kalispell365 Samba Member
Posted: Wed Jul 16, 2014 4:14 pm Post subject: 110 amp alternator upgrade for your Subaru conversion CHEAP |
Here is a simple upgrade to give your van real alternator power. 110 Amps!
If you have ANY 4 cylinder besides 1990-94 legacy EJ22, this is simply a bolt on deal. It will just clear the mounting brackets without modification.
If you have 1990-94 EJ22, you will need to hack the large white charge wires as well as the small green alternator plug and attached wires from the donor (or ANY 1995 and newer Subaru.) The black/ white wire on the plug closest to the main charge wire lug is for your charge light. The middle blue wire is the SENSE wire, and should go to the +12v stud in your black engine junction box.I will attach a link about that. I prefer the harness from the same vehicle as the alternator simply because the white charge wires are larger, but any 95 and newer will work as well.
On any 95 and newer conversion, you should already have all the correct connections, but I encourage you to check the sense wire hookup, as it will correctly maximize the charging if hooked up as I have explained.
The correct alternators are the following part numbers and applications:
23700AA55A - 2005-2009 Legacy and Outback 2.5 non-turbo
23700AA520 - 2005 Legacy Turbo and 2006-2009 Forester TURBO, 2007-2009 Impreza TURBO.
Either of these will work and interchange. I get these on Ebay used for 15.00! These are also super easy and cheap to replace brushes yourself and will otherwise last forever.
Here is some information on the sense wire and its proper function. This is for Toyota, but the sense wire hookup is identical. Some of the other information doesn't apply, as the Toyota uses a third IG wire that the Subaru does not.
http://wilbo666.pbworks.com/w/page/39441708/Toyota%20Alternators#AlternatorRegulatorSTerminal
Enjoy! _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l
Last edited by kalispell365 on Wed Jul 16, 2014 4:36 pm; edited 4 times in total |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17293 Location: Brookeville, MD
Posted: Wed Jul 16, 2014 4:20 pm Post subject: |
Dave...
Sorry, I keep trying to get the time to write this up, I have been doing these on customer vans and Subaru cars for some time now. Awesome power for next to nothing, no custom wound alternator either. _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12406 Location: Santa Cruz, CA
Posted: Wed Jul 16, 2014 4:59 pm Post subject: |
| 130 amps from a '10+ tribeca and legacy with 3.6l motor. |
mackaymanx Samba Member
Joined: October 12, 2006 Posts: 480 Location: Australia
Posted: Wed Jul 16, 2014 5:26 pm Post subject: |
Be very careful with this, later alternators are controlled by the ecu. I used an alternator from a 2006 Liberty(Legacy) on my 1996 EJ22 in my Syncro conversion and it put out 20 volts.
Not sure if they use pulse width modulation or some other method to control the voltage but the engine ECU is involved. |
Posted: Wed Jul 16, 2014 5:37 pm Post subject: |
I get normal voltage, checked it several times.
Thanks for the heads up though. |
Posted: Wed Jul 16, 2014 5:54 pm Post subject: |
Might depend on the model, alternator terminals are labeled L S C . Light Sense Computer?
Alternator also has a larger diameter and a different power steering pump bracket to suit which only takes the later style pump.
Could be the difference between U.S. and Australian models |
insyncro Banned
Posted: Wed Jul 16, 2014 7:22 pm Post subject: |
| syncrodoka wrote: |
Yes Sir...gotta love the H6s.
The EG33 from the SVX has a 120 amp alt.
The EE20 diesel has a monster alt (190 amp) due to electric power steering  |
Posted: Wed Jul 16, 2014 7:56 pm Post subject: |
The C pin on the second alternator that I listed will cause no harm if left blank on a Subaru that does not have an ecu with this function. That is the basic difference between the two alternators that I referenced. _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
Posted: Wed Jul 16, 2014 7:57 pm Post subject: |
| insyncro wrote: |
| syncrodoka wrote: |
The factory SVX alternator is 95 amp.
I only chose the Legacy alternator because I don't like the extra rib on the pulley of the H6 alternator,and they don't interchange with the 5 rib pulley.This is only cosmetic I know but Im stupid like that  _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
Posted: Wed Jul 16, 2014 9:16 pm Post subject: |
With the tribeca alternator you only hook up the sense wire and idiot light wire for a EJ22 converted van, the later alt plug is used of course. The factory white wire is eliminated from the alt plug and they only feed the 12v post. 3/16" needs to be cut off of the alternator bracket and it goes right in.
My 130 amp alt doesn't put out high voltage at any rev.
I removed the 6 rib pulley off of my '11 legacy alt and put on a 5 rib pulley from a SVX because I had one around but I left the tribeca 6 rib pulley intact and run it as is since you don't see it anyways.
I paid $60 for this 20K mile 2011 tribeca unit.
Posted: Thu Jul 17, 2014 5:42 am Post subject: |
That looks great!
Good price on the alternator as well, those are generally quite a bit more. The irony is the factory early EJ22 alternator is super expensive and I could never find brushes for them, they are Hitachi and not a common rebuild. All of these Mitsubishi built alternators in this thread including yours share the same brushes and are so easy to rebuild.
I wish I could have the belt guard like yours installed, but I have no power steering (or a/c for that matter). _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
Posted: Thu Jul 17, 2014 5:50 am Post subject: |
| kalispell365 wrote: |
Good to know.
Thanks.  |
insyncro Banned
Posted: Thu Jul 17, 2014 9:50 am Post subject: |
I purchased a few, brand new 130 amp alts for my EZ36r conversions.
$178 per alt, direct from Subaru.
That is with my shop discount. |
Posted: Tue Jul 29, 2014 7:08 pm Post subject: Re: 110 amp alternator upgrade for your Subaru conversion CH |
I get these on Ebay used for 15.00! |
Hey Kalispell, My 'Reman' alternator started to die after 2 months and NAPA just replaced it. Needless to say I am less than impressed with the quality....
I did an Ebay search for the used 110 amp version and couldn't find anything close to the $15 price you get them for. If you could help me by posting a link to an ebay sale?
I want to carry a spare. (Yes, I am a little OCD about spares.... these days I'd carry a tranny if I could... )
Thanks!  _________________ Dave O
The Western Syncro build
Posted: Tue Jul 29, 2014 7:47 pm Post subject: |
Hazle Auto Parts, Inc. USA-PA(Hazleton) 1-877-459-1415
These guys have like ten right now...$18.98 No more on ebay they all sold quickly after I posted this.
If these don't work, PM me and ill find you more easily.  _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
Posted: Tue Jul 29, 2014 8:16 pm Post subject: |
Also, once again I recommend that you learn how to replace brushes, It really takes the guesswork out of the dependability of an alternator. If you start out replacing brushes and polishing the copper slip ring they ride on, you will never need to carry a spare.
Such cheap and easy insurance. Ill never buy a reman/ new alternator again! _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
