lendunne Samba Member
Joined: May 10, 2007 Posts: 13 Location: Brisbane, Australia
Posted: Wed May 21, 2014 5:00 pm Post subject: Distributor Condenser Chart |
Hi VW people,
It's been some time since I was on this site but here I am again.
Does anyone have a Bosch Chart that shows the Part #s for each vehicle distributor? I run a 1969 Beetle 1500 and a 1972 Type 3 TLE (all standard Jetronic parts - with MPS units that I rebuild myself). I need to know the impedance of the Bosch condensers also. So then I can work out what condensers can be fitted to what cars and distributors. In many cases these components are interchangeable but only the length of wires and plugs are different for each condenser to be fitted to various distributors.
I am hoping somebody out there in VW-land has a file/chart that shows specs for the various Bosch condensers and what matches to points and even distributors.
I contacted Bosch in Australia - but they don't carry the technical specs for such old stock anymore. Even Germany could not help! Thanks, Len. |
EasternNotch Samba Member
Joined: January 19, 2006 Posts: 638 Location: Boston Metro West
Nate M. Samba Member
Joined: August 11, 2003 Posts: 1306 Location: Anacortes, WA U.S.A.
Posted: Wed May 21, 2014 6:01 pm Post subject: |
www.oldvolkshome.com has all the tune-up parts for virtually every distributor known to the VW world. It also has technical data for the dizzy, but NOT for each part though. _________________ Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!! |
Posted: Wed May 21, 2014 6:17 pm Post subject: |
Hi guys
Yes I did find this table on tThe Samba website. But it does not give the impedance or specs for the condensers. Here is the problem.
The 1971 VW TLE (Jetronic Fuel injected model) runs a 02 039 condenser on the distributor.
The 1972 VW TLE (Jetronic Fuel injected model) runs a 02 054 condenser on the distributor.
While the Bosch distributor on each of these models is a different Part #, the cap, points, coil, spark plugs are the same for both models.
So the way I figure it is that the condensers 02 039 and 02 054 should be interchangeable between these two model years - but maybe the wires are different lengths.
Maybe I need the advice of an auto-electrician who know these Bosch parts?
Or if I can get the impedance values of each condenser that should nail it for me.
regards, Len. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79782 Location: Sneaking up behind you
Posted: Wed May 21, 2014 6:20 pm Post subject: |
Most condensers are interchangeable. The only difference is the wire and mounting tab. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Wed May 21, 2014 10:17 pm Post subject: |
Do you know if they would have different capacitance values? _________________ The best of VW engine development!
https://www.youtube.com/watch?v=BROWqjuTM0g
71 Aussie notchback, the money pit
92 VP vacationer, old faithful never die
95 VR executive, Restored beyond factory
92 VP S Pack, bought it new old |
jadney Samba Member
Joined: January 13, 2005 Posts: 263 Location: Madison, WI, USA
Posted: Thu May 22, 2014 11:05 am Post subject: |
vlad01 wrote: |
Do you know if they would have different capacitance values? |
Many years ago I took a GR capacitance bridge down to my local foreign car FLAPS and went thru as many of their Bosch capacitors as I could find in their stock. ALL the capacitances were the same.
While it's certainly possible that there are odd cars out there that use odd values, they must be in the minority. My impression, however, is that the vast majority use the same value and the only difference is the wires and mounting.
I'm afraid I can never remember what that value was. I could measure one again if you like, but I get the impression that you've already got the answer you wanted. _________________ Jim Adney
50+ years of VW Type 3 experience
Specializing in VW Type 3 parts and service |
Joined: April 27, 2002 Posts: 6814 Location: Pentwater, Michigan
Posted: Fri May 23, 2014 1:25 pm Post subject: |
The final three digits in the Bosch parts numbers usually denotes the length of the lead wire. To my knowledge there is no difference in impedance.
The part numbers also help differentiate how the condenser attaches to the body of the distributor.
The oldvoikshome distributor list is very good but it DOES NOT contain every distributor known to the VW world. I have a thread here on the Samba on oddball distributors that is now up to five pages in length. Many of the distributors in the postings are stock. I prefer the list that's on here authored by glutamodo. His list is less confusing to use where as the oldvolkshome list has almost too much information esp for the novice. _________________ Roads Scholar
Member# 2059 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23458 Location: Kimball, Mi
Posted: Fri May 23, 2014 6:23 pm Post subject: |
tasb wrote: |
The oldvoikshome distributor list is very good but it DOES NOT contain every distributor known to the VW world. I have a thread here on the Samba on oddball distributors that is now up to five pages in length. Many of the distributors in the postings are stock. I prefer the list that's on here authored by glutamodo. His list is less confusing to use where as the oldvolkshome list has almost too much information esp for the novice. |
Got a link? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26535 Location: Douglas, WY
vlad01 Samba Member
Posted: Sun May 25, 2014 3:27 am Post subject: |
jadney wrote: |
vlad01 wrote: |
I'm afraid I can never remember what that value was. I could measure one again if you like, but I get the impression that you've already got the answer you wanted. |
yep! answers my question. I just wanted to know out of curiosity. Thanks. _________________ The best of VW engine development!
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5560 Location: Lefty, CA
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36025 Location: Conejo Valley, CA
Posted: Mon May 26, 2014 11:22 am Post subject: |
99% of all automotive condensers are rated from 0.2 μF to 0.33 μF, including those in our VWs. |
KTPhil  Samba Member
Posted: Mon May 26, 2014 11:42 am Post subject: |
Yup. |
Posted: Thu May 29, 2014 3:05 am Post subject: |
Hi Guys
And thank you for the intel on this vexing question.
I finally got hold of somebody at Bosch who also helped. All the Bosch condensers for VW/Porsche (that we are discussing here) seem to be the same impedance rating. 0.22MF.
There, so that nails it!
I thought this was the case - but the Bosch-man confirmed it.
Interesting about the last three digits in the Part # ID-ing the wire length. Seems logical. Anyway, now I'm set, I can go ahead and play away without any issue of condenser malfunction. Thanks to all for the input here. Regards, Len. |
