kamzcab86 Samba Moderator
Posted: Sat Feb 08, 2014 3:30 pm Post subject: What TIRES fit? The ultimate tire thread! |
Vanagon Tire Information
[Updated: August 16, 2019]
* * *March 2017: This post is now a truncated version of the original, with just the most basic, pertinent info supplied. For complete tire information and details, and in a more organized, readable format, please download and read the PDF version of this post.* * *
Gross vehicle weight (GVWR) at each corner of a van when fully loaded:
1433 lbs. (2WD Vanagon)
1521 lbs. (4WD Vanagon)
The above is the minimum weight rating you should use when shopping for new tires. The lowest weight-rated tire originally installed on Vanagons by Volkswagen was 1580 lbs. (load index 97, reinforced sidewalls); derated by 9% as required (see Tire Types section), the tire's actual load was 1438 lbs., just over the 1433 full-load van weight above. The 1580-lbs. rating is the preferred minimum weight rating to use when shopping for new tires, especially for campers, so that your van has a safety margin. Furthermore, except for that one 1580-lbs. rated tire, all tires installed on Vanagons at the factory were light truck tires. Use the original equipment list below as a guide while you shop.
Original Equipment (Vanagon 2WD):
185R14C 6PR
Load Index: 99
Load Range: C (6 ply)
Max Load: 1710 lbs.
Max Inflation: 55 psi
VW-recommended Inflation: 39-43 (front); 48-53 (rear)
Revs/mile: 820
Tire: Continental Transport RS771; Continental RT 735 M&S; Michelin XZXT-LRC; Michelin XC; Michelin X
205/70R14 97R
Load Index: 97
Load Range: XL/RF
Max Load: 1580 lbs.
Max Inflation: 40 psi
VW-recommended inflation: 30 (front); 40 (rear)
Revs/mile: 798
Tire: Michelin MXL
Notes: Reinforced passenger car tire
205/65R15
Standard size on South African-built T3's
Original Equipment (Vanagon 4WD):
185R14C 6PR
Load Index: 99
Max Load: 1710 lbs.
VW-recommended Inflation: 40-43 (front); 48 (rear)
Revs/mile: 820
205R14C 6PR/8PR
Load Index: 109
Load Range: D (8 ply)
Max Load: 2270 lbs.
Max Inflation: 65 psi
VW-recommended inflation: 36 (front); 43-43.5(rear)
Revs/mile: 798
Tire: Michelin XC A75; Continental Contrans
205/70R14 97R
Load Index: 97
Load Range: XL/RF
Max Load: 1580 lbs.
VW-recommended inflation: 36 (front); 40 (rear)
Revs/mile: 798
Tire: Michelin MXL
Load Index Rating Conversions
93 = 1433 lbs.
94 = 1477 lbs.
95 = 1521 lbs.
96 = 1565 lbs.
97 = 1609 lbs.
98 = 1653 lbs.
99 = 1709 lbs.
100 = 1764 lbs.
101 = 1819 lbs.
102 = 1874 lbs.
Load Range Conversions with Corresponding Standard Max psi Ratings
B = 4 ply (35 psi)
C = 6 ply (50 psi)
D = 8 ply (65 psi)
E = 10 ply (80 psi)
F = 12 ply (95 psi)
SL (35-36 psi)*
XL (41-42 psi)*
* These ratings are for P-metric tires; SL and XL load ranges are often 40 psi and above for Euro-metric and truck/SUV-branded tires.
Replacement Tire Types
Passenger car/minivan tires:
Passenger car tires come in P-metric and Euro-metric sizes. Volkswagen did install a passenger car tire on Vanagons; however, they had reinforced sidewalls and met their load requirement(s). Modern reinforced passenger car tires will have an XL (extra load) or RF (reinforced) rating, as opposed to SL (standard load, which are 2- or 4-ply tires). These tires must meet or exceed the original equipment (see above), which means few options available today. Furthermore, the load range of all P-metric passenger car tires must be reduced by 9%, even when XL or RF. Be vigilant when shopping for P-metric tires for your van.
Euro-metric passenger car tires:
If the tire has no letter designation it is a Euro-metric tire. Euro-metric tires, like their P-metric counterparts, including XL/RF tires, are to be derated by 9% when rated below the C/D/E/F load range. A Euro-metric tire load rated at 99, has a max load rating of 1709 lbs., has a max psi rating of 50, and is an extra load (XL). If we reduce the max load by 9% we get 1555, which is just below the recommended 1580 lbs., but is above the minimum 1433 lbs. This tire can be used.
To recap: Any tire that is not designated as LT (light truck), or does not have a C or higher load range, must undergo the 9% reduction in max load weight. However, it is unclear at this point whether a P- or Euro-metric SUV-branded tire (such as the Yokohama Geolandars) with an SL or XL rating must also undergo the 9% reduction.
For the math-challenged, the equation for reducing a tire's load rating: max load x 0.91 = reduced load rating. From the example above: 1709 x 0.91 = 1555.
Commercial Tires:
Speaking of C, don't confuse C with C. What? When a tire is designated as 205/65R15C, that C is not a load range indicator; it is a tire designation meaning it is a commercial-grade tire.
Trailer Tires:
While trailer tires can meet van specs, they are specifically for trailer applications and, according to experts and manufacturers, are not to be used on drive axles. Trailer-specific tires will be designated with "ST" (such as ST205/60/15).
It should be noted that some tires are actually multi-purpose, but are labeled as trailer-only tires by tire stores, despite the tires not being designated ST. These types of tires are often described by their manufacturers as trailer tires, but are "also suitable on light trucks and vans"; not all tire stores will provide this information so be sure to visit the tire manufacturer's web site. Two tires falling into this category are Hankook RA08 and Kumho Radial 857.
Light Truck (LT) tires:
These are the tires that are preferred on vans, with a load range of C or D (or higher), and a load index of 97 or higher (if going by Volkswagen's specifications). Light truck series tires will be designated LT (such as LT205/65R16).
Currently Available & Recommended Tires
Notes:
1) A tire that can easily fit a 4WD may not fit a 2WD, and vice versa.
2) Before you recommend your particular tire in this topic, please ensure that it is, in fact, still produced by the manufacturer.
3) This will be an ever-evolving post as tires come and go from the marketplace. If you are certain a tire on the list is no longer manufactured, please PM me to have it removed.
4) Again, please download the PDF version of this post for complete tire details including sizes, load ratings, diameters, types, etc.
14" Tires
Cooper Weather Master S/T2
General Tire Grabber AT2
GT Radial Champiro VP1
Hankook Vantra LT (RA18)
Kenda Klever A/T
Kumho Road Venture MT KL71
Maxxis Bravo MA-751
Maxxis Bravo UE-168
Nexen SV820
Nokian cLine Van
Omni United/Radar RLT 71
Yokohama Y356
14" discussion: http://www.thesamba.com/vw/forum/viewtopic.php?t=499636
15" Tires
Achilles Radial Multivan
BFGoodrich All-Terrain T/A KO2
Continental Vanco 4 Season
Falken Espia EPZ II
Falken Sincera SN250 A/S
Falken Ziex ZE950 A/S
Firestone Destination A/T
General Grabber AT2
Kumho Road Venture AT 51
Michelin Agilis CrossClimate
Michelin Defender LTX M/S
Michelin X-Ice XI3
Nokian eNTYRE 2.0
Nokian cLine Cargo
Nokian cLine Van
Nokian WR C3
Pirelli Scorpion ATR
Sumitomo HTR A/S P02
Thunderer Ranger R402
Vredestein Comtrac
Vredestein Comtrac 2 All-season
Yokohama Geolandar A/T G015
Yokohama Geolandar H/T-S G051
15" discussion: http://www.thesamba.com/vw/forum/viewtopic.php?t=488282
16" Tires
Bridgestone Dueler 422 Ecopia
Continental ContiProContact
Continental Extreme WinterContact
Continental 4x4 Contact
Falken Espia EPZ II
General Grabber AT2
Goodyear Assurance Tripletread All-season
Hankook Dynapro ATM RF10
Hankook i*Pike RW11
Hankook Ventus V2 H457
Kumho Crugen HT51
Nankang Cross-Sport All-Season SP-9
Nitto CrossTek 2
Nokian eNTYRE 2.0
Nokian cLine Cargo
Nokian cLine Van
Nokian WR C3
Toyo Versado Noir
Vredestein Comtrac
17" Tires
Nokian eNTYRE 2.0
Discontinued Tires
BFGoodrich All-Terrain KO
Continental Vanco 2
Continental Vanco 8
Cooper Discoverer M+S (14")
Firestone Destination AT (14")
Firestone TransForce HT (15")
Hankook RA08
Hankook i*Pike RS
Hercules Power CV
Goodyear Assurance Tripletred All-season
Kumho Radial 857
Kumho Road Venture AT KL78
Michelin Agilis
Nexen CP321
Nexen CP521
Nokian eNTYRE (16")
Nokian Hakkapeliitta C Van
Nokian WR G3 (15", 16")
Vredestein Comtrac All-season (14")
Additional tire information:
http://www.roadhaus.com/tires/guideline.html
http://www.busdepot.com/details/tires/
http://www.ratwell.com/technical/Tires.html
http://www.moderntiredealer.com/article/story/2008...age/2.aspx
http://www.tirereview.com/tire-types-and-load-capacity/#
Tire topics: http://www.thesamba.com/vw/forum/search.php?search...=titleonly
If anyone has a tire to recommend (ensure it is still available!), tire questions to ask, or general information to add/correct, feel free to post. Consider this the new official van tire FAQ topic.
Note: I'm no tire expert. This post (and PDF) is simply a culmination of the thousand tire topics in the Vanagon Forum.  _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
DAV!D Samba Member
Joined: September 10, 2013 Posts: 980 Location: EL CAMINO
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Sat Feb 08, 2014 9:04 pm Post subject: |
Excellent! Thanks Kamz. I know that took a ton of work/hours. Please add to the FAQs. _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
vwhammer Samba Member
Joined: May 20, 2006 Posts: 1011 Location: Boulder CO.
Posted: Sat Feb 08, 2014 9:24 pm Post subject: |
I also have the 225/70R16 Hankook Dynapro ATM that I am attempting to squeeze under an 85 tin top.
I am excited to see what I need to do.
Anyway this is a good list. |
childofthewind Samba Member
Joined: October 19, 2010 Posts: 771 Location: Eastern Sierra
Posted: Sat Feb 08, 2014 9:26 pm Post subject: |
This is very helpful. Thanks, Kamz! _________________ 1987.5 wolfsburg hardtop; 2.1
“As for me, I am tormented with an everlasting itch for things remote." - Melville |
jimeg Samba Member
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1342 Location: Snoqualmie (WA)
Posted: Sun Feb 09, 2014 12:34 am Post subject: |
I nominate for sticky!!! _________________ '91 Double Door Transporter |
1621 Samba Member
Posted: Sun Feb 09, 2014 12:46 am Post subject: |
Kam, excellent post. Another great tire to add is the Nokian WRC Cargo. It's got a higher ply-rating than similarly constructed WRC Van, with a unidirectional tread, lots of siping, and is still listed as all-weather. Very stout tire with a high load rating. I run the tall/narrow 205/75-16, Load Rated E, and they also offer other comparable sizes in 16", plus one wider 15" model. They are carried by Tires By Web, among others.
http://www.nokiantyres.com/tyre?id=10360798&group=3.01&name=Nokian
_________________ '85 Westy |
regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Posted: Sun Feb 09, 2014 6:11 am Post subject: |
PM me your land address. I'll buy ya lunch. _________________ Peace, ~R |
Tobias Duncan Samba Member
Joined: January 15, 2013 Posts: 1413 Location: Taos NM
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Sun Feb 09, 2014 12:38 pm Post subject: |
Nice work, Kam!
The Continental ContiPro Contact and Extreme Winter Contact in 225/55-16 XL have a 99H rating. 1709 lbs. at 51 PSI
I have a set of each for my van. They are really good tires and are exactly the same diameter as stock. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
insyncro Banned
Posted: Sun Feb 09, 2014 12:41 pm Post subject: |
Thank you for taking the time Kam ...awesome work  |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17283 Location: Brookeville, MD
geo_tonz Samba Member
Joined: August 01, 2012 Posts: 1473 Location: Courtenay, BC, CANADA
Posted: Sun Feb 09, 2014 3:13 pm Post subject: |
Very nice compilation!! Can't imagine what motivated you on this one!!! Make sure to sticky yourself!! _________________ ---------------------------------------------------
"Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper |
syncroid Samba Member
Posted: Sun Feb 09, 2014 3:59 pm Post subject: |
| DAV!D wrote: |
Looks good you should add the Hankook DynaPro ATM RF10 for 16 inch. 225/70/16 and I can confirm they will fit a syncro as I have them mounted on mine. Higher weight rating than the General Grabbers as well.
I've got the 225/70/16 dynapro atm rf10s on my syncro. Very tough but quite loud. Noise is partly due to my worn out shocks making them wear in a way that's made the blocks have a sloped instead of flat surface on the front pair.
Would love to compare noise levels, but not an easy figure to quote.
Good post. |
Posted: Sun Feb 09, 2014 6:05 pm Post subject: |
Tires and more info added.
| dobryan wrote: |
| Maybe call this "What TIRES fit? The ultimate tire post" And place it as Sticky so it complements the "what wheels fit..." one. |
Done (although, at least one sticky has to go... it's getting a bit out of hand; think I'll merge a few together eventually). _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Posted: Sun Feb 09, 2014 8:56 pm Post subject: |
Again, thank you so much Kamz.
Now, what I'd appreciate from the rest of the forum members would be real life reviews of these tire options (handling wet/dry, longevity, road noise, etc). For example: I have a new set of Nokian WRG3s and will be happy to report back after I've logged enough miles to have a credible opinion.
Ever get the feeling that Tire Rack's "surveys" are total BS ? I'd trust the collective wisdom of The Samba over Tire Rack ANY DAY!!! _________________ 1990 Multivan - "Ohana"
DAV!D Samba Member
Posted: Sun Feb 09, 2014 9:14 pm Post subject: |
| syncroid wrote: |
| DAV!D wrote: |
Good post. |
Sadly I didn't get to drive mine much with the new tires as I tore it apart for a engine swap. I never really had it out on a highway or really over 45mph but I didn't notice any excessive road noise from mine.
I was toying with seeing if I could squeeze them on my 2wd westy just for kicks while the syncro is tore apart. If I do, I'll report back on road noise. _________________ 86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion |
Posted: Sun Feb 09, 2014 11:37 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
| kamzcab86 wrote: |
The above is the minimum weight rating you should use when shopping for new tires. However, the lowest weight-rated tire originally installed on Vanagons by Volkswagen was 1580 lbs. (load index 97, reinforced sidewalls), which gives you a safety margin when your van is driven fully loaded.
As you pointed out elsewhere extra load passenger tires must be derated, which mean the stock 205/75r14's would have been rated at just over 1433 pounds for use on a MPV. |
big toe Samba Member
Joined: September 12, 2013 Posts: 117 Location: Richmond, VA
Posted: Mon Feb 10, 2014 10:46 am Post subject: |
Helpful info, thanks. Any way to list it in a spreadsheet? It might be easier to digest and cross compare that way.
I can't find the Kumho KL78 for sale anywhere, not even on the Kumho site. Anyone have a link?
27x8.5R14 LT
Load range: D
Load index: 101Q
Max load: 1820 lbs.
Max psi: 65 _________________ 57 R50, 60 R60, 65 Tempest, 66 Bul, 67 R69, 72 Combat, 73 Eldo, 91 SS, 91 Westy, KTM 950A, etc |
