vw cylinder heads, deli sliced
volkaholic1
volkaholic1 is offline
PostPosted: Sun Jul 27, 2014 1:11 pm    Post subject: vw cylinder heads, deli sliced Reply with quote
I know I will catch some flake for this, but I needed to do it. I wanted to see how thick the metal was in the cylinder heads. I plan on going type plug on type iv heads, and I have only found 2 folks that will do it, and they only sell complete engines, so that is not an option for me. I cut them on the horizontal band saw a work, it did not take too long. don't worry, these heads are junk from broken fins.
type iv on the left, type 1 on the right
exhaust valve
intakes
spark plugs, note that angle and chamber shape differences
planned plug location, 100 thread, 16mm plug clearence, 22mm socket clearance
Volkaholic
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jul 27, 2014 1:19 pm    Post subject: Reply with quote
Very cool... thanks for posting.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
modok
modok is online now
PostPosted: Sun Jul 27, 2014 1:25 pm    Post subject: Reply with quote
Flack? heck no. Junk heads are more common than good ones,
I did a type-1 about 8 years ago and it looked just like the PICs from the one they cut apart in "how to hotrod" from 1970. Not much changes
Never seen a type-4 done tho that's cool Very Happy
Vanapplebomb
Vanapplebomb is offline
PostPosted: Sun Jul 27, 2014 2:08 pm    Post subject: Reply with quote
Thank you for posting! That is pretty cool to see a Type 4 head sectioned like that.
1800 Type 4 Berrien 295
mark tucker
mark tucker is offline
PostPosted: Sun Jul 27, 2014 2:53 pm    Post subject: Reply with quote
been there done that,used to do v8 iron heads to see how far they could be ported saftly.there is a lot you can see with your head sliced up.
VWCOOL
VWCOOL is offline
PostPosted: Sun Jul 27, 2014 2:59 pm    Post subject: Reply with quote
Yes sections can confirm - or otherwise! - the validity of an idea.
Are you researching a twin-plug conversion?
volkaholic1
PostPosted: Mon Jul 28, 2014 11:13 pm    Post subject: Reply with quote
that is my plan, twin plug the type iv heads myself
Volkaholic
dawie
dawie is offline
PostPosted: Mon Jul 28, 2014 11:51 pm    Post subject: Reply with quote
Thanks for sharing.
While there are many pictures around of heads sectioned through the ports, this is the first time i see one sectioned through the plug hole position.
Personally, with a type 4 head, i would not mind removing pushrod tubes when replacing lower plugs. This is easy, as unlike a type 1, they just slide out without having to remove the heads. Valve clearances have to be adjusted in any case, so removing the rocker assemblies when replacing lower plugs would be no problem for me.
58 Plastic Tub
58 Plastic Tub is offline
PostPosted: Tue Jul 29, 2014 4:48 am    Post subject: Reply with quote
Thanks for posting, Clark. That's going to be fantastic!
Stan Galat
"A single point in isolation is a reference point. Two points is a line. Three points is a trend. Trends don't lie."
VWCOOL
VWCOOL is offline
PostPosted: Tue Jul 29, 2014 4:56 am    Post subject: Reply with quote
yes it works well Wink
volkaholic1
PostPosted: Tue Jul 29, 2014 10:03 am    Post subject: Reply with quote
yes, it looks like it might be easiest to plan on pulling 1 push rod tube, or mabye just make a special spark plug wrench, either way it can be done, we shall see
Volkaholic
Howard 111
Howard 111 is offline
PostPosted: Tue Jul 29, 2014 10:11 am    Post subject: Reply with quote
A nice job, thanks for posting it.
1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270
KROC
KROC is offline
PostPosted: Fri Aug 01, 2014 3:36 pm    Post subject: Reply with quote
Damm, you really can see how crappy the exhaust port is on the T4 head this way.....
raygreenwood
raygreenwood is offline
PostPosted: Fri Aug 01, 2014 5:53 pm    Post subject: Reply with quote
Yes....there is a really nice set of type 4 sections on the STF about 6 years ago. They were section very well to show just what could and could not be ported on a type 4 head exhaust and the otherwise better that type 1 intake port and angle. Nice work! Always something to be learned. Ray
mark tucker
PostPosted: Sat Aug 02, 2014 9:20 am    Post subject: Reply with quote
whats rong with the exhaust port?
might be able to relocate the pushrod tube some for better clearance.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Sat Aug 02, 2014 1:23 pm    Post subject: Reply with quote
The mega exhaust guide boss, you could take a pound of aluminum out of that monstrosity.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
Vanapplebomb
PostPosted: Sun Aug 03, 2014 6:05 pm    Post subject: Reply with quote
Stock for stock, the Type 4 head flowed better than the Type 1 ever did. It only ever becomes an issue to the people building huge engines that need extra porting on the exhaust, but such engines are quite a bit bigger than any Type 1s' I have seen built.
raygreenwood
PostPosted: Sun Aug 03, 2014 7:48 pm    Post subject: Reply with quote
I agree...stock to stock the type 4 heads flowed better.....but the issue with the exhaust port....and im going by like 6 years ago memory here so dont re quite this.....but from work that Jake Raby and HAM did....which spawned the original set of picture of deli sliced type 4 heads on the STF........
Where the type 4 exhaust port was found to benefit the most....getting greater exit velocity....was on the bottom side of the exhaust port....where there is very little meat as you can see in the picture.
Yss removing a hunk of guide boss gives more room for expansion/voulume....but with a bit more sectioning you find that right behind that hump is the exhaust stud. No much room to move and only so much deck holding that valve seat in.
Yes...its a better head than thpe 1 stock to stock but there is little room for modification. Ray
mark tucker
PostPosted: Sun Aug 03, 2014 8:28 pm    Post subject: Reply with quote
a good head porter should have no issues with that port porting it correctly for what it is. yes I saw the turd,but like I said...good head porter.
