gates barricade 5/16" fuel hose clamp
physast
physast is offline
PostPosted: Tue Oct 07, 2014 3:13 pm    Post subject: gates barricade 5/16" fuel hose clamp Reply with quote
I really did search for this...
What size hose clamps do you use on the gates barricade 5/16 ID fuel hose?
I have some from van-cafe, but would like to use the ear style clamp on most connections.
Thanks for the help.
1967 L633 VW beetle (currently being restored...slowly)
1991 Orly Blue Vanaru 2.5L
vanagonjon
vanagonjon is offline
PostPosted: Tue Oct 07, 2014 3:25 pm    Post subject: Reply with quote
You need to size the clamp to the OD, go online and look up Oetiker, the German company that makes the ear type clamps. They come in number sizes based on hose OD range. you will need something around a size 17 to 20 I guess based upon my clamps I just looked at.
John
physast
physast is offline
PostPosted: Tue Oct 07, 2014 3:34 pm    Post subject: Reply with quote
John
That's my problem I don't know the OD of the gates hose. It's gates 27348 FI hose. I saw one mention of the OD as being 13mm, but I can't find it again. I didn't find anything on the gates website.
I will keep looking.
kalispell365
kalispell365 is offline
PostPosted: Tue Oct 07, 2014 5:11 pm    Post subject: Reply with quote
If you are doing a Subaru conversion anyway, the factory stainless Subaru fuel clamps are the nicest Ive ever come across, and they are on your donor(or any 1990 and newer Subaru at the junkyard).I use them on all fuel lines on the Vanagons.
1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l
Phishman068
Phishman068 is offline
PostPosted: Tue Oct 07, 2014 5:50 pm    Post subject: Reply with quote
The clamps I used are:
Oetiker 16700013 Stainless Steel Hose Clamp, One Ear, 7 mm Band Width, 9/16" Hose ID, 12 mm - 14.5 mm Hose OD Range (Pack of 100).
They're available on amazon for $27, so $0.27 a piece.
They do seem quite tight though, and I may be moving up to the next size up for some applications. I have used them on most of the engine and fuel connections with no problem though, they tighten down really nicely.
I am using Goodyear Hose, so i'm not sure if the OD is any different but it should be pretty much the same.
http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry."
rubbachicken
rubbachicken is offline
PostPosted: Tue Oct 07, 2014 7:08 pm    Post subject: Reply with quote
these are what i've been using for the last couple of years, i've gone through 300 or so, all the vans i've put fuel lines have had these fuel line clips these are reuseable unlike the oetiker clamps, and a good bit cheaper.
i had them on lucy for over a year before i put them on other peoples vans, no leaks on any of them.
if you pop the hood on a modern VW you will find these all over the place, and they are LOT more expensive if you buy them from VW Wink
lucy our westy
lucy's BIG adventure
meet 'burni'
physast
physast is offline
PostPosted: Tue Oct 07, 2014 7:15 pm    Post subject: Reply with quote
Do you know if this fits the gates 27348 hose? I might give these a try.
rubbachicken
PostPosted: Tue Oct 07, 2014 8:29 pm    Post subject: Reply with quote
sorry i have no idea, i don't have any gates fuel line, what's the OD of the gates fuel line, i can go and measure what i have, if that would help.
lucy our westy
meet 'burni'
djkeev
djkeev is offline
PostPosted: Wed Oct 08, 2014 4:13 am    Post subject: Reply with quote
Intellectually I understand Spring Clamps and the principle behind their function.
Be it the flat spring steel clamp or the wire spring clamp......
The constant squeezing action through expansion and contraction cycles makes perfect sense........
A proven method of installing hoses for DECADES!
In my over half century of wrenching...... I've seen very few actually fail, a few squeeze ears broken off and an old wire type simply broken ........
But.....
There is a mechanical inner force in me that doesn't quite trust them, that force wants to rotate a screw to make something tighter!
Not unlike knowing that Ice Cream isn't good for you and that frozen yogurt crap isn't as bad...... But ice cream tastes SO GOOD!!!
Rubbachicken's link.........
Dave
Ghia
Vanagon
Beetle
nmerrill
nmerrill is offline
PostPosted: Wed Oct 08, 2014 6:13 am    Post subject: Reply with quote
Hopefully not a significant drift...
Is there a specific tool out there for this type of spring clamps? I always use pliers of one sort or another...
Yes, they are all over my GTI.
Oddly, the emissions pipes also have Oetiker style clamps on them.
Phishman068
PostPosted: Wed Oct 08, 2014 6:52 am    Post subject: Reply with quote
Are those rated for fuel injection pressures?
I can't see how they possibly can be and certainly won't be using them on my bus anytime soon. They just seem so weak.
Heck, I put a new carb on our Dodge truck recently and It used these, and I wasn't overly confident with their tension to hold on a fuel line that operated at a few PSI, let alone the high pressures of the vanagon system.
To each their own I guess.
nmerrill
nmerrill is offline
PostPosted: Wed Oct 08, 2014 7:38 am    Post subject: Reply with quote
Come to think of it, I think these are only used on the GTI for cooling system hoses.
physast
physast is offline
PostPosted: Wed Oct 08, 2014 7:54 am    Post subject: Reply with quote
I think I might stick with the ABA ones from vancafe for now. I have not heard of them failing yet.
Since I am using the 5/16 gas line I just want to make sure they get snug and stay put.
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Wed Oct 08, 2014 8:08 am    Post subject: Reply with quote
ABA 21013 Stainless 13mm bolt style clamps are what you want.
88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
physast
physast is offline
PostPosted: Wed Oct 08, 2014 8:26 am    Post subject: Reply with quote
Like this?
http://www.amazon.com/AAS-Fuel-Injection-Clamps-FI...K4VRGQWJ5A
I read somewhere that these are good for low pressure hose. But these say FI in the description.
rubbachicken
PostPosted: Wed Oct 08, 2014 9:47 am    Post subject: Reply with quote
go look under the hood on a new VW, these are all over the fuel lines, if you have the right size for the hose, they clamp very well, remember over tightening damages fuel line anyway, like i posted i put them on my van first, before using them on anyone elses, they are fine.
lucy our westy
meet 'burni'
kamzcab86
kamzcab86 is offline
PostPosted: Wed Oct 08, 2014 11:22 am    Post subject: Reply with quote
http://www.amazon.com/OTC-4525-Cable-Type-Flexible...amp+pliers
Couldn't work on my VW's without my Craftsman version... it's gotten lots of use.
According to the VW parts catalog, these are the factory clamps on the fuel lines, which are spring-type: http://www.vwbusshop.de/epages/GuenzlClassicParts....iewProduct .
My van has reusable metal clamps that I've no clue what their proper name/type is. Next time I have the lid off, I'll try to remember to snap a pic of them.
2016 Golf GTI S
borninabus
Samba R&D Dept.
PostPosted: Wed Oct 08, 2014 1:19 pm    Post subject: Reply with quote
physast wrote:
Like this?
yep Smile
no special tools required
rubbachicken
PostPosted: Wed Oct 08, 2014 1:20 pm    Post subject: Reply with quote
those pliers are WAY to big for fuel line clips though.
i use just a regular pair of pliers, for the fuel line clips, those are for coolant hose clips
lucy our westy
meet 'burni'
1vw4x4
Banned
1vw4x4 is offline
PostPosted: Fri Oct 10, 2014 10:44 am    Post subject: Reply with quote
You people really know how to spend money. Pinch clamps are available
in any size you want. That's the key. Beverage companies seem to need
a lot of these. They are typically stainless steel and are about .03 to .05 each. YES that is five cent.
Bars and restaurants use these all the time. I have about 4000 of these in maybe 6 different sizes.
THey work great, look great, and are cheap.
