SweetCars Samba Member
Joined: July 23, 2009 Posts: 219 Location: Dominican Republic
Posted: Fri May 30, 2014 7:49 pm Post subject: Tins under cylinders are they essential? |
| I just bought a complet header for my car. Stock 1600. I have to take off the tins under the cylinders, is this going to cause my engine overheating?? |
Danwvw Samba Member
Joined: July 31, 2012 Posts: 8895 Location: Oregon Coast
Posted: Fri May 30, 2014 7:54 pm Post subject: |
As they spread the air and force it over the fins on the back side of the cylinders and block some of the air they increase the air flow over the heads too. I would think the cylinders need them to keep from running hotter on the bottom side than the top! Probably not too big a deal for a drag race engine. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Fri May 30, 2014 7:59 pm Post subject: |
| first off ...what exzactly tins are you refeering too??? there lottsa tin in these cars/busses..... some ok, some not ok to loose |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3804 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Fri May 30, 2014 9:14 pm Post subject: |
| mark tucker wrote: |
Deflector tins (below cylinders).
Don't run without them. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Fri May 30, 2014 10:16 pm Post subject: |
| are you referring to heater box sled shaped tins? Those protect pushrod tubes and deflect hot air away from engine. The cylinder air deflector plates or cool tins that attach to cylinder studs under cylinders is an absolute must to direct air around cylinders. |
stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
Posted: Sat May 31, 2014 9:58 am Post subject: |
He means the sled tins. They do get in the way of my Bugpack merged header, mine are still on but I had to bend them. The little deflector fins won't be in the way and would be difficult to remove anyway.
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
Posted: Sat May 31, 2014 10:51 am Post subject: |
I think he needs to reply as to just what tins, but there is no need to remove the cylinder tins for a header,just the "sled" tins on some apps.or trim&modify to fit if you want to keep them.I personaly dont run any of that stuff but I think there good for road cars as well as offroad cars in directing&helping the used heated air out the rear easyer.my butt has been chewed so much on my spellen& grammer(still in cali)I no longer have a rear....  |
57 Rag Samba Member
Joined: October 24, 2006 Posts: 1145 Location: Paradise
Posted: Sat May 31, 2014 12:34 pm Post subject: |
I personally run as much of the tins possible on all the engines Ive had. Like said before, its essential in cooling and them germans put them there for a reason. I just like to "massage" them into place if necessary.
Ohhhhh and Mark. Its "easier" with an i. lol jus kidding bro. you ragged yourself so id figure id laugh with you.  _________________ 57 Ragtop
84x94 86C
IDAs |
Posted: Sat May 31, 2014 1:09 pm Post subject: |
| Quote: |
| He means the sled tins. They do get in the way of my Bugpack merged header, mine are still on but I had to bend them. The little deflector fins won't be in the way and would be difficult to remove anyway. |
yes i mean the sled thins, which protect the push rods.
People told me that they are there only for protecting push rods. I guess helps for cooling. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80458 Location: Sneaking up behind you
Posted: Sat May 31, 2014 1:11 pm Post subject: |
| SweetCars wrote: |
| People told me that they are there only for protecting push rods. |
They are wrong. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
tattooed_pariah Samba Member
Joined: April 24, 2006 Posts: 2064 Location: El Cajon, CA
Glenn  Mr. 010
Posted: Sat May 31, 2014 2:06 pm Post subject: |
Unless you're smarter than the VW engineers, i'd suggest using every piece of tin the engine originally came with. Because if it wasn't needed, they wouldn't of put it on at the factory.
By every piece i don't mean just the large pieces, I mean the hoover bit, the lower tins that close off by #2 and #4 and the little square tins that fit in the heads (which no replacement head includes).
My 2180 with 9.5cr in a full body sedan has the stock oil cooler with the only additions of 1.5qt sump and remote filter and runs cool as a stock 1600.
That's because I use all the factory tin. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sat May 31, 2014 4:25 pm Post subject: |
| Well I going to put the original exhaust system. Thanks for your advices and knowledge. |
Dwayne_71SB Samba Member
Joined: February 26, 2009 Posts: 277 Location: Atlanta, GA
Posted: Mon Jun 02, 2014 6:34 am Post subject: |
It's not hard to make your own tin so you can use the header and not sacrifice cooling.
_________________ '71 Super Beetle |
Glenn  Mr. 010
Posted: Mon Jun 02, 2014 7:45 am Post subject: |
| Dwayne_71SB wrote: |
| It's not hard to make your own tin so you can use the header and not sacrifice cooling. |
Just get a header that clears the tins and thermostat and a set of Type 126 tins.
Member #1009
#BlueSquare
