer
designer is offline
PostPosted: Fri Feb 21, 2014 7:34 pm    Post subject: Reply with quote
Thanks for the heads up on the install to the OP! I followed this pretty much - and I do agree - the heavy duty LT mirrors aren't that HD. But they are cool and i think they'll be just fine. nice view to the rear. Much better than stock.
They look friggin' tight!
I'm not too impressed with the rivet installation - i used the 25/64 bit and i think it was just a tad bit loose for the rivets I bought from GW. They still hold the top of the mirror on well but i just think i either did it wrong, which I don't see how that'd be possible ... but whatever. I know i didn't "waller" the holes out.
Still thanks for the heads up. Oh, the "tool" you buy - don't waste your money.
Thanks!
-cc-
smurfpike
smurfpike is offline
PostPosted: Tue Apr 08, 2014 6:03 am    Post subject: Re: LT Heavy Duty Heated Mirror -- [HEATED] Reply with quote
[/img]
Robertgriner What site did you find them from in Germany with heated mirrors for $295?
1965 Ottinger Tribute Overland Bus
IG @otter.the.overland.bus
FB Ottertheoverlandbus
IG Westyrestorations
FB WestyRestorations, parts and accessories
1987 Syncro "Big Red", Full restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=606596
1978 Westy Camper, Full ground up restoration, restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=593413
ng
ng is offline
PostPosted: Thu Apr 17, 2014 6:32 pm    Post subject: heated mirrors install Reply with quote
I bought a set of the heated mirrors from Syncro Services
I couldn't get much info on the wire routing from them, and now that I have them there doesn't seem to be a really obvious way to hook them up. Has anybody installed these? Any ideas on wire routing?
1986 Syncro Westy "Braunbaer"
http://www.thesamba.com/vw/forum/viewtopic.php?t=607112
bstein
bstein is offline
PostPosted: Sun May 03, 2015 9:46 am    Post subject: Reply with quote
Great write-up and thanks for posting!
I just did this yesterday. My installation turned into a bit of a brief nightmare on both sides b/c I'm a slow learner. All is well, as the mirrors are installed and looking pretty sweet. (The first syncro I test drove had these and the visibility put them on my todo list immediately.)
As stated in the original post be extremely careful on alignment on installation. I thought I was threaded into the nutsert and wasn't. Removing an unseated nutsert in each door made the installed a wee bit longer than expected. Embarassed
After fixing that, I ended up opening up the two top outer mounting holes 1mm (using a 7mm bit), masking/painting the bare metal, and reinstalling. The additional play allowed easier alignment; installation is just as solid on both sides. Also I just used RTV on the nutsert vs. masking/painting and decided on hex heads. May none of us experience rust! Very Happy
IMHO, I like having threaded mounts in the door now that I'm done with it. Functionally for installation it would be more straight forward and less fraught to use self-taping metal screw for an item that doesn't functionally require frequent removal.
Brian
1987 Syncro Wolfsburg Weekender | Triple Knob | SAH 1.8T
GypsyDriver
GypsyDriver is offline
PostPosted: Sun May 03, 2015 2:23 pm    Post subject: Reply with quote
Looks good. I like the hex nuts. I was looking for those when I did mine, but couldn't find them. What size are they and what was your source? Did you black them out? If I had to do it over, I'd still use the rivet nuts. I feel a little more secure about it with a threaded insert. But I'd use RTV instead of painting. Still ... zero problems so far.
bstein
bstein is offline
PostPosted: Sun May 03, 2015 2:39 pm    Post subject: Reply with quote
I found them locally and followed your advice for M6x1.00x25 sizing. Painted them with SEM Black Trim. It's close enough for the screws, though I think they have a glossy version which would match perfect.
Brian
designer
designer is offline
PostPosted: Sun May 03, 2015 7:34 pm    Post subject: Reply with quote
the bottom of mine leave a gap where the old mirror was. Has anybody come up with a good idea to cover that?
GypsyDriver
PostPosted: Mon May 04, 2015 8:13 am    Post subject: Reply with quote
I just blacked out the bottom bolt and reinserted it. Its only a few millimeters and hardly noticeable, in my opinion.
I'm hoping svenakela will 3D print a turn signal cover for the LT mirrors. That bolt hole would be perfect to thread the wiring through. http://www.thesamba.com/vw/forum/viewtopic.php?t=4...;start=320
bstein
bstein is offline
PostPosted: Mon May 04, 2015 8:48 am    Post subject: Reply with quote
Same for me.
That would be awesome and a great excuse to open the door for some dynamat while-I'm-in-there. Wink Thanks for the link to that thread.
Brian
michaeltag
michaeltag is offline
PostPosted: Sat Sep 16, 2017 10:08 pm    Post subject: Re: LT Mirror Installation (Photos and Installation Tips) Reply with quote
Read your excellent write-up but I'm still stumped on something ...
In the picture I'm posting here, the piece on the left is for the lower mount and its fit is really obvious and I've installed the lower mount with it in place, no problem. However, I've tried to line up this upper piece (on the right in the photo) every which way on the right side of the van (it is marked right and was packed with the right side mirror) and it just doesn't work. Is the thick part supposed to sit outside of the mount on the window frame? There is not a hollow void under the mount for thick part to fit into, which was where I thought it went at first.
You didn't mention the orientation of the shims in your write-up. Thanks for the details on rivet nuts, though. I'm going to get those.
Could you give me a tip on that upper shim?
'87 Vanagon GL Westfalia Syncro w/ rear locker
• 1.8T engine conversion from Stephan's AutoHaus
• Schwenk Springs, OME shocks, BFG All Terrains on South African 15-inch steel wheels
• GoWesty Plate Steel Bumpers w/ front skid plate & rear swing-away spare carrier
• Big Shot Shifter
• Transaxle rebuilt with taller heavy-duty 4th gear, GoWesty decoupler and oiler plates by Ken at Porter's Precision
* TruckFridge
• Propex Heater
• Vintage Air in-dash A/C
Page 2 of 3
