Vince Waldon Samba Member
Joined: November 07, 2010 Posts: 451 Location: Edmonton, Alberta
Posted: Sun Apr 20, 2014 6:02 pm Post subject: Has anyone found a reliable source for outside mirrors? |
My 70 bus came with two very de-silvered outside mirrors.
Have tried a couple different flavours of replacements from CIP, also a couple originals from a local bus.
The CIP versions, not unexpectedly, don't bolt on tight to the body, loosened within a day at the swivel joint next to the body, and loosened within a couple of weeks at the back of the mirror. All of which means they don't stay adjusted for more than about 10 minutes of Edmonton potholes.
Tracked down a couple of original mirrors from someone locally who was parting out a bus. They stay tight at the body and swivel joint but the back of the mirror is again loose enough to vibrate out of adjustment after a typical trip to the store.
Anyone find a better version of repro... or know a way to bolster the originals so they stay tight at the back of the mirror?
thanks for any suggestions,
Vince _________________ Vince Waldon Edmonton Alberta CANADA
1970 baywindow |
rustbus Samba Member
Posted: Sun Apr 20, 2014 6:11 pm Post subject: |
Maybe a dumb question, but did you include the hard plastic washer between the mirror and the body? This helped mine stay put. _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
TheFonz Samba Member
Posted: Sun Apr 20, 2014 6:19 pm Post subject: |
I got two from an import store local to me called Action Auto
They were EMPI and tightened right down (though it hasn't left my garage it seems like its of solid build)
Number on the box is 98-2017b for left side _________________ -73' Westfalia
-76' Westfalia
-72' Westfalia (parts bus)
-76' Westfalia (project for my dad as a thanks)
http://www.thesamba.com/vw/forum/viewtopic.php?t=452223&highlight=
^Check out my restoration thread |
jtauxe  Samba Member
Joined: September 30, 2004 Posts: 5975 Location: Los Alamos, New Mexico, USA
Posted: Sun Apr 20, 2014 6:32 pm Post subject: |
Mirrors are one of those things where the originals just can be beat. the hard part is finding them in decent shape. One thing you can do with yours, if you the heart to do it, is bust out the glass and service the little spring and nut that is inside so that it tightens appropriately. Then you have to find new glass. My attempt have having a local glass shop shape glass to fit failed pretty miserably.
I had the same problem of the threaded mounting part being too short on mirrors I got from Bus Depot. Otherwise, they were nice -- good metal, nice binding around the glass:
http://www.busdepot.com/211857514f
and
http://www.busdepot.com/211857513f
Don't even bother with the black plastic ones, except in an emergency. They vibrate so much that you can hardly see anything:
http://www.busdepot.com/211857514h
To solve the problem of the threads being too short, you need to replace the mounting part. You could use the original ones, and if you get lucky the taper in the hole will match, but I've seen a lot of versions of that, too.
Here's a source for NOS VW mirror nut mounts:
http://www.thesamba.com/vw/classifieds/detail.php?id=1051720
I got two, and they fit well, but still do not look quite as good as the German originals. I wonder if these are really from Brazil, though the seller says Germany. At any rate, they do work. If they weren't so expensive I'd get more of these.
So, I think the best bet aside from original is the Bus Depot mirrors supplemented by the NOS mirror mounts. That ends up being about $55 per mirror. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
FreedomBuild Samba Member
Joined: September 21, 2010 Posts: 385 Location: Calgary, Alberta
Posted: Sun Apr 20, 2014 7:23 pm Post subject: |
I got some CIP1.ca ones and I like them. They tightened down with no issues of coming out of adjustment unless someone bumps them on the way by.
These ones look really nice but I'm not sure how they are. Anyone have them?
http://www.busdepot.com/12179 _________________ 1973 Campmobile rustoration in progress..
1700 Type 4 engine
Manual Transmission
Pertronix Mechanical advance distributor
Pertronix Flame Thrower coil
Weber Progressive
Come visit our Facebook page!
http://www.facebook.com/pages/Freedom-the-Campmobile/158775277473211
Click to view image |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Sun Apr 20, 2014 7:28 pm Post subject: Outside Rear View Mirror |
Tcash wrote: |
Thank YOu
1975 Kombi wrote: |
The factory OE mirrors have a longer thread length and the nut has a recess to allow the threads future extension. I bought Wolfsburg mirrors and the thread part is not enough and there is no recess in the nut. So the combination of the two Wolfsburg parts does not leave enough thread to screw into the door. Also the door has a tapered recess that does not allow the threads to catch until they are in 3 thread. I couldn't get my new mirrors tight either.
OE arm is on the right.
Zelten Samba Member
Joined: September 16, 2008 Posts: 1335 Location: Issaquah
Posted: Sun Apr 20, 2014 8:26 pm Post subject: |
I have these and I love them. Sure they aren't OEM to a 78 but they are bigger and they will never rust. _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
Posted: Sun Apr 20, 2014 8:28 pm Post subject: |
Zelten wrote: |
I have these and I love them. Sure they aren't OEM to a 78 but they are bigger and they will never rust. |
Nice. I think I may invest in some. _________________ 1973 Campmobile rustoration in progress..
1700 Type 4 engine
Manual Transmission
Weber Progressive
Zelten Samba Member
Posted: Sun Apr 20, 2014 8:32 pm Post subject: |
FreedomBuild wrote: |
Zelten wrote: |
Nice. I think I may invest in some. |
I may invest in a second pair just in case anything happens to these.
I really like mine. _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
camit34 Samba Member
Joined: January 14, 2006 Posts: 1567 Location: Chula Vista, CA
Posted: Sun Apr 20, 2014 9:29 pm Post subject: |
I picked up a set of these from Go Westy when I stopped by their shop back in '12. Put them on that day, so about 6000 miles and a year and a 1/2 and they are still holding up good.
http://www.gowesty.com/ec_view_details.php?id=2656&category_id=190&category_parent_id= _________________ In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD)
1965 Bug (SOLD) |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22659 Location: Escondido CA
Posted: Sun Apr 20, 2014 9:33 pm Post subject: |
I agree that those new plastic ones are now the best thing going. But the og ones are out there and cost less per mirror than those plastic ones. Replacement glass as well if you get used og ones and need to do a tune up.
At one of the last shows I was at I noticed Things use the same mirrors with different stems. It was the stem on the drivers side that got me thinking of a bus mod - funny this thread popped up as I did this today and this seems like a good place to share.
For me the raised height of the mirror gives a better view.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Sage79 Samba Member
Joined: September 13, 2008 Posts: 437 Location: Holland MI
Posted: Mon Apr 21, 2014 5:00 am Post subject: |
I bought my mirrors from WW with the short thread as mentioned earlier. I was able to successfully cut longer threads onto the pieces with the right sized metric die. They've been working great on my 2 buses for several years now. _________________ Dirk
'79 Westy 2.0FI
'73 Sportsmobile 1.7dual Solex 003Auto - now my daughter's
'77 delux 2.0FI 090Auto - now my son's |
Posted: Tue Apr 22, 2014 10:05 am Post subject: |
Wow... thanks all for all the thoughtful responses... very much appreciated.
Good to see most of my experiences are not just me missing something obvious. All the replacements I've found so far have the short threads. No problem... reuse the original mount, except that the taper is different on the other end, so it gets loose there. And on it goes.
Happy to be at a stage with our bus that we're being annoyed by little things... but it is annoying to not be able to see next to you.
Will investigate the vanagon option and re-glassing the set I have after tightening the back mount.
One specific follow-up question, since Canadian vendors are so much less money to deal with right now, due to the dollar, brokerage, etc:
I got some CIP1.ca ones and I like them. |
Do you remember which version? IIRC They sell 3 different "quality" levels... the cheap ones broke instantly, didn't have any luck tightening the intermediate version, but maybe that was just a fluke.
Thanks again, all!
1970 baywindow |
richparker Samba Member
Joined: November 24, 2011 Posts: 7501 Location: Durango, CO
Posted: Tue Apr 22, 2014 5:09 pm Post subject: |
jtauxe wrote: |
Not true. I have been running these mirrors since 2011. No problem seeing and they have yet to loosen up. I bought them because I don't have any chrome accessorys on my bus. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
JQ1492 Samba Member
Posted: Sat May 17, 2014 4:41 pm Post subject: |
Thanks for the info. Answered my question as well. |
chabanais Samba Member
Posted: Sat May 17, 2014 5:46 pm Post subject: |
rustbus wrote: |
Maybe a dumb question, but did you include the hard plastic washer between the mirror and the body? This helped mine stay put. |
http://www.busdepot.com/j12477 _________________ "I spud therefore I yam." |
Posted: Sat May 17, 2014 9:09 pm Post subject: |
Anyone know the source of the plastic mirrors Bus Depot sells. Are they by any chance factory mirrors from Brazil? |
Posted: Sat May 17, 2014 9:11 pm Post subject: |
After having spent too much money over the years on aftermarket crappy mirrors I finally shelled out some cash and bought two NOS units that hopefully will last for 10 to 30 years. _________________ "I spud therefore I yam." |
ewdb92 Samba Member
Joined: September 24, 2010 Posts: 505 Location: Plymouth, NH
Posted: Tue Nov 17, 2015 3:19 pm Post subject: |
Vince Waldon wrote: |
Thanks again, all!
Vince |
There does seem to be three different levels of mirror out there. My bus had the very cheap ones when we bought her and they never stayed put. We always had to adjust them after shutting a door or in a strong headwind. I just upgraded to the high-end repro mirror. The box they came in had the WW logo, tho I didn't get them from WW. The mirror to door seals came from WCM. I only have maybe 50 miles on them, but I can now shut the doors and hit a pothole (not that I do that often!) without my mirrors getting out of whack. So far I'm happy with them, but time will tell. I have also heard from one person that the middle level mirrors aren't much better than the cheap ones and they also had better luck getting the high-end mirrors.
I'll admit here that I was asked to write a review of a product for VW Heritage and while I ended up choosing the mirrors, I intend to be honest about my experience so far and in the future. For what it is worth, I agree with everyone about original mirrors - they are best.
My experience is written up on my blog and includes some photos for comparison for those interested:
https://zerotosixtyeventually.wordpress.com/2015/1...nd-review/ _________________ Erik
71 Camper
http://zerotosixtyeventually.wordpress.com/ |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5492 Location: North Texas
Posted: Tue Nov 17, 2015 3:30 pm Post subject: |
Zelten wrote: |
Zelten wrote: |
I really like mine. |
Two of the four buses in my "camping circle" run those black mirrors and love them. Mine will be wearing them by Thanksgiving.
_________________ MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super |
