volkaholic1 Samba Member
Posted: Sun Jul 27, 2014 1:11 pm Post subject: vw cylinder heads, deli sliced |
I know I will catch some flake for this, but I needed to do it. I wanted to see how thick the metal was in the cylinder heads. I plan on going type plug on type iv heads, and I have only found 2 folks that will do it, and they only sell complete engines, so that is not an option for me. I cut them on the horizontal band saw a work, it did not take too long. don't worry, these heads are junk from broken fins.
type iv on the left, type 1 on the right
exhaust valve
intakes
spark plugs, note that angle and chamber shape differences
planned plug location, 100 thread, 16mm plug clearence, 22mm socket clearance
_________________ Volkaholic |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80536 Location: Sneaking up behind you
Posted: Sun Jul 27, 2014 1:19 pm Post subject: |
Very cool... thanks for posting. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
modok Samba Member
Joined: October 30, 2009 Posts: 27754 Location: Colorado Springs
Posted: Sun Jul 27, 2014 1:25 pm Post subject: |
Flack? heck no. Junk heads are more common than good ones,
I did a type-1 about 8 years ago and it looked just like the PICs from the one they cut apart in "how to hotrod" from 1970. Not much changes
Never seen a type-4 done tho that's cool  |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5573 Location: Holland, MI
Posted: Sun Jul 27, 2014 2:08 pm Post subject: |
Thank you for posting! That is pretty cool to see a Type 4 head sectioned like that. _________________ 1800 Type 4 Berrien 295
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Sun Jul 27, 2014 2:53 pm Post subject: |
| been there done that,used to do v8 iron heads to see how far they could be ported saftly.there is a lot you can see with your head sliced up. |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Sun Jul 27, 2014 2:59 pm Post subject: |
Yes sections can confirm - or otherwise! - the validity of an idea.
Are you researching a twin-plug conversion? |
Posted: Mon Jul 28, 2014 11:13 pm Post subject: |
that is my plan, twin plug the type iv heads myself _________________ Volkaholic |
dawie Samba Member
Joined: July 27, 2008 Posts: 222 Location: Cape Town, South Africa
Posted: Mon Jul 28, 2014 11:51 pm Post subject: |
Thanks for sharing.
While there are many pictures around of heads sectioned through the ports, this is the first time i see one sectioned through the plug hole position.
Personally, with a type 4 head, i would not mind removing pushrod tubes when replacing lower plugs. This is easy, as unlike a type 1, they just slide out without having to remove the heads. Valve clearances have to be adjusted in any case, so removing the rocker assemblies when replacing lower plugs would be no problem for me. |
58 Plastic Tub Samba Member
Joined: September 03, 2007 Posts: 533 Location: Nowhere, USA
Posted: Tue Jul 29, 2014 4:48 am Post subject: |
Thanks for posting, Clark. That's going to be fantastic! _________________ Stan Galat
"A single point in isolation is a reference point. Two points is a line. Three points is a trend. Trends don't lie." |
VWCOOL Samba Member
Posted: Tue Jul 29, 2014 4:56 am Post subject: |
| volkaholic1 wrote: |
| that is my plan, twin plug the type iv heads myself |
yes it works well  |
Posted: Tue Jul 29, 2014 10:03 am Post subject: |
yes, it looks like it might be easiest to plan on pulling 1 push rod tube, or mabye just make a special spark plug wrench, either way it can be done, we shall see _________________ Volkaholic |
Howard 111 Samba Member
KROC Samba Member
Joined: February 20, 2006 Posts: 364 Location: Vancouver B.C.
Posted: Fri Aug 01, 2014 3:36 pm Post subject: |
| Damm, you really can see how crappy the exhaust port is on the T4 head this way..... |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23522 Location: Oklahoma City
Posted: Fri Aug 01, 2014 5:53 pm Post subject: |
| Yes....there is a really nice set of type 4 sections on the STF about 6 years ago. They were section very well to show just what could and could not be ported on a type 4 head exhaust and the otherwise better that type 1 intake port and angle. Nice work! Always something to be learned. Ray |
Posted: Sat Aug 02, 2014 9:20 am Post subject: |
whats rong with the exhaust port?
might be able to relocate the pushrod tube some for better clearance. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Sat Aug 02, 2014 1:23 pm Post subject: |
The mega exhaust guide boss, you could take a pound of aluminum out of that monstrosity. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| Glenn wrote: |
| satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Posted: Sun Aug 03, 2014 6:05 pm Post subject: |
| KROC wrote: |
Stock for stock, the Type 4 head flowed better than the Type 1 ever did. It only ever becomes an issue to the people building huge engines that need extra porting on the exhaust, but such engines are quite a bit bigger than any Type 1s' I have seen built. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Sun Aug 03, 2014 7:48 pm Post subject: |
I agree...stock to stock the type 4 heads flowed better.....but the issue with the exhaust port....and im going by like 6 years ago memory here so dont re quite this.....but from work that Jake Raby and HAM did....which spawned the original set of picture of deli sliced type 4 heads on the STF........
Where the type 4 exhaust port was found to benefit the most....getting greater exit velocity....was on the bottom side of the exhaust port....where there is very little meat as you can see in the picture.
Yss removing a hunk of guide boss gives more room for expansion/voulume....but with a bit more sectioning you find that right behind that hump is the exhaust stud. No much room to move and only so much deck holding that valve seat in.
Yes...its a better head than thpe 1 stock to stock but there is little room for modification. Ray |
Posted: Sun Aug 03, 2014 8:28 pm Post subject: |
| a good head porter should have no issues with that port porting it correctly for what it is. yes I saw the turd,but like I said...good head porter. |
