1960 SO23 Westy - Cabinet and Metal Restoration
Page: Previous  1, 2, 3 ... 14, 15, 16 ... 18, 19, 20  Next
grailoc
grailoc is offline
PostPosted: Sat Feb 08, 2014 8:49 pm    Post subject: Reply with quote
zuggbug wrote:
grailoc wrote:
It has been some times I did not post any updates, so here we go:
Since last of February I restored the 2 seats bases and now I am working on the panels.
Here is the drink tray panel that has been freshly restored:
Remains the holes for the water trunk and I should be done for this one.
Can u share where you purchased the westfalia badge?
I bought it from someone here on the site but can t remember who. This Guy also had very good leather stap for the curtains.
My 59 low light ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=452128
My 56 beetle convertible: http://www.thesamba.com/vw/forum/viewtopic.php?p=7796259
My 60 SO23 westy: http://www.thesamba.com/vw/forum/viewtopic.php?t=341539
My oldspeed 36hp autotechnik express build: https://www.thesamba.com/vw/forum/viewtopic.php?t=670827
My garage build: http://www.garagejournal.com/forum/showthread.php?t=199438
cab2276
cab2276 is offline
PostPosted: Tue Oct 21, 2014 9:08 am    Post subject: Reply with quote
Salut Jérome,
Je suis depuis longtemps la resto de ton bus qui est superbe et me sers de tes plants de ciel de toit pour refaire le mien
Je n'ai pas le bus sous la main (il est en révision) et il me manque une cote pour finir de couper mes planches
l'as tu noté quelque part ?
et j'imagine que cette partie s'enfonce dans la boite diffuseur d'air ?
peut être as tu une photo du détail de cette partie une fois monté ?
Merci beaucoup pour ton aide
I'm sorry for the french but my english is very bad
Guillaume
Guillaume SO 23 walk-thru and 1965 Pigalle convertible
[url=http://i43.servimg.com/u/f43/16/83/88/82/bannie11.jpg]Click to view image/url]
crofty
Judas of the North
crofty is offline
PostPosted: Tue Oct 21, 2014 9:28 am    Post subject: Reply with quote
Is there a source for the gold trim?
HamburgerBrad wrote:
sled
sled is offline
PostPosted: Tue Oct 21, 2014 12:35 pm    Post subject: Reply with quote
the trim alex was selling is the same as whats available on chinese market sites like alibaba.com
it takes a bit of searching but you can find the right size material. of course its not exactly like original. I imagine that would have to be custom made.
http://www.alibaba.com/product-detail/pvc-edge-banding-with-gold-film_1146003117.html
drive your split.
grailoc
grailoc is offline
PostPosted: Tue Oct 21, 2014 12:37 pm    Post subject: Reply with quote
5000 meter minimum order, I don`t know how much SO-23 westies this represent Smile
jjjjack
jjjjack is offline
PostPosted: Tue Oct 21, 2014 1:01 pm    Post subject: Reply with quote
group buy?
Jack Stenner
1959 Mango Westfalia SO-23
1953 Porsche 356 Coupe
IG:j.stenner
View user's profile Send private message Visit poster's website Twitter Instagram Gallery Classifieds Feedback
grailoc
grailoc is offline
PostPosted: Tue Oct 21, 2014 1:05 pm    Post subject: Reply with quote
let`s say 5 meter required by bus,
5000/5 = 1000 bus Smile
cab2276
cab2276 is offline
PostPosted: Tue Oct 21, 2014 1:16 pm    Post subject: Reply with quote
With me, it's 5
Still 995 !!!!
earlywesty
earlywesty is offline
PostPosted: Tue Oct 21, 2014 4:05 pm    Post subject: Reply with quote
cab2276 wrote:
Salut Jérome,
Guillaume
If this is a drawing of the subhatch roof wood then the drawing is incorrect. The red piece does exist, the front edge is straight across from corner to corner.
grailoc
grailoc is offline
PostPosted: Tue Oct 21, 2014 5:18 pm    Post subject: Reply with quote
the drawing I made is based on the cut I did,
and the red line has the same width as the fresh air box.
here is a picture after the roof was installed:
To restore my roof, I did not have an original subhatch wood panel that I could use as master, so I probably made some mistakes, however both dimensions I came-up with made the resotred roof spot on.
cab2276
cab2276 is offline
PostPosted: Wed Oct 22, 2014 12:55 am    Post subject: Reply with quote
Ok, thank you for your answers
i'm going to experiment
earlywesty
PostPosted: Wed Oct 22, 2014 3:45 am    Post subject: Reply with quote
You can see in these photos that the og piece is straight across on the front edge. I found that the grill on the fresh air vent had to be put on after the wood was in place to allow it so sit right.
cab2276
cab2276 is offline
PostPosted: Wed Oct 22, 2014 4:19 am    Post subject: Reply with quote
great !!! thank you so much for these photos !!!
grailoc
grailoc is offline
PostPosted: Wed Oct 22, 2014 4:55 am    Post subject: Reply with quote
beside that detail, dimensions I provided in my drawing should be right.
However, cab2276 I suggest you to make some trial before you cut the final plywood. I saw that the subhatch roof was grafted on your bus, so you need to be even more vigilant.
to keep the roof right in place and edges locked into the gutters you need to make sure to build those slices of plywood that will be nailed onto the hard wood structure. otherwise the panel will pop-up.
cab2276
cab2276 is offline
PostPosted: Wed Oct 22, 2014 5:33 am    Post subject: Reply with quote
je n'ai pas fait l'ouverture de la trappe du toit
je la tracerai quand le bois sera en place
I did not open the roof hatch
I will trace when the wood is in place
merci pour ton aide
Stocknazi
Stocknazi is offline
PostPosted: Wed Oct 22, 2014 5:27 pm    Post subject: Reply with quote
buseric wrote:
cab2276 wrote:
Salut Jérome,
Guillaume
Has someone with an og ceiling panel comfirmed that the deminsions posted above are correct?
WANTED:
Thomas Jefferson
bubba
bubba is offline
PostPosted: Wed Oct 22, 2014 5:58 pm    Post subject: Reply with quote
Sounds like a lot of footage.. But at .15 foot.. Is still worth it... I'm down for a set to do all three tables
***WANTED***
SO-23 Cargo net hooks...
for sale
curtain Bungee cords for SO23, 22, 33 ,34 ,35
http://www.thesamba.com/vw/classifieds/detail.php?id=1587591
Clara Premium Member
Clara is offline
PostPosted: Fri Oct 24, 2014 6:27 am    Post subject: Reply with quote
StockNazi wrote:
buseric wrote:
cab2276 wrote:
Salut Jérome,
Guillaume
If this is a drawing of the subhatch roof wood then the drawing is incorrect. The red piece does - not -exist, the front edge is straight across from corner to corner.
I have found that whole the so42 has the notch for the fresh air vent , the earlier Westys do not have the notch.
Also, the cab roof panels for the so-42 are slightly shorter. The earlier Westys use stock for Kombi length cab roof panels.
The seam between wood and grey for the so42 falls in the middle of the metal brace. While the seam for the earlier westy falls at the back edge of the metal brace and the screws go into the wood bow.
This means the middle large roof panel for an so42 is slightly longer than the so23 version.
X2 on what buseric said
I have used several slightly different patterns for the roof panels. There is some wiggle room there.
That Limba looks lovely and really pops!
grailoc
grailoc is offline
PostPosted: Fri Oct 24, 2014 7:15 am    Post subject: Reply with quote
Thanks providing clarification and differences between roof panels. As I said earlier, since back in the time I did not have any original master to start from, I used pictures information and measurements I was able to find and deduct, which in the end made my roof restoration work well.
vwboop
vwboop is offline
PostPosted: Fri Oct 24, 2014 7:16 am    Post subject: Reply with quote
we have two conversations goin on here. I like both of them Wink Let's continue the gold trim one here:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7373375&highlight=#7373375
"Love and good roads"
Page 15 of 20
