Canoes and Convertibles
Revelen
Revelen is offline
PostPosted: Thu Aug 28, 2014 5:29 am    Post subject: Canoes and Convertibles Reply with quote
Alright, bit of an out there, impractical question, I know!
We've got a 1972 super 'vert, and we've got a 16" canoe. Transportation of said canoe is a bit tricky, using said car...
I'm considering welding some mounts to the support rails, and then building a removable cage/psuedo-roof rack of sorts, and tying down to that and the bumper mounts.
There's also the option of a trailer-hitch T-mount thingy and the front windshield, that I've seen on a few other makes of 'verts around the interwebs...
Any thoughts or suggestions?
(Also, yes, we've considered a small trailer, but we'd reaaaaally rather not!)
I probably have no idea what I'm talking about. That's honesty, not shrouded modesty. No, really.
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Thu Aug 28, 2014 5:39 am    Post subject: Reply with quote
if you look at the bumper mounts on my bug, you can see the mounts welded to the bracket to install removable a roof high rack made out of square tubing. There are also some on the front bumper. I can take pics of the rack later if you want.
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
Revelen
Revelen is offline
PostPosted: Thu Aug 28, 2014 5:57 am    Post subject: Reply with quote
That's pretty much exactly what I was hoping to do, a square-tubing rack. When we get home from this camping trip, I think the welder may just be coming out....
jhicken
jhicken is offline
PostPosted: Thu Aug 28, 2014 6:21 am    Post subject: Reply with quote
How about a few heavy blankets and a couple ratchet straps? Also run a lanyard tying down the fore and aft of the canoe.
-jeffrey
Der Kleiner Kampfwagens
gt1953
gt1953 is offline
PostPosted: Thu Aug 28, 2014 6:58 am    Post subject: Reply with quote
Pull a light weight trailer. May be more practical.
72 type 1
72 Squareback
Randy in Maine
Randy in Maine is offline
PostPosted: Thu Aug 28, 2014 8:21 am    Post subject: Reply with quote
Here is a trailer I see similar cars using around here to transport not only a canoe, but yaks and bikes. They are pretty light.
http://www.amazon.com/Malone-MicroSport-Sports-Tra...ak+trailer
60ragtop
60ragtop is offline
PostPosted: Thu Aug 28, 2014 8:55 am    Post subject: Reply with quote
I do not have the front rack but you get the idea and you don't have to tow a trailer Wink
This bug was owned by an oilfield engineer and he hauled equipment with it
so I guess this set up would work for a canoe Smile
Rick
DWP
DWP is offline
PostPosted: Thu Aug 28, 2014 1:48 pm    Post subject: Reply with quote
What about a bracket that mounts just to the front and rear bumpers?
Bolt it on when you need. This way you would still have use of the
convertible top.
DWP
hitest
hitest is offline
PostPosted: Thu Aug 28, 2014 5:49 pm    Post subject: Reply with quote
Hey 60ragtop- I don't think he wants to buy a hardtop just for the canoe... Cool
Second vote for the canoe trailer. There are a ton on the net- and your local CL should produce a single axle utility; MC or PWC trailer you could alter easily for the job.
FU#5
60ragtop
60ragtop is offline
PostPosted: Thu Aug 28, 2014 6:16 pm    Post subject: Reply with quote
Yep, doesn't need a buy hardtop for the bumper mounted racks which will work on a vert also. At least I understand what he is asking about as he'd prefer not to tow a trailer Wink
I didn't see a poll to vote Laughing
Rick
Revelen
Revelen is offline
PostPosted: Sat Aug 30, 2014 7:57 am    Post subject: Reply with quote
Thanks for all the responses, guys!
We COULD do a trailer, but we'd definitely like the compact-ness of going without...
Right now, the bumper mounts are looking like the way to go!
hitest
hitest is offline
PostPosted: Sat Aug 30, 2014 11:57 am    Post subject: Reply with quote
60ragtop wrote:
It definitely helps to see this thing with a useful picture. Even better if you had one on the front. I'd probably go this route too- but my canoe is 17 feet long- and should not be supported so close to its ends. The gunwale load spread is only 5 feet. Hope it works out.
FU#5
mikeonthebike
mikeonthebike is offline
PostPosted: Sat Aug 30, 2014 12:01 pm    Post subject: Reply with quote
you can always throw a support under the canoe like a 2X6 or a 4X4.
