wyomingriviera Samba Member
Joined: October 04, 2006 Posts: 384 Location: Vee-Tee
Posted: Thu Aug 21, 2014 7:20 am Post subject: Fuel delivery issue...am I on the right track? |
Towed home in shame last week; had spark, but not getting gas. Here's what I've found since:
When fuel pump is wired directly to 12v power, she fires right up, but dies immediately. Fuel pressure reads 35 psi, but drops to about 28 when it fires up, and dies shortly after. It's a 2.0 GD motor, stock fuel injection.
Is this a symptom of only the fuel pressure regulator, or is the double relay to blame as well? _________________ '77 Rivi 2.0 T2 GD
"I tell you, we are here on Earth to fart around, and don't let anybody tell you different."- Kurt Vonnegut |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53244 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Aug 21, 2014 7:23 am Post subject: |
Does the pressure continue to read 28 as it dies? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Aug 21, 2014 7:34 am Post subject: |
It goes back to 35 soon after it dies. Pressure drops when engine fires _________________ '77 Rivi 2.0 T2 GD
Posted: Thu Aug 21, 2014 7:45 am Post subject: |
It's normal for the pressure to drop when it gets engine vacuum, sounds like it's doing what it's supposed to. If you have the pump wired directly to 12 volts then the double relay is out of the picture so I can't say if it's to blame right now, since fuel pressure maintains it seems the pump is working and the feed from the tank isn't restricted.
So that leaves us with a large vacuum leak or an issue with something electrical as it seems it's only running on the prime the cold start valve provides. Is the black wire laying along the left of the engine with the fuse holder in it connected to terminal #15 on the coil?, is the single whitish wire from the ECU connected to #1 on the coil? When you bypassed the double relay did you unplug it or is the rest still connected? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17783 Location: San Diego, California
Posted: Thu Aug 21, 2014 9:01 am Post subject: |
I'm not that good at this but I'd suspect the double relay. As I understand it, when you crank the engine power is supplied from one source to the electric fuel pump. Once you quit cranking the power changes over to another source. Seems to me like when that change happens is when your pump stops and soon the engine will die. I'm sure you can search for a double relay test procedure here somewhere. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Thu Aug 21, 2014 9:50 am Post subject: |
| This is the classic symptom of a large vacuum hose being off. Could also be something like the plug on the AFM not being fully seated. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42986 Location: at the beach in Northern Wokistan
Posted: Thu Aug 21, 2014 9:54 am Post subject: |
to the OP - all of the above posters are correct on things you will need to check over. There is also the ignition switch which adds another set of contacts in the start position vs the run position. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
Posted: Thu Aug 21, 2014 11:54 am Post subject: |
I was hopeful it was the Auxiliary Air valve, but that was seated firmly. I left the double relay attached when I patched power to the fuel pump. I'll check the wires when I can (out of state right now).
Frustrating because it rolled into the campground just fine
Thanks for all the help so far, Sambanistas! _________________ '77 Rivi 2.0 T2 GD
Randy in Maine Samba Member
SGKent  Samba Member
Posted: Thu Aug 21, 2014 2:00 pm Post subject: |
where are you now - you say you are camping. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
my59 Samba Member
Joined: August 13, 2003 Posts: 4017 Location: connecting the dots
Take a look at the brown ground wires at the relay. Make sure the one that goes into the relay plug is plugged all the way into the relay. I have one that is loose and has a habit of falling down inside the plastic plug housing if I mess with the relay.
Tighten the ground connection that is under the plenum on the drivers side.
If it just started when you got to your destination....did you hit a bump on the way in that may have jarred something loose? _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
SGKent  Samba Member
Posted: Thu Aug 21, 2014 2:44 pm Post subject: |
when you have the time, let's go over the symptoms again. Here is why - you indicate when the fuel pump is wired to 12V the bus starts and dies. Let's discuss what being wired to 12V directly means. Are you running a wire from the battery to the pump for example? Are you running a secondary power source? Is the wire back to the starter still in the circuit? Are you starting it with a screwdriver or the ignition key, remote starter etc.?
Let's carefully explain how we are doing this because I can see lots of ways that the issue can be fuel, vacuum or electrical based on what you have said. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Sun Aug 02, 2015 4:36 pm Post subject: |
Ok, it's been a while, but better late than never....
When I try to start my bus, no go. No power to the fuel pump. Fuel pressure is at zero.
When I wire the fuel pump to the ignition coil (terminal 15) and I turn the key to position 2, the pump turns on, and fuel pressure goes to ~35psi. I then hit the starter button (came from the PO that way) it fires up for about a second, then dies.
I've done the Bentley tests 4.1 in the fuel injection section. It passed the current supply, but usually fails the test relay function. I say usually because out of the five or six times I've done it, it fired up and stayed running twice.
When the double relay fails, does it usually fail absolutely, or can it work intermittently? _________________ '77 Rivi 2.0 T2 GD
Posted: Sun Aug 02, 2015 4:57 pm Post subject: |
| wyomingriviera wrote: |
| When the double relay fails, does it usually fail absolutely, or can it work intermittently? |
Yes!  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Sun Aug 02, 2015 5:54 pm Post subject: |
Make sure connections on the wire from the double relay to the starter term. #50 have good connections.
Pull the air cleaner out, turn the key on to position 2, use a pen and open the flap inside the AFM (air flow meter) does the pump come on?
The pump should keep running connected directly to the coil. Check the pump ground.
Check the connections and the ground for the double relay.
http://www.itinerant-air-cooled.com/viewtopic.php?f=50&t=5459
good luck
Tcash |
Posted: Sun Aug 02, 2015 5:56 pm Post subject: |
If hot wiring the pump didn't do the trick, that should tell you the issue was not the fuel pressure or the system that provides it. |
Posted: Sun Aug 02, 2015 6:10 pm Post subject: |
Word, the AFM flap trick doesn't do anything. When someone cranks the engine, it starts when I hear a click from the double relay. If I don't hear the click, it doesn't start _________________ '77 Rivi 2.0 T2 GD
Tcash Samba Member
Posted: Sun Aug 02, 2015 6:16 pm Post subject: |
Does it stay running after it starts? |
| One side of the double relay is the fuel injection relay. You should hear it click whenever you turn the key to the "run" position. The fuel pump relay will not activate if the FI relay doesn't close. |
Posted: Wed Aug 05, 2015 10:27 pm Post subject: |
New double relay, works like a charm!
Thanks for the help!
Looking back, the double relay had been slowly dying, giving me lots of grief over the last few years  _________________ '77 Rivi 2.0 T2 GD
